Old May 9th, 2017, 08:30 AM   #1
Soundtrackzz
Motorcycle(s): 2003 Ninja 250
Oil leak
Hey all. I'm having an issue where my bike is leaking a little bit of oil everytime I ride it. I had a similar issue caused by the wrong size crush washer last year. This year I already tried replacing it with a new one to no avail. I've attached some pictures. I've noticed drops of oil on the drain plug, the oil filter nuts and on the lines that run near the shifter(sorry I don't know what they're called). Any help would be appreciated. What's the easiest way to find an oil leak?
Soundtrackzz is offline   Reply With Quote
Old May 9th, 2017, 08:40 AM   #2
Clean it up good with some engine degreaser, scrub brush, soap, water, whatever it takes, then watch carefully for a leak. You may see it right away, or you may have to idle it in the driveway, or you may have to ride it a mail, pull over, and look. Puffing some talcum powder in the area after you clean it can help spot the very first seepage, but you may not need it.
Old May 11th, 2017, 03:09 AM   #3
Soundtrackzz
I've discovered that the leak is coming from the drain plug. As I said previously I've already replaced the crush washer about a week ago so I don't know why it would be leaking. Do I need to use more torque than the 14.5 ft/lb for a new crush washer. Should I get an all new drain plug? Should I use thread tape like on a household fitting? Any thoughts?
Old May 11th, 2017, 05:25 AM   #4
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Thread tape is for "pipe" thread. Pipe threads are tapered so they get tighter as they are screwed together, if you put tape on straight threads you could (and probably will) get tape in the oil pan. Check the mating surfaces of the pan and the drain bolt (where the crush washer fits) to be sure they are clean and no nicks in them. I've had luck on cars by cutting a washer out of a plastic jug (antifreeze or milk jug or whatever) to get a seal on roughed up surfaces.
Old May 11th, 2017, 06:29 AM   #5
I had a problematic drain plug on one of my bikes, and ended-up getting a fiber washer from Ace Hardware to use instead of the original washer. The original aluminum crush washer leaked, was deformed, and was an odd size that I couldn't find. The fiber washer seemed to be doing the trick.
Be careful you don't really crank on it. Fixing stripped threads could be a real pain.
As noted above, thread tape wouldn't cure the problem and might cause other problems.
Old May 11th, 2017, 06:29 AM   #6
I've started using Parker Stat-O-Seals for those washers on my motorcycles. They have a rubber insert that seals without relying on squashing a metal washer, and they can be used multiple times. One place to buy them is McMaster-Carr, and the M12 size is McMaster-Carr part number 93786A200. You can plug that into www.mcmaster.com to see what it is.
They're only $1.50 each, but at McM you have to buy 10, and then pay shipping. You may find another source for getting a couple that's cheaper. Luckily I buy from McM regularly, so I just added a pack to an order.
Generic search phrases would be something like "m12 seal washer" or "m12 stat-o-seal"
Old May 11th, 2017, 06:34 AM   #7
I've never seen those before. I added it to my next order.
Should cure most any sealing problem.
Old May 11th, 2017, 06:50 AM   #8
You can use them on brake banjos too. Just watch material/fluid compatibility. Parker has a bunch of different versions.
And Jay, you might find them useful in 2-stroke oil injection systems. They're popular on Kawasaki triples to replace the aluminum crush washers on the oil line banjos. Kawasaki combined crush washers with soft cast aluminum threads, and half the Kaw triple oil banjo threads in the world have been stripped by now.
Old May 11th, 2017, 11:14 AM   #9
Ram Jet
Ram Jet's Avatar
I have the same problem. The previous owner had over-tightened the drain plug and may have damaged the seat where the crush washer seats. I'm going to install a nylon washer in place of the copper crush washer. I haven't tried it yet but it's worked for me in the past.
Bill
Still got this oil leak!! xXecuterXx2 1986 - 2007 Ninja 250R Tech Talk 11 August 11th, 2015 11:56 PM
Oil leak.... skilletmo 2008 - 2012 Ninja 250R Tech Talk 13 October 24th, 2014 09:31 PM
Oil Leak? Fakker 1986 - 2007 Ninja 250R Tech Talk 5 September 6th, 2013 06:38 AM
Oil Leak thisisbenji 2008 - 2012 Ninja 250R Tech Talk 10 December 12th, 2012 06:59 PM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
