April 30th, 2011, 02:43 PM | #1 |
love to ride
Join Date: Apr 2010 Motorcycle(s): 2010 Kawasaki Ninja 250r Ebony/Candy Persimon Red Posts: 53
Could not open my fuel cap
2010 SE last week I was headed to work (45 miles away) and I had a little under a 1/4 tank of gas so I stopped to fill up for probably the 3rd time this year. My bike is garage kept and has not seen rain or been washed this year but when I went to open the fuel cap at the gas station it was almost like I was using the wrong key it would not open. I did not have enough gas to get to work and back home so I had to turn around and come home and take the cage to work.
I called the dealer on the way to work and he said that the pins/tumblers may be stuck on the gas cap lock. he told me to use graphite lubricant and slide the key in and out several times. This fixed the problem and I have not had trouble with it since. It was a ver concerning situation to find myself in but would have been much worse had I been on a long road trip away from home and not able to get home because of it. From this point forward I will be maintaining my ignition and gas cap with graphite lock lubricant on a regular basis. Just wanted to share incase anyone else has the same problem they will hopefully not freak out as much as I did. Gear up and ride safe |
April 30th, 2011, 03:16 PM | #2 |
I find graphite based lubes a mess and have taken to lubing all my switches and lock mechanisms with a teflon based lube called Tri-flow.
April 30th, 2011, 05:23 PM | #3 |
Join Date: Jul 2010 Motorcycle(s): '10 Ninja 250 Posts: 221
Thanks for the heads up. Something else to add to my shopping list.
April 30th, 2011, 05:52 PM | #4 |
April 30th, 2011, 06:00 PM | #5 |
it might... never tried it, but when I compare the Dupont to the Tri flow, the Tri flow leaves almost no extra white stuff, dries clear and, to me, helps parts slide together really well and covers for a reasonable amount of time.
The Dupont, however, is a much better than the Tri flow when used as a chain lube. Try the Dupont in your locks switches and see how it does. The graphite based lubes leaves a nasty black residue on the keys and while it may not seem like a problem, try getting some on your hands or clothes. |
April 30th, 2011, 06:02 PM | #6 |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
Did you try pressing the cap down while turning it, before you lubed it. Sometimes it helps to do this.
Gas cap won't open | Lvr | 2008 - 2012 Ninja 250R Tech Talk | 33 | February 14th, 2017 07:32 AM |
Gas cap won't open | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 27 | December 16th, 2013 09:16 PM |
Fuel cap whistling | Th3 Grumpy Gnome | 2008 - 2012 Ninja 250R Tech Talk | 9 | January 19th, 2011 07:17 PM |
Aftermarket fuel cap | randomwalk101 | 2008 - 2012 Ninja 250R Farkles | 3 | January 7th, 2010 11:18 AM |
fuel cap issues | nate-bama | 1986 - 2007 Ninja 250R Tech Talk | 10 | June 18th, 2009 06:16 PM |
