Old January 3rd, 2014, 10:44 AM   #1
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
sonic fork springs
Just got mine in the mail today. I was wondering if the preload inserts are necessary? I'm curious what effect it has on the ride? I weigh 215 and trying out the .85 springs w 15w oil
Mods: Offset clutch pressure plate
Old January 3rd, 2014, 10:55 AM   #2
http://faq.ninja250.org/wiki/How_do_..._suspension%3F
Old January 3rd, 2014, 10:55 AM   #3
Lychee
sail away
Lychee's Avatar
Congrats on your upgrade. Yes the insert is required, unless you magically got a spring that is the exact length required. It is more likely you will want to use the insert, but cut it down so that the fork cap sits above the fork about half an inch, when measured at the oring vs oring groove with the fork fully extended. You can also measure the length of your stock spring and make the total length of your spacer plus sonic spring equal to that. If you have a valve emulator make sure you take that into account and make the spacer shorter.
Without the insert, and assuming your sonic springs were shorter than the stock springs like mine were, your suspension would need to compress the entire air gap before it would have any spring tension. For me that would have been more than 6 inches of extra sag.
Old January 3rd, 2014, 04:53 PM   #4
FvnnyL3tt3r1ng
Originally Posted by Lychee View Post
Congrats on your upgrade... You can also measure the length of your stock spring and make the total length of your spacer plus sonic spring equal to that.
Thanks! Can't wait to start riding again!!
Old January 7th, 2015, 05:12 PM   #5
agentbad
agentbad's Avatar
How were the springs? I am considering this upgrade since my front end hasn't been quite right since I upgraded my rear shock with one from the 300r. I was considering just going with heavier oil and seeing how that goes first. Maybe readjust my rear shock back down from 4 to 3 or 2.
Old January 7th, 2015, 05:32 PM   #6
Ghostt
Ghostt's Avatar
Spacers are to set sag with, which is extremely important to do.
personally save your money cut & space out the OEM springs afterwards. I've done this many times before, including my 500 & 250 both.
violente et ignorantia
ZX-2R BLOG
Old January 8th, 2015, 08:22 AM   #7
I would use them, but you could talk to Rick at Sonic Springs for expert advice.
Did you use their spring-rate calculator? .85 seems too light. 15W seems right though.
FS: Pregen : Fork Springs, Fork Clamp, Factory Pro Jet kit FvnnyL3tt3r1ng Motorcycle-related 20 February 24th, 2016 08:24 AM
NEW Sonic Springs 0.75 kg/mm for Ninja 250r / Ninja 300 1ER6F Motorcycle-related 5 May 31st, 2014 10:57 AM
Can fork springs be changed without removing the fork tubes? AlanDog 1986 - 2007 Ninja 250R Tech Talk 26 April 23rd, 2014 05:19 AM
Sonic Springs Thumbs Up! Finder 2008 - 2012 Ninja 250R Tech Talk 1 August 29th, 2009 12:52 AM
FS CO: Parts (Sonic Springs, Pre 08 Gauge Cluster, Tail Section) RMLegacy Motorcycle-related 0 August 10th, 2009 07:57 AM
