Old September 26th, 2012, 03:09 PM   #1
YMCMB
YMCMBillionaire
YMCMB's Avatar
Motorcycle(s): 2008 Ninja 250R(Wrecked&Gone), 2004 Honda CBR1000RR (Trading back to dealer for 600cc)
Headlight Upgrade etc..
Ok I was wondering I was wanting to upgrade my headlights on the 250 to HID kit. Where could I get a SET for cheap online but good quality and My Ninja 'Elektra' is blue and I want blue ones but not completely blue more like 6k to 8k whiteish blue what size should I get to fit is it H4? H7? Etc? Also nooby question what wattage and amp etc should I get? Any help will be appreciated Cheers!
YMCMB is offline   Reply With Quote
Old September 27th, 2012, 09:21 AM   #2
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
H7
55W
I never messed w/the kits, I just bought the bulbs.
100% these will work but hopefully there's somewhere else that's cheaper.
http://www.ebay.com/itm/PHILIPS-4000...58c1ce&vxp=mtr
http://www.mea.philips.com/c/motorbi...2972bvubw/prd/
THE GOOD LIFE
Old September 27th, 2012, 09:34 AM   #3
It's illegal and annoying to put hids in without a projector
Old September 27th, 2012, 10:20 AM   #4
xaple
xaple's Avatar
I also wanted to get hids but didn't due to these reason, what is a projector?
xaple is offline   Reply With Quote
Old September 27th, 2012, 10:32 AM   #5
a projector is a lens with a cutoff that makes it so you don't blind the **** out of the people in front of you when you use hids.
Old September 27th, 2012, 10:33 AM   #6
nealt
Motorcycle(s): 09 Ninja 250
Best option so far for getting a projector installed, instructions are pretty clear and straight forward.
http://bkmoto.com/index.php?route=pr...&product_id=55
Please don't throw in HID bulbs without projectors...wut others have said
Last futzed with by nealt; September 27th, 2012 at 12:43 PM.
nealt is offline   Reply With Quote
Old September 27th, 2012, 10:46 AM   #7
xaple
xaple's Avatar
What does it do angle it down towards the ground or something?
Old September 27th, 2012, 10:53 AM   #8
HID bulbs are not designed for standard reflectors. they make lots of scattered light that goes in all directions. projectors are designed for hid bulbs. do a google search
Old September 27th, 2012, 11:12 AM   #9
Projectors make a clean cut-off line and fill in everything underneath that line with light. You can then control the cut-off thingy with your high beam switch to give you "high" beams.
Basically, you can then control the output of the HID bulb so it doesn't accidentally blind people.
Old September 27th, 2012, 09:51 PM   #10
cuz
cuz
cuz's Avatar
ohh & G Unit!!!
that's all.
THE GOOD LIFE
To upgrade or not to upgrade... neldy General Motorcycling Discussion 19 August 29th, 2011 10:21 PM
Mounting stock headlight and gauges using headlight clamps? SV_Hadder 1986 - 2007 Ninja 250R Farkles 0 January 17th, 2011 09:15 PM
Looking to upgrade... P1NDLESK1N General Motorcycling Discussion 12 June 24th, 2009 11:12 AM
