April 2nd, 2017, 10:41 AM | #1 |
Join Date: Nov 2016 Motorcycle(s): 2005 ninja 250 Posts: 74
Weird issue
I was sitting at a stoplight yesterday and all of a sudden my bike shut off and wouldnt start again. Once I let it sit for about 2 minutes it started back up again. I noticed that after it died, I had a little bit of black smoke coming out of the tailpipe of the bike. Has anyone ever had this issue or have any ideas?
April 2nd, 2017, 10:50 AM | #2 |
Black smoke indicates too much fuel. I wonder if one of your carburetor's float valves stuck open.
April 2nd, 2017, 10:54 AM | #3 |
April 2nd, 2017, 12:01 PM | #4 |
Join Date: Jan 2016 Motorcycle(s): 1994 GN 125, 2004 EX 250 Posts: 10
Sometimes, just a small piece of microscopic debris can lodge itself right where it needs to be to cause a float needle valve to stick open. This happened to me a few times, and the problem corrected itself shortly afterwards.
April 2nd, 2017, 12:50 PM | #5 |
Right Zachary. That's one of many reasons I always install an inline pleated paper fuel filter between the gas tank and carbs.
Sometimes you can get it unstuck by shutting off the fuel and running the carbs dry, then starting over. That causes the floats to make a complete cycle down and back up, which can let the dirt get on through. Of course you have to be able to keep the engine running to run the carbs dry. |
Weird issue with manual turning. | Nickyt2289 | 1986 - 2007 Ninja 250R Tech Talk | 21 | March 15th, 2017 04:40 PM |
weird oil leak issue..fixed last problem | garyg199 | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 16th, 2016 12:09 PM |
weird voltage/no start issue | thedrewski86 | 2008 - 2012 Ninja 250R Tech Talk | 8 | April 16th, 2014 09:47 PM |
Weird noise and shifting issue | tony7kp | 2008 - 2012 Ninja 250R Tech Talk | 1 | October 14th, 2012 01:40 PM |
Really Weird carb Issue need more trouble shooting ideas | Virustech | 1986 - 2007 Ninja 250R Tech Talk | 11 | September 24th, 2012 06:35 PM |
