#1 |
Join Date: Jun 2009 Motorcycle(s): 2007 Kawasaki Ninja EX250 Posts: 13
Alternative rear turn signals?
After noticing that nobody makes clear lenses for the stock '07 Ninja 250 rear turn signals, I was wondering if I could put another bike's rear turn signals on it instead. I'd put them in pods, but I want to remain street legal. Does anybody have any suggestions of rear turn signals (with available clear lenses) what would look good on an '07 250?
EDIT: And to people that have integrated their rear turn signals into the pods, have you ever had a problem with law enforcement or getting your bike inspected? Last futzed with by virtualmatt; July 5th, 2009 at 03:43 PM. |
#2 |
Join Date: Aug 2008 Motorcycle(s): 2007 EX250 Posts: 133
Check this thread out:
http://www.ninjette.org/forums/showthread.php?t=16201 I added a couple of pictures at the bottom of a pair of new rear signals with clear lenses that I put on. Cleaned up the back of the bike and made more room for saddle bags should I choose to use them. |
#3 |
Those are pretty nice! They are pretty tiny, though. So you don't find there is a visibility problem?
Also, are those 9" apart (center to center)? If so, I may have to find a set of them ![]() |
#4 |
Matt - what leads you to believe that integrating into the pods would not be street legal? There are federal regulations that dictate what lighting on vehicles needs to be - and as long as your pods have a minimum reflective surface area, there's no reason why they wouldn't be legal unless you switch to red bulbs instead of amber. If you have questions about it let me know and I can find the link, but the only thing I can recall that might make the pods illegal was that there is a minimum distance of 9" from bulb to bulb on the turn signals IF they're the same color as the tail light, but if they're amber, then the minimum distance does not apply.
#5 |
Ah, I was given some bad information!
#6 |
Join Date: Apr 2009 Motorcycle(s): 2000 Honda CBR600F4 (sold) 1999 Ninja 250 (sold) Posts: 586
Im not a big fan of clear lenses on anything.. very ricey...
amber lenses in the rear pods look good.. I was going to do that as mine were relocated before I bought the bike.. bike teh red has grown on me.
2000 Honda CBR600F4 Silver and Red 1999 Kawi Racing Green Ninja 250 sold |
#7 | |
There is a table all the way at the very end (that I found after reading all through the rest of the garbage) that summarize everything:
http://frwebgate.access.gpo.gov/cgi-...2000&TYPE=TEXT basically it says this about rear signals: Quote:
#8 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
So does that mean that integrated signals aren't street legal? I've never had any problems with the police or anything because of my signals.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
#9 |
Legality of turn signals will vary from state to state. Check with your local DMV.
#10 |
Michael - as long as the center of the flashing part is 9 inches apart, then they are legal
John-Michael, that information is incorrect. These are FEDERAL DOT regulations and cannot be overruled by any state regulations.
#11 |
Here is a link to Texas DOT inspection requirements:
http://www.txdps.state.tx.us/vi/insp...ejectsubmit=Go Without proper inspection, bike is not legal per state law. That is why I brought up legality and checking with state specifics. Apparently, motorcycles in Texas are not even required to have turn signals. |
#12 |
I checked on motorcycle requirements in NM, and all it says is that turn signals are required. It doesn't say anything about placement or distance from each other.
#13 |
Michael - NM can't make those requirements as it is a federal guideline - otherwise a vehicle that is legal in one state wouldn't be legal in another
#14 |
Just measured. With integrated signals, it's approximately 8.5 inches from center of signal to center of other signal. Technically illegal, but I don't think they'll be too nitpicky. At least I hope not!
#15 |
well, the regulation I believe says 9 inches, not 9.0 inches - this is the one time that significant figures really are your friend! if it's 8.5" measured, it rounds up to 9 inches as stated in teh law
#16 |
Very nice!!!! I'm LEGAL!!!!
rear turn signals | bannr35 | 2008 - 2012 Ninja 250R Tech Talk | 28 | March 24th, 2014 07:52 PM |
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Rear turn signals don't blink, front turn signals don't turn on | andyuc88 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 23rd, 2012 02:47 PM |
