Old June 18th, 2012, 02:09 PM   #1
sageninja
Motorcycle(s): None Yet
Ninja 250+Motorcycle.Hitch.Trailer.Carrier ???
anybody ever try this? or seen it done with a newgen ninjette?
or anyone suggest not doing this for any reasons?
i know strapping it down can be a bit of a bear and adding that much weight to the back of a vehicle hinders handling... but besides that. were all good right?
lol
sageninja is offline   Reply With Quote
Old June 18th, 2012, 02:22 PM   #2
i've seen it done before, but it looks sketchy to me.
Old June 18th, 2012, 02:35 PM   #3
Whiskey
(about it lookin sketchy)
A normal bike trailer or in the back of a van & properly tied down would be my suggestion if you're bringing a bike somewhere & can't ride it.
That may work, but I wouldn't trust it, at least without seeing it in the flesh & inspecting it's mounting system
Old June 18th, 2012, 02:42 PM   #4
flynjay
flynjay's Avatar
I've done it with my pregen. Yes it was a little sketch, not because I was afraid of it falling off but usually hitches have a little rotational play in them and that causes excessive movement of the carrier.
I have friends that do that with dirtbikes all the time.
Usually those carriers can only be used with a class 3 or higher hitch which can handle a 500 lb tongue weight.
Old June 18th, 2012, 05:53 PM   #5
A poster from here awhile back dropped their ninjette off one of those while loading/unloading. If you have the vehicle to support it and the hitch is solid, there's no reason it absolutely won't work; but it seem that there are any number of simpler options (folding trailer, get a truck with a bed, closed trailer, etc.)
Old June 19th, 2012, 03:11 PM   #6
NJ Ninjette
NJ Ninjette's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r
Yeah, and with my 250 lb dirt bike it looks scary as hell flopping around...I'll pass putting my Ninja on there. I have a 3 rail bike trailer I've been thinking about pulling out of retirement anyway.
NJ Ninjette is offline   Reply With Quote
Old June 19th, 2012, 04:49 PM   #7
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Buy a harbor freight trailer if you're on a budget. But don't let Zombiephone tie it down for you. Her bike was almost falling off the trailer, and I heard to get her attention Kit & Shane had to run her off the freeway cuz she was too busy jammin' to some heavy punk metal devil worshiping music.
Damn devil worshipers!
Old June 20th, 2012, 12:20 AM   #8
n4mwd
n4mwd's Avatar
I just hauled a Ninja and went with a $15/day uhaul motorcycle trailer. It worked really well and has an easy load ramp and is made specifically for motorcycles. It took about 5 minutes to load and strap it in.
I considered a harbor freight trailer, but the reviews say they're junk. Plus you have the problem of registration and storage when not in use. Unless you use it at least twice a year, its really not worth having.
Those bike carriers are probably fine for lightweight bikes, but I personally wouldn't put anything as heavy as a Ninja on there.
My Ninja Blog
Old June 20th, 2012, 03:26 AM   #9
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
it would be ok because most towing weights for a
sedan is 120 to 160kg
average 4x4 200 to 240kg
friggin house of an ford f truck or american gmc etc 250kg+
ps aussie spec cars
ninja250r81 is offline   Reply With Quote
Old June 20th, 2012, 05:01 AM   #10
n4mwd
n4mwd's Avatar
The problem isn't the weight, its the rocking motion. Hitches are designed to pull a load with a certain amount of weight on the tongue. Rocking motion causes fatigue which will eventually cause the carrier to fail.
However, a friend of a friend modified one to have two outriggers on the ends to prevent rocking. With something like that, I don't see why it wouldn't work.
My Ninja Blog
Old June 20th, 2012, 06:04 AM   #11
Palero
Palero's Avatar
Motorcycle(s): 1988 Honda Hawk GT 1989 EX250F (Died from left-turning car) 2011 EX250J (Died from SAME left-turning car)
lol
I was looking into those.
I wanted one to not have to transport to the track at 55MPH (CA fuel or emissions rule)
From what I understand, you'll need at least a Class III hitch for that!
Cars usually have a class I hitch which has a 150 to 200lbs tongue weight and a 1500 to 2000.
http://en.wikipedia.org/wiki/Tow_hitch
Looking to take some motorcycle classes this Summer?
Palero is offline   Reply With Quote
Old June 21st, 2012, 02:41 PM   #12
lostdaemon
lostdaemon's Avatar
Motorcycle(s): 2009 Ninjette
I saw someone hauling a full dress cruiser on the freeway around 90mph on one of these - it bounced around a bit, had me a bit freaked out to be behind it. The vehicle hauling was an extended cab super duty truck though, so I would hope it was built for that sort of thing?
lostdaemon is offline   Reply With Quote
Ninja 250 on a motorcycle carrier using a 2" hitch receiver jaesun General Motorcycling Discussion 15 November 20th, 2014 11:29 AM
Hitch Mounted Motorcycle Carrier BlueRaven General Motorcycling Discussion 69 October 4th, 2011 06:46 AM
