Old January 28th, 2014, 06:40 PM   #1
Bill N
Motorcycle(s): 250 Ninja
Rear brakes - pad replacement
Time for new brake pads on the 08 250. Front looks very easy. The rear caliper looks like muffler must be removed. Not obvious looking at it as to how to remove the muffler. Would appreciate some advice before I do the job. Thanks, Bill
Bill N is offline   Reply With Quote
Old January 28th, 2014, 06:51 PM   #2
I'm pretty sure you can do it without removing the muffler, just need a longer extension on an allen wrench to loosen the caliper mounting bolts. Might be able to get some more clearance by just removing the bolt attaching the muffler mount up to the passenger peg area, so the end can is able to move slightly.
Old January 28th, 2014, 06:51 PM   #3
/moved to new-gen tech area
Old January 28th, 2014, 06:52 PM   #4
Whiskey
You can get a hex key in there to loosen the pins & take the caliper off without removing the exhaust, I found with a ratchet, extension & hex bit the job was easy enough.
Old January 28th, 2014, 07:25 PM   #5
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r (Slightly Modded)
This is actually depends on the kind of exhaust you have. If it is stock, you can get by without removing it. Some aftermarket exhausts make it impossible, such as the HMF Exhaust.
I don't know what you have, so I'll tell you what I did.
-Loosen all the connections your muffler has to the bike, and loosen the t-bolt clamp.
-Use lubricant or general purpose oil around where the muffler attaches to the actual exhaust pipe. *Make sure the bike is COLD before doing so*
-If you can't work the muffler off with some elbow grease and your bare hands, read the following.
-Take a cloth or towel and hold it under the base of the muffler.
-Now take a hammer and bang it loose. The towel/cloth is there to prevent denting or damage to your muffler.
Now, like others have said, if it's stock, you don't need to remove it, you can use extensions to get around it. If you have aftermarket and it proves problematic just follow the above.
May the force be with you and keep your rubber side down.
Sykes92 is offline   Reply With Quote
Old January 29th, 2014, 02:48 PM   #6
Bill N
I have a knee problem for the moment which prevents me from laying down or stooping to see the pins. Are they acessed from the left side of the bike thru the wheel? If so your post is now very clear to me.
Thanks, Bill
Old January 29th, 2014, 03:22 PM   #7
I think you can do everything from the right side of the bike; no need to go through the wheel.
Old January 29th, 2014, 04:12 PM   #8
Whiskey
Thanks, Bill
2 pins at the top hold the pads, the 2 bolts below hold the caliper to the bike, loosen the top 2 first, & re mount it before torquing them.
The brake line usually covers the lower bolts.
Old January 30th, 2014, 03:24 PM   #9
Bill N
A picture is worth a thousand words. That clears up everything. When my knee heals I'll get down there and do the job. Many thanks. Bill
Do you use your rear brakes and when? ally99 Riding Skills 244 May 22nd, 2013 01:57 PM
Rear Brake Pad Replacement neff 2008 - 2012 Ninja 250R Tech Talk 12 April 8th, 2013 06:22 PM
Rear end fender pad Slono 2008 - 2012 Ninja 250R Tech Talk 3 December 19th, 2011 07:24 PM
replacing rear brakes ians_04_250 1986 - 2007 Ninja 250R Tech Talk 7 August 2nd, 2009 10:34 PM
Timing my pad replacement headshrink 2008 - 2012 Ninja 250R Tech Talk 7 April 16th, 2009 09:24 PM
