September 23rd, 2009, 04:11 PM | #1 |
Join Date: Dec 2008 Motorcycle(s): ninja 250r Posts: 371
Sportisi USA clipons - Installed
Well I got the clip-on's from matt 2 days ago and all I have to say is WOW THEY ARE GREAT. these are very light with them both in one hand and one of the stock handles bars in the other the stock one is heavier then both of the clip-on's the look and finish is great not a single complaint from me at all even the mounting hardware is nice, the install was easy as with all clip-on's it took me about 1hr to finish it by myself. I went on a nice ride with them and found that this is what I was missing the handling feels much sharper and crisp all in all for $110 bucks you cant beat it thanks Matt
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl |
September 23rd, 2009, 04:39 PM | #3 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250R Posts: 89
Wow I wish I knew about these 3 weeks ago! I dropped about $170 for my Woodcrafts, and they do the same thing.
Do you ride through twisties? If so, how does it handle? |
September 23rd, 2009, 05:08 PM | #4 |
I told myself that I was just going around the block and ended up going to Mt lemon instead and with the new clip-on's it was amazing. if you do not know how the roads are do a Google search and you will see it is a haven for the aggressive rider in the turns. I wish I had these for a ride I did last month up Hwy 191 witch is killer and down the salt river canyon.
September 23rd, 2009, 05:26 PM | #5 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
$110 is the GB price. Normally these will be $115 Look good to hmm damn now I need to order a new set.
Sportisimoto USA is born. |
September 23rd, 2009, 11:33 PM | #6 |
Join Date: Jun 2009 Motorcycle(s): 06 Ninja 650R, 08 Ninja 250R, 00 Aprilia SR50 (dead) Posts: 94
Those actually look better than the woodcraft setup...great price too...
September 24th, 2009, 12:01 AM | #7 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250R Posts: 98
Can we get a set of these now or place an order?
September 24th, 2009, 12:14 AM | #8 |
The Sportisi Master
pm me
September 24th, 2009, 05:02 AM | #9 |
n00b
Join Date: Sep 2009 Motorcycle(s): 09 250r Blue Area P, Factory Pro Jet kit, woodcraft rearsets, Galfer SS brake lines Posts: 19
do your hands rub anywhere when turning the bars from lock to lock?
September 24th, 2009, 05:31 AM | #10 |
Do you know how far you had to raise the forks in order to fit these, or how much total fork leg is above the triple now? (I have a calculator )
September 24th, 2009, 07:16 AM | #11 |
How long did it take you to install these? and is it any different than the woodcraft install?
Matt you're killin me man. Just when I tell myself I won't buy any more toys, I see these..I've gotta save for a couple weeks, but I want some!! |
September 24th, 2009, 07:38 AM | #12 |
The Sportisi Master
September 24th, 2009, 07:39 AM | #13 |
The Sportisi Master
difference between this and woodcraft is you adjust your forks.
September 24th, 2009, 07:40 AM | #14 |
The Sportisi Master
15mm is sticking up to begin with I imagine about 10mm more
September 24th, 2009, 10:43 AM | #15 |
September 24th, 2009, 11:36 AM | #16 |
Fighting Texas Aggie '05
they look great in black
September 24th, 2009, 12:01 PM | #17 |
Join Date: Apr 2009 Motorcycle(s): '04 sv650s Posts: 438
So you en up dropping the bike about 10 mm ? that's not too bad....gaining a little bike of agressive angle there
There's 2 types of people in this world, those who complain and those who act. |
September 24th, 2009, 01:11 PM | #18 |
Join Date: Mar 2009 Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636. Posts: 918
looking sharp
did you need to drill a hole in the handlebar to mount the controls? |
September 24th, 2009, 03:50 PM | #19 |
n00b
Mike i have the same joerocket jacket as you!
September 24th, 2009, 04:07 PM | #20 |
yes i did i went ahead and made 3 holes one each one for adjustibility or you could just cut the nub of and mount it that way
September 24th, 2009, 04:08 PM | #21 |
it took a little over an hour and i have not mess with the woodcraft so i do not know
September 24th, 2009, 04:10 PM | #22 |
ya this jacket is great I really like how it vents and it has a lot of armor on it
September 24th, 2009, 04:17 PM | #23 |
n00b
September 24th, 2009, 04:19 PM | #24 |
you will like the clip ons and Matt will do you right i have never had a prob with him and his customer service is great
September 24th, 2009, 07:18 PM | #25 |
The Sportisi Master
silver in case you wanted to see
May 4th, 2011, 12:58 PM | #26 |
Join Date: Mar 2011 Motorcycle(s): 09 ninja 250r - yoshi slip-on, fender-elim, Pazzo levers, Pro-bolt gold mods, b-monkey ITL, SSR hanger/spools Posts: 69
just pm'd ztrack about these, hoping im not too late
can I install the gold pre-load adjusters with these clip-ons?? Stoked to get this set-up! looks amazing! cheers, |
May 4th, 2011, 01:06 PM | #27 |
also, do these clip-ons drop the height of the bars???
I notice that the woodcraft clip-ons go underneath the fork bracket/clamp, I'm a newb when it comes to clip-ons, this will be a first! all help/info is much appreciated. thanks everyone! |
May 5th, 2011, 07:33 AM | #28 |
You should be able to use the fork preload adjusters in combination with these without any issue. These clipons will drop the height of the bars, as well as lengthen the reach to the bars a tidbit.
The Woodcraft clipons will drop the height a little bit more and so by geometry the reach will be a little bit further too. Bear in mind that the Woodcraft clipons are actually rising clipons, which is why they are only a little bit lower, even though they mount below the upper triple tree. |
Koso RX-2 and WC Clipons [installed!] | NikkitaNinja | 2008 - 2012 Ninja 250R Farkles | 19 | September 12th, 2011 10:24 PM |
Sportisi USA Rearsets - Installed and reviewed | NorCal_250R | 2008 - 2012 Ninja 250R Tech Talk | 43 | July 11th, 2011 10:49 AM |
Sportisi Undertail | tjb0012 | 2008 - 2012 Ninja 250R Farkles | 2 | May 3rd, 2010 10:17 AM |
Installed my Sportisi Exhaust today | CrzyFstMnM | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 23rd, 2009 05:26 PM |
Sportisi Hugger | bikeboyben14 | Motorcycle-related | 1 | June 27th, 2009 01:23 AM |
