Old November 8th, 2012, 04:42 PM   #1
SabreValkyrn
Motorcycle(s): 2017 Motus MSTR (Kara), 1990 Ninja 600R (ZX600C3) (Scrappy)
Exclamation Front brake not engaging
I was having front wheel squeak off and on, and yesterday it was almost deafening at parking lot speeds, then it disappeared for a bit.
So I decided to take off the axle and regrease. I took off the front wheel, cleaned each of the pieces and greased appropriately (I think). I must have bumped the brake lever when repositioning the bike, so the brake pads were too close together for the disc to fit and wouldn't spread apart.
I took out the outer brake pad to see/spread the pistons. The lower piston appeared stuck, so I WD40'd it and bled the brakes a little to get them to spread apart. Got everything back on, including that gorram speedo wheel PoS thing. And was spinning the front wheel to test if it spun freely and brake... brake.... brake brake brake. Nothing. Wheel kept free spinning.
So I thought I had gotten air in the tubes, I bled and refilled the system. Brakes still didn't work. Okay... maybe I got air in it again. So I re-bled and filled the system. Brake caliper still doesn't work.
20% total brake capacity is totally fine, right?
Help please.
I looked at both faq.ninja250.org and ninjette's wikis and can't figure out what I did incorrectly.
SabreValkyrn is offline   Reply With Quote
Old November 8th, 2012, 05:19 PM   #2
What exactly did you spray wd-40 on? Did any get on the pads themselves?
What does the brake lever feel like, does it firm up, or does it just go right to the bar with no resistance?
Old November 8th, 2012, 05:20 PM   #3
Does the brake lever travel to the grip easily? if so, there's still air in the lines. Squeeze forcefully and make sure you have the order of motions correct. It's less of a forceful squeeze, and more of a hard grab, with a quick open/close of the bleeder thrown in there.
Old November 8th, 2012, 05:59 PM   #4
SabreValkyrn
WD-40; I sprayed it on the pistons without the outer brake pad, so unless it bounced off and hit the inner pad, there shouldn't be any on the disc or pads.
It is same resistance all the way to the grip.
Chone, you're thinking I was too slow with the lever and bleeder changeoff?
Old November 8th, 2012, 06:05 PM   #5
Only if you can easily squeeze the lever the whole way to the grip.
If the lever is just as firm as normal, then I have no idea.
Old November 8th, 2012, 06:17 PM   #6
SabreValkyrn
I'll try the steps again and be more abrupt then.
Thanks for the speedy input
Old November 8th, 2012, 08:07 PM   #7
Did you pump the lever repeatedly after spreading the pads before bleeding and refilling the system? Mine goes all the way to the handle with slack several times before firming up when I spread them like that.
Old November 8th, 2012, 08:33 PM   #8
SabreValkyrn
Before bleeding and refilling, should the pads be touching the disc, all the way apart, or does it matter?
I pulled the lever a lot of times, thinking just that; but it still did nothing to stop the wheel.
Old November 8th, 2012, 09:37 PM   #9
SabreValkyrn
Okay, I abruptly turned and pulled and it appears to work. I just about went postal on it.
It brakes really pathetically, like less than the rear brake. If there was still air in the lines it wouldn't even be functioning, right? If so, that means I must have gotten grease or wd-40 onto the disc. Probably from cleaning grease/WD-40 off of other things then wiping down the disc with the same rag.
Old November 8th, 2012, 09:43 PM   #10
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
You can have some engagement and feel but still have air in the lines. If you have access to a syringe I would recommend you get a piece of tubing, put it onto the end of the syringe, and fill the syringe with brake fluid. Take your MC reservoir cover off and crack open the bleed nipple. Inject the brake fluid through the bleed nipple. (This will help drive any air up, through the MC).
You could also try cracking your banjo bolts lightly and bleed any air out of the threads in the bolts that may be present.
k-os is offline   Reply With Quote
Old November 8th, 2012, 10:14 PM   #11
SabreValkyrn
I might try that tomorrow. It's too dark to see now.
I zip tied the brake lever and letting it sit overnight, one of the wikis says that's an option to try, and might as well since I can't try anything else now anyway?
Old November 9th, 2012, 08:23 AM   #12
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
From what I understand the brake pads are very sensitive to chemicals. If you didn't use brake cleaner on your rotor and any WD-40 got on it it's not coming off with just a rag. I would spray the rotor with brake cleaner and dry with canned air and a dry towel/cloth but if your pads got anything on them you might be best off replacing them...
Old November 9th, 2012, 12:22 PM   #13
SabreValkyrn
*Sigh of relief* There was just air in the lines. Leaving the brake lever zip tied to the grip over night let the air leak out.
Thank you everyone for the help!
And on the bright side, I now know how to: replace brake pads, bleed and refill brake system, remove front wheel, replace front wheel, align that gorram speedo thing, spread brake pads, and beg for help on this wonderful forum.
Clutch not fully engaging? greenmachine 2008 - 2012 Ninja 250R Tech Talk 3 August 10th, 2013 01:05 PM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
[superbikeplanet.com] - Engaging Front Man Toseland Set To Entertain IMS With His Mus Ninjette Newsbot Motorcycling News 0 July 14th, 2011 12:50 PM
Help Please! Clutch not engaging! splittrain 2008 - 2012 Ninja 250R Tech Talk 13 August 19th, 2010 01:43 PM
