Old January 3rd, 2010, 01:05 AM   #1
bikermunda
Ninja World YAY
Bike is not starting now :(
I havent started my biker for a month or so and now i was trying to start the bike and it is not starting today even after using the choke.
Any advice how to start the engine
bikermunda is offline   Reply With Quote
Old January 3rd, 2010, 04:09 AM   #2
bikermunda
Ninja World YAY
18 views but no suggestions ?
Old January 3rd, 2010, 07:41 AM   #3
Samer
Samer's Avatar
Motorcycle(s): 09 Ninja 250R SE
Umm, the battery would be the obvious first check. People who don't start their bike for a long time typically would use a battery tender to keep it charged. If you look at your manual, you will see that there are a number of days that it takes to drain the battery from full charge to zero.
What sound is being made when you try to start the bike? Is it even turning over?
Samer is offline   Reply With Quote
Old January 3rd, 2010, 09:26 AM   #4
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Crank the bike for a few seconds without the choke. Then with the choke, then with the choke and hold the throttle open, then only with the choke on. Usually if you then keep trying it, for a few seconds at a time, the bike will start to "try" to start. After maybe 7-8 tries, it will probably start. I just did the same thing, started both bikes after sitting for 4-5 weeks (the fuel injected cbr fired after two key cycles and then a couple engine revolutions). The fuel system needs to fill (lines, carbs) and so you gotta coax it along. You could also remove the air filter and give it a small shot of starting fluid to nudge it along.
Old January 3rd, 2010, 09:37 AM   #5
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
If its Cali crap gas, then your pilot jets are probably clogged. I start my bikes every week, or I get the same thing. You'll need to pull the carbs out and clean them.
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old January 3rd, 2010, 04:08 PM   #6
bikermunda
Ninja World YAY
thanks for all the advice my bike did started right now and i will make sure i start it once a week to make sure i dont get into issues like this again
Old January 3rd, 2010, 10:02 PM   #7
Betlog
Betlog's Avatar
Motorcycle(s): 2009 250r
So what did you do to make it work?
Betlog is offline   Reply With Quote
Bike has trouble starting capriccio 2008 - 2012 Ninja 250R Tech Talk 7 July 19th, 2012 10:37 AM
Bike not starting.... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 2 April 29th, 2012 07:33 PM
Starting New Bike Club! MotoED General Motorcycling Discussion 4 September 20th, 2011 11:20 AM
Bike not starting?! nightrider 2008 - 2012 Ninja 250R Tech Talk 32 September 5th, 2011 04:44 PM
starting bike james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 April 3rd, 2010 12:12 PM
