Old August 25th, 2010, 06:27 PM   #1
highpsiguy
highpsiguy's Avatar
Motorcycle(s): 1981 Honda Cx500 Custom, 2002 Ninja 250
Need windshield screw and plastic grommet/nut for 02
Need plastic windshield gromet and screw for my 02 Ninja 250. Got an extra one u can throw in an envelope and send my way? Also need rubber gromet that holds left sidecover onto plastic on left side right under seat towards front.
THANKS!!!!!!!!
"Rudeness is a weak persons attempt at strength."
highpsiguy is offline   Reply With Quote
Old August 25th, 2010, 08:56 PM   #2
are you looking for wellnuts? if so, they are a common item that go bad on our bikes. I suggest you pick up a handful at your local dealer.
Old August 26th, 2010, 09:06 AM   #3
Cuongism
Cuongism's Avatar
I bought a windshield kit from cycle gear that has 8 wellnuts, washers, and screws (also comes in 4 colors). I used the wellnuts for my fairings and they fit perfectly. I think it was $15 for 8 sets.
WTB: Float Bowl Screw, Gas tank fairing grommet haze5736 Items Wanted 0 July 19th, 2011 07:04 AM
Missing Rocker arm and valve adjust screw/nut Ragnar1x 1986 - 2007 Ninja 250R Tech Talk 45 May 22nd, 2011 09:28 AM
2005 left handle bar and screw and nut for clutch handle gogiburn Items Wanted 4 June 24th, 2010 01:17 AM
