March 25th, 2015, 02:30 PM | #201 |
Fighting Texas Aggie '05
you can, but they are not particularly cheap
March 25th, 2015, 02:40 PM | #202 | |
March 25th, 2015, 02:44 PM | #203 |
went back to the dealer today. it was pretty empty. asked them about the R3... "r1?" ... "no r3." ... "the r1 is the biggest yamaha we have. but we don't carry any H3s right now. we're getting more R1s in next month though" ... "... no.... the R3... the little one." -- "sorry man i donno."
WTF YOU SELL BIKES FOR A LIVING AND YOU DONT KNOW WHAT AN R3 IS?!
March 25th, 2015, 03:46 PM | #204 | |
The reason adding preload in this case is 'willy nilly' is because you're throwing adjustments at a problem, despite not knowing what you're doing. I call that willy nilly because it's just taking shots in the dark. Preload does nothing for the stiffness of the front end because the spring rate and damping rates have not been changed. Knowing Ben's track habits, I'd bet he's not looking for sag adjustment. Keep telling yourself that preload adjusters will make the front end stiffer for riders who are 160lbs or more; that doesn't make it any more right. Put a heavier rider on a bike with preload and you're still going to get a diving nose under braking and a front end that mushes in corners. Sure it will ride the right height, but it won't be any firmer. TL;DR Don't suggest preload to correct a soft front end. |
March 25th, 2015, 05:09 PM | #205 |
speaking of, @choneofakind, when are you going to lathe me those cartridge emulators!!
March 25th, 2015, 05:10 PM | #206 |
Who'da whata what? hahaha ummmmmmmm no promises? hahaha
March 25th, 2015, 05:42 PM | #207 | |
Just cause it's new to US market, doesn't mean it's completely new.
My replies are intended for street riding only, plz do not provide track only replies. Visit my new MotoVlog Channel !! |
March 25th, 2015, 07:38 PM | #208 |
Private Joker
MOTM - Mar '14
That's what I did, but it's nice to be able to be incredibly lazy and get away with it
March 25th, 2015, 09:45 PM | #209 |
Join Date: Jan 2015 Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold. Posts: 338
That doesn't sound reassuring...
Screw the inscrutable, eff the ineffable. |
March 25th, 2015, 09:48 PM | #210 |
Track Clown
MOTM - Sep '15
seriously a slipper clutch for a 300 cc motorcycle?!?! Who cares!
March 25th, 2015, 10:40 PM | #212 |
Join Date: Jun 2013 Motorcycle(s): N650 (and others) Posts: 408
Just read up on slipper clutch -- actually I'd prefer engine breaking for around town riding! I had a turbo car that had minimal engine breaking, what a pita always having to break for even minor deceleration.
March 25th, 2015, 10:40 PM | #213 |
cadd cadd cadd
MOTM - May '15
CNET review
http://www.cnet.com/products/yamaha-yzf-r3-2015/ |
March 26th, 2015, 12:12 AM | #214 |
cadd cadd cadd
MOTM - May '15
March 26th, 2015, 06:00 AM | #215 |
I don't understand your logic w/ this one.
March 26th, 2015, 06:17 AM | #216 |
Freedom for Germany
March 26th, 2015, 06:22 AM | #217 |
Ahhh I didn't even notice my screw up...haha
Still same thing as Kawi did w/ the 250 to 300, so that's why I didn't get it.
March 26th, 2015, 02:23 PM | #218 | |
March 26th, 2015, 02:26 PM | #219 |
Track Clown
MOTM - Sep '15
depending on your weight, proper spring weight will fix sag, if you are heavier for stock springs, then stiffer springs will fix it.
March 26th, 2015, 02:29 PM | #220 | |
Cast aluminum wheels. Wow. I'll have to try one this summer. |
March 26th, 2015, 02:45 PM | #221 |
cadd cadd cadd
MOTM - May '15
Dyno numbers for all 4 bikes. Except for the CBR, each bike best each other by 3HP.
http://www.motorcyclistonline.com/20...ison-dyno-test |
March 26th, 2015, 03:15 PM | #222 | |
the point of suspension is to move. you have a limited amount of travel in your suspension. there's no point having as much as you do if you never use it. setting the correct spring rate means your bottom outs- the max force that spring will take on braking before the bike flips- comes as close to but doesn't go past your bottom out length. this doesn't necessarily set the correct sags in fact with a correct spring rate for bottom out most of the time its not the correct sag.. which is what setting preload is for. now mind you preload only adds initial pressure to the spring so your actual spring rate needs to be lower than what you want to wind up with so you can add a bit of preload. because without preload or some amazing perfectly lengthed spring (not gonna happen) you get a small amount of play at top out. anyway, you get the 1 rate lower spring and add some preload until the weight of the bike settle the suspension to your desired sag
March 26th, 2015, 05:43 PM | #223 |
^^^ werd.
...and suggesting that someone add preload to stiffen the front is still wrong. Isn't the ignore list a wonderful feature? |
March 26th, 2015, 06:39 PM | #224 | |
Freedom for Germany
Sorry, I'd take the wrong sheet for my calculation so it was wrong. I promise you not to post anymore before I'd trink my coffee |
March 26th, 2015, 06:46 PM | #225 | |
Track Clown
MOTM - Sep '15
March 26th, 2015, 07:01 PM | #226 | |
Private Joker
MOTM - Mar '14
honestly it's unnecessary on anything other than a racing bike and even then it's not needed since someone who's racing *should* know how to blip the throttle for downshifts while braking. Engine braking is when the clutch is engaged (disengaged?) and you just roll off the throttle to brake
March 26th, 2015, 07:03 PM | #227 | |
Private Joker
MOTM - Mar '14
luckily the sizing matches up with old r6 stuff so someone clever may be able to head over to their local used parts warehouse and get some forks + a shock that fits for all the adjust-ability they'd ever reasonably need.
March 26th, 2015, 07:05 PM | #228 |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
The shape of the power curve means far more than the peak numbers.
That Duke makes 4 more hp than the rest of the world is getting, trying to find motorcyclist online or USA market dyno of it? KTM claim 43hp, tuned RC390 street versions put out 36-37 (A mate has a well sorted one) maybe its the Euro A2/ Au Lams spec that brings ours down. http://www.indiancarsbikes.in/wp-con...yno-Pull-1.jpg and http://www.team-bhp.com/forum/attach...0-imag0761.jpg |
March 26th, 2015, 07:17 PM | #229 | |
Track Clown
MOTM - Sep '15
March 26th, 2015, 07:20 PM | #230 |
The A Team
March 26th, 2015, 07:21 PM | #231 | |
Private Joker
MOTM - Mar '14
Honestly I see it as a bad thing, it allows me to get into lazy/bad habits
March 26th, 2015, 07:32 PM | #232 |
Track Clown
MOTM - Sep '15
Have you ever seen anyone back a motorcycle into a corner? Down shifting changes the engine to speed up faster then what the rear tire is rotating causing lock up, many riders use that as a way to slide the rear around the corner. watch Moto2, specifically Lowes going into turn one. |
March 26th, 2015, 07:32 PM | #233 |
Track Clown
MOTM - Sep '15
It will definitely smooth out little mistakes that could high side a guy on a liter bike w/o the slipper.
March 26th, 2015, 07:34 PM | #234 | |
Private Joker
MOTM - Mar '14
I've even been complimented for it at the track while being coached at mid-o. Then again I'm sure those coaches see tons of guys who don't even blip the throttle
March 26th, 2015, 07:56 PM | #235 |
you adjust the spring rate the same as any other bike. by replacing the springs.
March 26th, 2015, 09:07 PM | #237 | |
The A Team
learn to match your revs. Slippers are great on 600's with a massive rev range, for the very best of racers, but like ABS, its the last thing needed on a 250. |
March 26th, 2015, 09:10 PM | #238 |
Track Clown
MOTM - Sep '15
so we're going to do this.
March 26th, 2015, 09:15 PM | #239 |
Track Clown
MOTM - Sep '15
that isn't rear brake.
March 26th, 2015, 09:25 PM | #240 |
Track Clown
MOTM - Sep '15
[motorcycle.com] - 2014 EICMA: 2015 Yamaha YZF-R1 and YZF-R1M Preview | Ninjette Newsbot | General Motorcycling Discussion | 20 | November 6th, 2014 07:03 PM |
[motorcyclistonline] - 2015 Yamaha YZF-R1 and YZF-R1M Unveiled At EICMA | Ninjette Newsbot | Motorcycling News | 0 | November 3rd, 2014 06:40 PM |
[motorcycle.com] - 2014 Yamaha YZF-R1 and YZF-R6 Race Blu Unveiled | Ninjette Newsbot | Motorcycling News | 0 | August 30th, 2013 05:50 PM |
[roadracingworld.com] - Yamaha YZF-R1 And YZF-R6 Coming Back In "Variety Of New And E | Ninjette Newsbot | Motorcycling News | 0 | September 12th, 2012 05:20 PM |
[roadracingworld.com] - Yamaha YZF-R1 And YZF-R6 Coming Back In "Variety Of New And E | Ninjette Newsbot | Motorcycling News | 0 | September 12th, 2012 12:50 PM |
