March 15th, 2011, 02:24 PM | #1 |
Aftermarket Drop in Type Air Filters
Anyone using an aftermarket Drop in Type filter with their stock airbox? Like to hear your actual results.
March 15th, 2011, 02:49 PM | #2 | |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
BTW it was a tight fit.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
March 15th, 2011, 03:00 PM | #3 |
March 15th, 2011, 07:57 PM | #4 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
Blue most show minimal gains but they do flow better. Will you notice a difference? Probably not. The plus side is having to not clean it as much.
Sportisimoto USA is born. |
March 15th, 2011, 10:27 PM | #5 | |
http://www.sportisimotorsport.com/jfc.php |
March 16th, 2011, 12:36 AM | #6 |
Bike is fine. Dont expect too much from a filter change and you wont be let down. You have to swap alot of aftermarket parts on your ride for this to make a noticeable change. On the flip side I think its better than the foam filter that comes stock.
March 16th, 2011, 05:38 AM | #7 |
Resident Old Guy
Pipercross is a sponser of 250R racing, and they have a good product.
Here's their website and review.... http://www.calsportbike.com/px/ http://www.newninja.com/forums/f98/n...lter-5556.html Just a note... My dealership warned me, that replacing the stock filter with an aftermarket variety would require some carb work, to correct the lean condition. So even the dealers acknowlege that the aftermarket replacement can be less restrictive. |
April 6th, 2011, 06:59 AM | #8 |
Join Date: Feb 2011 Motorcycle(s): 2010 Ninja 250R (for the weekend's) and the Suzuki Fiero for office commute. Posts: 80
I plonked this in and have ridden my bike for a little over 1000 miles.
I noticed that the exhaust pop's (stock can) when the bike is slightly revved up when in idle. Is the engine running lean? Is this a cause for worry? Should i go back to the stock foam filter? My ninjette is fuel injected and a 2010 model. I thought the ECU adjusts to compensate for more air that is flowing in. Am i right? Please help. |
April 6th, 2011, 09:42 PM | #9 |
Bump !
I'm slightly more paranoid about my baby than most other people. Please reply to my above post. |
April 6th, 2011, 09:46 PM | #10 |
hard to comment as most have carbs and not FI on their bikes, so not many with experience here to offer opinions on your problem.
do you happen to have a service manual that you can consult? |
April 6th, 2011, 11:23 PM | #11 |
no joy
Join Date: Nov 2009 Motorcycle(s): Ninja 2006 636 Posts: 408
I had a BNC airfilter before I jetted and put my 2bros exhaust _ backfired ect took it out and jetted put it in again and bike ran flawlessly_ but that was carbed bike_ but I'd assume with FI you'd atleast need an aftermarket exhaust...if the Ecu does auto adjust ?? "L
Posted via Mobile Device |
April 7th, 2011, 05:37 AM | #12 | |
Air Filters | 102dalz | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 18th, 2013 06:42 PM |
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2012 06:00 PM |
Fixing something thats not broken - Drop-in Air Filters | setasai | 2008 - 2012 Ninja 250R Tech Talk | 16 | October 9th, 2011 02:25 PM |
The truth about aftermarket air filters | mrlmd | General Motorcycling Discussion | 43 | September 23rd, 2010 09:12 AM |
Air Filters? | mista350z | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 29th, 2009 04:03 PM |
