Old October 18th, 2009, 11:01 AM   #1
Jam3s
n00b
Jam3s's Avatar
Motorcycle(s): 09 250r Blue Area P, Factory Pro Jet kit, woodcraft rearsets, Galfer SS brake lines
Leaking low speed mixture screw?
This morning i decided to get the bike started and go for a short ride but its very cold here in NW Indiana so getting her started it a project... I had enough time to adjust the mixture screws so i richened up both cylinders about 1/4 turn each. "when its this cold out the bike wont even start with the choke on." After that she fired right up even without the choke! WOW i went for a short 15 mile ride and was blow away i was having so much fun the bike was pulling so hard all through the revs. But i noticed my idle went from 1300rpms to 1500-1600. so i went home and parked the bike and checked the carbs and this is what i found.
it looks like the right mixture screw is leaking?
By the way this is my bike
Jam3s is offline   Reply With Quote
Old October 18th, 2009, 11:18 AM   #2
Jordan,
Sorry, can't see your picture clearly of the mixture screw area. Can you take another??? Possibly use the macro feature on the camera?
If the screw is backed out too much, it can leak, I believe. You should check to see how many turns you are backed out on that mixture screw. Also, there is a gasket in there, so that could be leaking.
Old October 18th, 2009, 11:27 AM   #3
Jam3s
n00b
Jam3s's Avatar
Better pic. Yeah looks like its leaking. hum and i think im only up to 3 turns. has anyone else run into this problem?
Old October 18th, 2009, 11:34 AM   #4
Is it greasy or "wet" around that area? Doesn't look like it.
You might want to place a piece of paper/cardboard under that area and leave it overnight to see if you can find traces of a leak. Better yet would be a small container filled with some water.
Old October 18th, 2009, 11:41 AM   #5
Jam3s
n00b
Jam3s's Avatar
then thats what ill do! btw Kelly what do you think of the K&N R-0990? worth the money?
Old October 18th, 2009, 11:46 AM   #6
You'll lose some low end w/o the airbox, but I feel the gains were worth it in the midrange through top end pull.
Pulling the airbox out was the biggest problem and if I had to do it over, I don't think I'd switch. I'd keep the airbox, stick a drop in K&N filter (or some other aftermarket filter) and remove the snorkel.
Old October 18th, 2009, 11:58 AM   #7
HKr1
IC2(SW)
HKr1's Avatar
3 turns out, you might just want to go 1 bigger on the pilot jet. It will put the mix screw back in(less turns out).
Stock mixture screw settings ferret09 2008 - 2012 Ninja 250R Tech Talk 6 September 12th, 2023 11:00 PM
what is the best idle screw mixture vmax 2008 - 2012 Ninja 250R Tech Talk 9 July 1st, 2017 10:45 AM
Mixture screw turns. simook 2008 - 2012 Ninja 250R Tech Talk 7 October 13th, 2013 07:26 PM
Idle Mixture Screw Problem gogoKawi 2008 - 2012 Ninja 250R Tech Talk 6 April 23rd, 2013 07:07 PM
Idle Mixture adjustment screw Q indr 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2010 09:36 PM
