Old August 5th, 2016, 05:46 PM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Welp, it happened: Put a hole in my tank
I've heard the stories before, but yet it happened to me today. The right-side top fairing bolt put a hole in my gas tank on my '07 Ninja 250.
I've heard JB weld deteriorates over time and isn't a great fix.
Professional welding is an option, but I'm told you have to completely clean the inside of the tank so that there's no gas left. Plus, you have to end up repainting it?
Lastly, just replacing the gas tank is probably the best option? I'm sure I can find one on eBay or Craigslist.
Any thoughts?
Cra1g is offline   Reply With Quote
Old August 5th, 2016, 05:49 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Any thoughts?
They make a metal epoxy for repairing gas tanks. It's not cheap though, I think $60 for the kit.
Depends on what you can get a new tank for.
Goin' fast on slow bikes!
Old August 5th, 2016, 05:56 PM   #3
Cra1g
Cra1g's Avatar
How would I go about applying it? There's the metal tab that sort of blocks the hole, making it hard to get to: http://imgur.com/a/2viMs
Old August 5th, 2016, 06:03 PM   #4
juliusmichaelhonrada
Motorcycle(s): GPX250-RII
the bolt will push the epoxy where it made the hole
juliusmichaelhonrada is offline   Reply With Quote
Old August 5th, 2016, 06:04 PM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
You get some popsicle sticks, some sandpaper, some glue to stick the sand paper to the stick, some alcohol, and a whole crap ton of patience!!
This is a smaller container and much cheaper. I've used it before and it works well! I'd trust it.
https://www.amazon.com/Marine-Tex-Ep.../dp/B0014419V0
Old August 5th, 2016, 06:04 PM   #6
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Oh, and by the way, if you put a hole in the gas tank, you used the wrong fairing bolt in that hole. They are different lengths....check before you insert!!
Old August 5th, 2016, 06:11 PM   #7
Cra1g
Cra1g's Avatar
So this stuff will work with the gas tank's metal and won't be affected by the gasoline?
What's the sandpaper and alcohol for? Prepping the area I'm guessing? Anything special I need to do? Any tips to seal it the best I can? Sorry for all the questions!!
All the bolts are the same length..
Old August 5th, 2016, 06:11 PM   #8
probably cheapest to just get a used tank...
Old August 5th, 2016, 06:13 PM   #9
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Hmmm....Ok. Thought the uppers were shorter. Might want to shorten it so it doesn't happen again....
Anyway, sand the paint away around the hole down to bare metal. Alcohol to clean up sanding residue. Apply epoxy EXACTLY per instructions.
Yes, it's gasoline safe and resistant. Will work just fine.
Manu's FAQ; http://www.marinetex.com/Marine-Texf...r-Marine-44867
Is Marine-Tex Epoxy Putty resistant to gasoline and diesel?
Yes, Marine-Tex Epoxy Putty is resistant to gasoline and diesel.
Old August 5th, 2016, 06:21 PM   #10
Cra1g
Cra1g's Avatar
I did a quick search and $100 is about the cheapest I could find, and that's with dents and scratches. Might as well spend $20 and try to patch it up myself.
Old August 5th, 2016, 06:44 PM   #11
Cra1g
Cra1g's Avatar
Would it be easier to cut off the bolt mounting tab thing? It would give me much better access to the hole and I wouldn't really need to use a screw there anyway--the fairing would hold just fine without it.
Old August 5th, 2016, 10:05 PM   #12
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
here's how I fixed it, not easy but it's permanent and won't mess up the paint job.
https://www.ninjette.org/forums/showthread.php?t=176379
Old August 6th, 2016, 06:13 AM   #13
They shouldn't be. That's why it punctured the tank.
http://faq.ninja250.org/wiki/How_do_...l_tank,_etc%3F
"Warnings first, AND PAY ATTENTION
1. The bolts that go from the upper fairing into the gas tank are very size-sensitive.
We recommend using only OEM Kawasaki bolts in that application. On older bikes, if you used one of the bolts from the bottom in the top fairing hole, you would puncture the tank, making it leak gas and making you replace it. Late-model bikes SHOULD have bolts that are all equal length, but earlier ones had some that were longer than others. Be careful and organized. Certainly don't use anything longer than the OEM length of 6x18.
If you have some fairing bolts that are longer than others, replace them".
Old August 6th, 2016, 06:44 AM   #14
Cra1g
Cra1g's Avatar
That's understandable, but I wonder why all my bolts are the same lengths?
Old August 6th, 2016, 07:10 AM   #15
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Isn't that what the alcohol is for?
Old August 6th, 2016, 07:23 AM   #16
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Old August 6th, 2016, 07:57 AM   #17
Cra1g
Cra1g's Avatar
http://i.imgur.com/boKlrGS.jpg
Sanded it down mostly. Still going to attack it some to make sure I absolutely got it all, but it honestly didn't take that long using 150-grit sandpaper--maybe 10 minutes or so.
Old August 6th, 2016, 08:24 AM   #18
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Old August 6th, 2016, 07:22 PM   #19
Cra1g
Cra1g's Avatar
Alright, completely sanded down and cleaned. Ready for the epoxy stuff to get here on Monday..
Old August 6th, 2016, 08:54 PM   #20
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Replace the tank, repair the current one in your spare time for a back up.
Old August 6th, 2016, 09:50 PM   #21
Chocula
Motorcycle(s): Lots
Kawasaki issued a recall for this exact issue. It is likely you can get it replaced by your local dealer. At the very least, it is worth calling your dealer and talking to them about the issue. Have your VIN number handy and they should be able to look up the recall.
Chocula is offline   Reply With Quote
Old August 7th, 2016, 05:41 AM   #22
Cra1g
Cra1g's Avatar
I believe the 2007 model isn't included in the recall.
Old August 7th, 2016, 06:28 PM   #23
Chocula
Motorcycle(s): Lots
You can check your VIN at http://www-odi.nhtsa.dot.gov/recalls...l_ID=07V003000
Even if yours is not subject to the recall, it is showing the same problem as covered by the recall and I would be VERY surprised if Kawasaki USA would not cover this. Personally, I would be making phone calls and writing letters until they sent me a new tank. Of course it is your bike, you may choose to handle this any way you like.
The NHTSA shows the following models covered by this recall.
Vehicle Make Model Model Year(s)
KAWASAKI EX250F18 2004
KAWASAKI EX250F18L 2004
KAWASAKI EX250F19 2005
KAWASAKI EX250F19L 2005
KAWASAKI EX250F6F 2006
KAWASAKI EX250F6FL 2006
KAWASAKI EX250F7F 2007
KAWASAKI EX250F7FL 2007
Old August 8th, 2016, 10:55 AM   #24
Cra1g
Cra1g's Avatar
So my model is listed there, but when I went to check my VIN, it says there's no recalls.
Honestly, I'm not too determined about getting a whole new tank. I think the method that RacinNinja mentioned (and what I'm in the middle of doing) will do just fine.
Old August 9th, 2016, 05:08 AM   #25
Cra1g
Cra1g's Avatar
Applied the Marine Tex this morning and was fairly simple and straightforward. Now waiting 24 hours for it to cure! The anticipation is killing me..
Old August 9th, 2016, 11:34 AM   #26
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I'm trying to work on my patience... I want it now :rotfl:
Old August 10th, 2016, 02:33 PM   #27
Cra1g
Cra1g's Avatar
Epoxy stuff is cured and ready to go, so I filled the tank back up and will await to see if it leaks or not. Got a towel ready just in case..
Old August 11th, 2016, 07:44 AM   #28
JohnnyBravo
Looks great!
Old August 11th, 2016, 08:01 AM   #29
Cra1g
Cra1g's Avatar
I let it sit overnight and there were no leaks! So I'll start the process of putting everything back together.
I also found out that the four bolts that hold the radiator in place were all missing, which means it was probably just hanging by the hoses. Had to go to the hardware store to get new bolts. Not sure if the shop I took it to a while ago forgot to put them back on or what...
Old August 11th, 2016, 08:08 AM   #30
JohnnyBravo
Least it all sorted out!
Old August 11th, 2016, 09:38 AM   #31
You would think they would have at least caught it. What work did you have done at the shop?
Old August 11th, 2016, 10:01 AM   #32
Cra1g
Cra1g's Avatar
Carb clean/sync and valve adjustment.
Old August 11th, 2016, 10:46 AM   #33
Probably the shop then. If you are smart you put all of the fasteners from one area together in a tray so you know when everything you removed is replaced.
Figures. It's really hard to find a good Tech these days.
Old August 15th, 2016, 01:33 PM   #34
soonerbillz
Motorcycle(s): 2003 Ex250
So i have been down this path..
My permanent cure was to eliminate the chance of leaks by using the JB weld marine grade gas tank repair epoxy and filling the entire bolt hole and then before it cured screwing a stud into the hole. I then put a thin flange nut onto the stud with a bit more epoxy and tightened it down. Now my fairing is held on by another flange nut on the stud.. on removal only the nut comes off.. the stud stays put.
I can remove and install with no worries of punching a hole in the tank again...
Soonerbillz - Soonerbillz Racing News - Soonerbillz Trading Post
soonerbillz is offline   Reply With Quote
There's rust on dust on a frog on a log in the hole at the bottom of my tank MrAtom 1986 - 2007 Ninja 250R Tech Talk 12 January 9th, 2015 03:01 PM
Replacement gas tank only has one hole on the side? IF13 2008 - 2012 Ninja 250R Tech Talk 10 September 20th, 2013 11:17 AM
I'm Back w/Hole In Tank lowdown112 1986 - 2007 Ninja 250R Tech Talk 5 January 30th, 2013 12:06 PM
Fairing to tank bolt put hole in tank mhobie16 1986 - 2007 Ninja 250R Tech Talk 18 April 15th, 2011 01:23 PM
WTB: rust / hole free pregen gas tank CynicalC Items Wanted 9 April 15th, 2011 10:07 AM
