Old February 20th, 2018, 05:55 PM   #1
DieselKilgore
Motorcycle(s): '05 Ninja 250, '80 KZ750
Fast flashers with incandescent bulbs, no leds?
Is this a normal problem, even with regular incandescent bulbs?
I've had my '05 for 2 years and have always lived with it. But for this spring and summer it's one of the things that's left on my to do list.
Any one have this same problem without leds?
Sometimes with the bike idling it'll start flashing at a normal pace but eventually it always goes into the fast flash just after 5 seconds or so.
I'm gonna get a new flasher relay and see if that will fix it.
DieselKilgore is offline   Reply With Quote
Old February 20th, 2018, 06:45 PM   #2
A new flasher might fix it (not a relay). Or is it possible someone put different bulbs in than standard?
Old February 20th, 2018, 09:21 PM   #3
Are both bulbs flashing when it does the fast flash?
Old February 21st, 2018, 11:45 AM   #4
DieselKilgore
No they flash separately.
Would a led in the gauge cluster cause this?
Old February 21st, 2018, 12:52 PM   #5
taz
taz's Avatar
MOTM - May '17
Originally Posted by dieselkilgore View Post
no they flash separately.
the front and rear of the corresponding side should blink at the same time.
Old February 21st, 2018, 01:40 PM   #6
DieselKilgore
Oh yes. They flash the same time. Sorry I misread what the post meant.
Old February 21st, 2018, 01:51 PM   #7
Pull out the bulbs and check their part#. If different bulb was used with higher resistance than stock, that would cause flasher-relay to not work correctly.
Old February 21st, 2018, 05:15 PM   #8
DieselKilgore
Gauge cluster or flashers? Or both?
Old February 21st, 2018, 06:04 PM   #9
The turn-signal bulbs themselves. Their resistance dictates the flashing rate. Wouldn’t hurt to measure their resistance too.
Old February 22nd, 2018, 07:25 AM   #10
If the main turn signal bulbs have something like '12v 21w" or "12v 23w" stamped on the bases, they're probably original. 1156 is a correct replacement from any auto parts store.
Old March 1st, 2018, 11:55 AM   #11
VaFish
VaFish's Avatar
MOTM - Jan '16
There are smaller bulbs with lower wattage that still fit in the socket which will give a fast flash like the LED bulbs will.
Old March 7th, 2018, 08:28 PM   #12
Dab
Motorcycle(s): 1996 ninja 250
bulbs could all be original size but the tungsten filament could have slightly shorted out on itself reducing the resistance while still lighting up i would replace the bulbs one by one but install a new flasher first and you should be good to go
Dab is offline   Reply With Quote
Lighting Issues. Flashers/Turn Signals Help. Dahaka 2008 - 2012 Ninja 250R Tech Talk 5 January 4th, 2016 07:01 PM
Flashers, fuses, other electrical garbage Amsler457 2008 - 2012 Ninja 250R Tech Talk 7 April 4th, 2014 09:37 AM
After Market Incandescent Turn Signals AMMOCAN General Motorcycling Discussion 11 April 7th, 2011 02:01 PM
