Old June 27th, 2015, 09:38 PM   #1
ninjagaiden09
ninjagaiden09's Avatar
Motorcycle(s): 2011 Ninja 250r
Koso Oil temp. sensor
Hi folks, I have a koso RX2 on my Ninja. I was changing the oil when I accidentally broke the oil temp sensor from the tip so only option have is to replace it. (No, I dont have the sensor installed where you drain the oil. I have it close to the bolt of the oil filter) Somehow when I was taking off the drain plug with a wrench the sensor cable got caught My question is can I still use the bike without it ? What is my option for replacement ? I tried Koso but it will take sometime to get it.
ninjagaiden09 is offline   Reply With Quote
Old June 28th, 2015, 06:37 PM   #2
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Provided you're not leaking oil, I see no reason why it wouldn't hurt. Just understand you have no visual cue to any oil pressure issues. From what I know of the bike, EFI not withstanding, no part of the system is relying on that sensor, you will probably have a constant light indicating oil pressure issue, when really, the sensor is not communicating to dash. Hope this helps.
Someone with experience on EFI bike chime in, OP from Toronto, Canada.
Old June 28th, 2015, 07:00 PM   #3
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@ninjagaiden09, since the Koso is accessory it shouldn't mean anything with only important that no oil is leaking.
@DmbShn41, why do you think the bike is EFI? As far as I know in Canada also the carbed version is sold, or did I miss anything?
Old June 29th, 2015, 06:16 AM   #4
ninjagaiden09
First, thank you for the info. Unfortunately I don't have the EFI version. In Canada it same in the US we have the carb version here.
About the bike, I was thinking the same thing too that it should be OK but better safe than sorry. I know that there are more members here that know more than me about the bike. Thanks again.
@Somchai : thanks for you response.
Old June 29th, 2015, 04:08 PM   #5
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Was thinking Canada=EFI. Thought only US got that punishment...
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
WTB: Pre-Gen Water Temp Sensor!! bluebr65 Items Wanted 3 January 5th, 2012 09:45 AM
WTB 08+ Water Temp Sensor charri Items Wanted 0 July 26th, 2011 07:05 PM
Where is the water temp sensor? wild-bill 2008 - 2012 Ninja 250R Tech Talk 2 December 24th, 2010 10:32 PM
How to test coolant temp sensor? Togglehead 1986 - 2007 Ninja 250R Tech Talk 1 July 21st, 2010 03:50 PM
