Old April 28th, 2011, 04:13 PM   #1
tjb0012
Motorcycle(s): 2009 SE Ninja250r
Question Low idle question.
After reading all of the info about the 2008 250r sometimes running too low of an idle speed, I noticed that mine runs right around 1000 rpm and I believe that it needs to be increases a few hundred... I sometimes fell as though the bike wants to die at a stop light.. its just hasnt yet.
I plan on shimming my carb needles soon and removing the snorkel. but for now should I use the idle adjustment knob to increases idle rpms or wait until i shim the carbs and remove the snorkel then adjust the idle with the idle mixture screws while i have the fairings off. Thanks
tjb0012 is offline   Reply With Quote
Old April 28th, 2011, 07:31 PM   #2
use the idle adjustment knob... that's what it's for.
http://www.ninjette.org/forums/showp...55&postcount=5
Old April 28th, 2011, 11:02 PM   #3
tjb0012
Thanks kkim I appreciate the knowledge
Old May 4th, 2011, 03:56 PM   #4
sarapacman99
Climb to Glory!
sarapacman99's Avatar
Motorcycle(s): 2011 Kawasaki Ninja 250R White (sold)
would this also fix it if when at a stop light like it takes time for my ninjette to move? twice this morning at stoplights, my ninjette died and i had to re-do
I wanted to become Kamen Rider as a kid.
sarapacman99 is offline   Reply With Quote
Old May 4th, 2011, 03:58 PM   #5
first, what is your idle speed set to?
Old May 4th, 2011, 07:17 PM   #6
sarapacman99
Climb to Glory!
im a real motorcycle noob, i dunno what it's set. i guess factory defaults? but i idle at a stop light on 1st gear at 1500 RPM. hope that helps.
Old May 4th, 2011, 08:54 PM   #7
1500 is about right.
so, can you explain a bit more by what you mean by "it takes time for my ninjette to move" and "twice this morning at stoplights, my ninjette died".
Old May 4th, 2011, 08:56 PM   #8
sarapacman99
Climb to Glory!
now that i really think about it, i let go of the clutch lever too soon. i guess putting more miles in that bike will fix that problem of mine
Old May 4th, 2011, 09:00 PM   #9
being smooth with the clutch plus knowing where the "friction" zone is, is very important to ride any bike smoothly.
I suggest you go to an empty parking lot and practice stop and go exercises until you are very familiar with where your bike's friction zone is. You can tweak the clutch lever a bit if the zone feels too far in or too far out for your liking.
Old May 4th, 2011, 09:02 PM   #10
sarapacman99
Climb to Glory!
for me it feel's too far out. what tweeking can i do to it?
Old May 4th, 2011, 09:09 PM   #11
take a look at this DIY. It shows you how to unlock the adjuster and turn the cable adjuster in or out to adjust the clutch lever. when you get it where you want, lock it back up. you can't adjust it very much w/o getting out of spec, but a quarter to half a turn will significantly vary the clutch lever position/distance from the bar. see if that helps.
http://www.ninjette.org/forums/showthread.php?t=10016
Old May 4th, 2011, 09:17 PM   #12
sarapacman99
Climb to Glory!
thanks ive now been officially blessed with the knowledge of kkim. i will put this on my to-do-list for my bike
Old May 4th, 2011, 09:32 PM   #13
I doubt if "blessed" is the correct word for it... more like "cursed".
Old May 5th, 2011, 08:15 AM   #14
vkuchhal
vkuchhal's Avatar
Motorcycle(s): ninja 250r -2010
Does low Idle , creates any problem to the engine..
My Idles at 900 to 1000k since a long time... but never at any stop or when i start the engine, it never gives any problem...
Please advise...
vkuchhal is offline   Reply With Quote
Old May 5th, 2011, 08:58 AM   #15
setasai
setasai's Avatar
Please advise...
The low idle doesnt really cause a problem. It just makes it so that you need to either feather the clutch out more smoothly or give it slightly more throttle. Is there a reason why you run it so low? Factory specs 1300 +/- 200ish. If i'm not mistaken, if you like it there, I dont see a problem with it.
Old May 5th, 2011, 11:47 AM   #16
I think oil pressure is directly related to how fast the engine turns. I would be concerned about not enough oil pressure if the idle got too low.
I have my idle speed to 1500 rpm.
Old May 5th, 2011, 11:53 AM   #17
Buffalony
Buffalony's Avatar
pay attention to what gear your in
Old May 5th, 2011, 01:59 PM   #18
ricochet08
ricochet08's Avatar
Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D
Am i the only one that has a habit of counting my gears? like....all day...everyday? I even count other biker's gears if we pull off together
I have issues
ricochet08 is offline   Reply With Quote
Old May 6th, 2011, 09:34 AM   #19
Buffalony
Buffalony's Avatar
I have issues
LOL.Count others gears huh? I'd love to have an indicator.
Last futzed with by Buffalony; May 6th, 2011 at 09:34 AM. Reason: LOL
Old May 6th, 2011, 10:09 AM   #20
fyv0h
fyv0h's Avatar
Motorcycle(s): 2008 250r, of the blue variety (bestowed to Ninja_Duck22), 1998 CBR Smokin' Joe
Yep, noob here. First post goes straight to the techies. My 2008 idles mad low also. 800 would be a reasonable guess. So I grab the knob to adjust idle, and it will turn down all day long, but that 800rpm is as high as it'll go. What gives? I'll stall on a rare occasion at stoplights when idling. When it stalls, it can be hard to restart. It might catch quickly, but may die as soon as it thinks I might touch the throttle. Other times the starter might need to spin for 5 seconds. I *think* someone has been into the carbs before. The previous owner said he "jetted the carbs." I didn't see it happen, so It may be true, or may had been a overstatement to make it more sellable. It does have a two bros exhaust. Bike runs fine, except that minor idle issue. Any ideas???
Last futzed with by fyv0h; May 6th, 2011 at 10:10 AM. Reason: I was a hasty typer
fyv0h is offline   Reply With Quote
Old May 6th, 2011, 01:31 PM   #21
welcome, jesse.
it sounds like the idle speed adjuster cable has come off at the bracket down by the carbs. take a look at this and see if it helps.
Old May 6th, 2011, 06:39 PM   #22
fyv0h
fyv0h's Avatar
Thanks, buts I'm not certain that's the issue. You see, I can't turn the knob to make the idle increase. It doesn't budge up. And I checked again, but I was mistaken in that it won't adjust down either. Are these things impossible to turn? I feel like my giant sausage fingers are going to snap the knob.
Old May 6th, 2011, 06:50 PM   #23
sounds like that adjuster is bound up somewhere. try spraying the end of the cable down by the adjuster with some wd40 and see if it loosens things up a bit enough to get it working again. If that doesn't work, either the adjuster cable is frozen inside the cable sheath or the portion where it threads into the adjuster is stripped/cross threaded.
try the easy stuff first and spray the end with some wd40.
Low and bouncing idle... archaeofreak 1986 - 2007 Ninja 250R Tech Talk 10 January 17th, 2015 11:00 AM
Low idle , high choke, shim needle help ! Noobman 2008 - 2012 Ninja 250R Tech Talk 13 June 6th, 2013 05:48 PM
Rough and Low Idle RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 4 March 26th, 2012 07:52 PM
Really low idle speed when starting??? HELP!! Ktaylor07 2008 - 2012 Ninja 250R Tech Talk 3 October 17th, 2011 09:57 PM
Low idle, not sure why Suave 2008 - 2012 Ninja 250R Tech Talk 9 September 11th, 2011 10:12 PM
