March 20th, 2010, 04:11 PM | #1 |
james250ninjette.newbie
Join Date: Mar 2010 Motorcycle(s): 1986 ninja 250 Posts: 276
bar ends
i had trouble taking my bar ends off i ended up with bar end off cause the bolt was stripped so i have 1 on and 1 off bar ends will this make a diffrence in riding
March 20th, 2010, 05:20 PM | #2 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250R (sold) Posts: 356
Not really, no. Blow torch is needed to not strip them.
March 20th, 2010, 06:13 PM | #3 |
Humble Observer
Join Date: Mar 2009 Motorcycle(s): 2009 Yamaha XT250 Posts: 612
James, I ended up in the same situation. Tried the blowtorch trick in combination with a philips bit on a ratchet, but that didn't work. The screw head eventually got drilled out so the bar end just slid off, and then used vise-grips to unscrew the shank from the bar.
Everything I post is "IN MY HONEST OPINION". Why is "Parking Lot Enduro" not a thing? |
March 20th, 2010, 06:26 PM | #4 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Without the bar end on there, you may notice a bit more vibration in that grip....the bar end weights are there to dampen the vibration in the handlebars so you dont get that hand numbing buzz.
March 21st, 2010, 11:22 PM | #5 |
Fastly Slow!!!
Join Date: Feb 2010 Motorcycle(s): 2007 Kawasaki Ninja EX250, 1980 Honda XL125 Posts: 467
I initially bought some LIGHT, Cheap anodized bar ends when I bought the bike. Holy crap these things VIbrate with no weight on the ends. Ended up buying some custom lathe turned HEAVY bar ends, now no vibrations at all.
March 22nd, 2010, 06:03 PM | #6 |
two wheels good
Join Date: Mar 2010 Motorcycle(s): 04 ex250 and 08 Triumph Sprint ST and custom calfee carbon race tandem Posts: 71
uh oh
Just got an impact driver cheap for this task (and a few others).
Hope that will work...maybe I should hit it with a torch first??? also like the Throttlemeister product and wonder if I can gat old bar end off to install.
Some must watch while others must sleep |
March 22nd, 2010, 06:17 PM | #7 |
Join Date: Oct 2009 Motorcycle(s): Red 08 250r Posts: 218
you need to up heat bars
Posted via Mobile Device |
March 22nd, 2010, 08:04 PM | #8 | |
April 16th, 2010, 10:23 AM | #9 | |
How did it go? Did you end up needed to heat it up like everyone is saying? |
April 17th, 2010, 05:52 AM | #10 | |
two wheels good
Will get to grips over weekend with new impact driver and let you know. Ps it already paid for itself on Axle nut and stubborn soft carb bolts! Nice tool to have around Posted via Mobile Device |
April 18th, 2010, 05:59 PM | #11 |
two wheels good
impact driver
My little CH impact driver did the trick!! No torch required.
Took a little while and it fought to the last thread. I'm glad it was air powered because it would have taked all day with a hammer powered one. I need some of that loctite available for me to use...I think it could hold congress together!
April 18th, 2010, 08:56 PM | #12 | |
I was planing on using blue loctite when I put the new bar ends on. I don't get why they use red! What kind of attachment did you use? |
April 22nd, 2010, 03:45 AM | #13 |
two wheels good
On the impact driver or the barends? I got in the habit of putting blue locktite on all my barends after one went on its own way on another bike. yep it was a fancy throttlemeister one too! ouch.
On this bike it is still sufficiently hard to twist the screw because of the residual red locktite that I am not going to worry about it.
April 22nd, 2010, 04:06 AM | #14 | |
bar ends.... | gkarats | 2008 - 2012 Ninja 250R Tech Talk | 9 | October 30th, 2013 05:26 AM |
Bar Ends | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 8th, 2013 11:17 PM |
bar ends | skikman | 1986 - 2007 Ninja 250R Tech Talk | 8 | January 7th, 2013 06:15 AM |
!@#$!ing bar ends! Torch, impact screwdriver, breaker bar, etc ALL failed. :( | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 64 | September 13th, 2012 11:50 AM |
Bar ends | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 22nd, 2011 08:54 PM |
