February 18th, 2014, 11:29 AM | #1 |
Join Date: Jan 2014 Motorcycle(s): 2009 Ninja 250R (Sold), 2007 SV650S Posts: 161
Not really a crash but it got tipped over
Someone from work backed a van into my bike and tipped it over onto my exhaust side.
The manager came out and gathered my information and also has insurance so it's not too big of a deal BUT a small oil drip started..not sure where it's coming from and that's my primary concern. Cosmetic stuff is not too big of a deal. I'm not sure where the drip came from but i thought i'd ask in case this is something that occurs when the bike is tipped over. luckily i had installed frame sliders 2 weekends ago. Sucks that the sliders were used when i wasnt even on the bike, but they held up well. Some pics attached: did some research and it looks like a leak can occur after getting tipped. i'll have to check on it during lunch to see if anything else comes out. Do insurance companies replace or repair scuffed fairings? If my exhaust got pretty badly scuffed do they replace the whole thing? |
February 18th, 2014, 06:00 PM | #2 |
Join Date: Feb 2014 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 42
Try to take out the Right hand side Fairing, and inspect Closely the following:
Engine Seals oil Cap any Sign crack in the engine Block or From the sides I'm not an Expert But i would Check For those Types of Sign |
February 18th, 2014, 06:26 PM | #3 | ||
Check the frame. If there is even a small nick on the frame and the insurance adjuster sees it, they're going to write off the bike. |
February 18th, 2014, 06:32 PM | #4 |
damn what if it's a two brothers exhaust? That would really suck if they wont replace that for me.
it looks like besides the extremities like the bar ends and lever, mirror, and the side of my exhaust nothing else touched the ground. seems like it fell directly onto the frame slider. |
February 18th, 2014, 08:20 PM | #5 | |
It's good that the frame slider did its job; the shattered windscreen makes the damage seem a lot worse than it most likely is. However since the accident wasn't your fault, a lot of it is going to be up to you / your insurance company to make sure the other party makes you whole, whether that's fixing the bike up or cutting you a check. You'll want your representative to be as thorough as possible, ask for a mechanical inspection to be safe and get all the parts replaced. The underlying point is that since these little bikes are cheap and replacement parts tend to be relatively expensive, there could be a point where the insurance company would rather write the bike off and cut you a check. You can a) take the full payout, b) take the bike back with a salvage title and partial payout or c) not take the payout and demand the bike be fixed. Just be thorough, document everything, weigh your options carefully and don't make any rash or emotional decisions. |
February 18th, 2014, 09:09 PM | #6 |
MOTM - Mar '13, Jun '14
That bike looks brand new (except for the crashed parts).
February 18th, 2014, 10:22 PM | #7 | |
i'm pretty certain the oil came from that airbox tube. nothing else was on the ground after i moved the bike a little. it only has 51xx miles on it now or something rather. I did get it for a premium as far as ninjas go (socal ninjas are so expensive ) but i liked the mods it came with lol. If i had gotten an unmodified ninja any cheaper, the mods i would've done would bring it close. |
February 18th, 2014, 10:36 PM | #8 |
Private Joker
MOTM - Mar '14
I feel like you may end up in the situation where an insurance adjuster wants to write off the bike. My reasoning for this is the oil leak, an insurance adjuster looks at that and just goes "well ****, this'll cost us a good deal of money" after seeing the cosmetic stuff in addition to that. If you have any frame damage it's an instant write up. If it's a write up situation make sure that you get refunded for all of your aftermarket modifications, namely the two brothers exhaust you have on there.
February 19th, 2014, 05:17 PM | #9 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
I lowsided at a low speed back in October and when I picked my bike back up it was leaking oil. It was also on the right side. It dripped for a couple of days and then stopped. That was four months ago and it hasn't leaked since. But my bike was running when it hit the ground and yours wasn't, I'm not sure if that makes a difference but... I wouldn't freak out too much yet. A couple other friends of mine whose bikes have been down on the right side have leaked oil shortly after, but then stopped.
Also, my fairings were trashed. The insurance adjuster literally asked me if I wanted my bike to be totaled or not, and when I said no, he wrote up the cost of the parts that he would pay me for and omitted other things as 'pre existing damage' which would fly on my bike 'cause it's a 1999 and there are scratches all over it so he wouldn't know what's new or not. I don't know if this will work for you. But it's worth telling your claims adjuster that you DON'T want your bike totaled. The insurance company has to give you more money if you total your bike, after all... Good luck, let us know what happens. |
February 19th, 2014, 05:44 PM | #10 |
Thanks for all the responses.
it leaked again later that night after riding but i wiped it down more and it hasnt leaked since. I too think it's just something that can happen when the bike is tipped over--oil goes into places that it normally doesnt go. I havent been able to contact the other party's insurance so i notified AAA just so they know. If I decide to go with them i can just take it to a shop of my choosing and let my agent know. They'll waive the deductible and in previous times with my cars they go after the other party's insurance in my stead. damn..i'm planning on taking it on a trip to SD this weekend..should i just drive and leave the bike alone until i can take it to the shop? Lest i crash on it during this process..rode it into work without the windscreen. i would prefer not to have this totalled because it's a very clean bike (or was) and there aren't any ninja 250s like it at the moment on the market. Unless of course somehow the other insurance cuts me a large enough check to get something. |
February 19th, 2014, 10:48 PM | #11 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Some insurance companies cover accessories.
February 20th, 2014, 09:51 AM | #12 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
MY insurance requires me to pay an additional coverage charge for any after market or modifications. Its about 32$ for 3K$ additional coverage.
I consider it totally worth it , because other wise my bike is insured for blue book of my bike- which is low because all of my bikes are old lol its the difference between 2600$ buy out if my vstar were wrecked or 5600$ if they counted the custom paint , exhaust, intake, oil filter relocation kit and added chrome. - they still probably wouldnt give me max payout but at least cover those items ~ about 2500$ subtract depreciation. and they do depreciate stuff. My totaled Jeep cherokee they depreciated thousands because I replaced the front drivers seat and other cosmetic blemishes! I was rear ended and it totaled my jeep and they offered me 2100 or 1800 and i keep it salvage title. I took the 1800 and sold it for scrap for 600 .... either way it was not fun. Always get MORE coverage.... its only a little more but it pays a lot when it counts!
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
February 20th, 2014, 10:17 AM | #13 |
yeah i think since i'm not at fault in this one my coverage limits dont really matter, i can pretty much demand anything haha.
I'm going to take it to a shop, get an estimate and go through AAA, who will then demand money from the other party. No money out of my pocket! The other insurance contacted me this morning as well. definitely agree though on the insurance coverage. It shares the same coverage as my car so it's actually quite comprehensive. It just doesnt pay for medical lol..but i have med insurance for that. |
February 20th, 2014, 01:07 PM | #14 | |
Intrepid Adventurer
I am getting new plans when I move down to NC ... I am going to have to do my research
March 7th, 2014, 02:10 PM | #15 |
alright so the shop got a check and will be ordering parts.
Those of you who have had insurance repairs on your bike, do you get to keep the old parts or are you entitled to? That two brothers exhaust...the old one still works. |
March 7th, 2014, 02:55 PM | #16 |
insurance writes you a check for the cost of the repairs. that is the end of it. if a shop trys to keep your old parts, that's between you and them.
March 7th, 2014, 03:07 PM | #17 |
gotcha. AAA wrote a check to the shop for their estimate, but i just emailed the guy at the shop i can keep the old brother's exhaust. Will be getting a shiny new two brothers from insurance! the old one has a few scratches but it works. it would be a waste to scrap it.
March 14th, 2014, 12:35 PM | #18 |
just an update but it's fixed!
March 14th, 2014, 04:00 PM | #19 |
Certified looney toon
MOTM Jul '13, Jul '14
Sweet!
What have you got on your rear seat? What bag is that?
March 14th, 2014, 04:12 PM | #20 |
[crash.net - MotoGP] - Jack Miller tipped for the top | Ninjette Newsbot | Motorcycling News | 0 | August 7th, 2014 02:30 PM |
[crash.net - WSBK] - Qatar tipped to conclude 2014 WSBK season | Ninjette Newsbot | Motorcycling News | 0 | February 26th, 2014 03:10 AM |
[crash.net - MotoGP] - Casey Stoner tipped to quit V8 Supercars | Ninjette Newsbot | Motorcycling News | 0 | September 13th, 2013 05:00 AM |
Bike got tipped | Dat_Ninja_There | General Motorcycling Discussion | 13 | April 12th, 2011 12:55 PM |
[crash.net - MotoGP] - Alice tipped to confirm Kallio, Canepa at Sepang. | Ninjette Newsbot | Motorcycling News | 0 | October 9th, 2008 05:11 AM |
