August 30th, 2013, 05:50 PM | #1 |
[motorcycle.com] - 2013 Can-Am Spyder RT and ST Models Recalled for Fire Risk
Transport Canada announced a recall for all 2013 Can-Am Spyder RT and ST series roadsters because of a risk of a vehicle fire. At the moment, a recall has only been announced for Canada but a representative from Bombardier Recreational Products says agencies in other countries such as the U.S. National Highway Traffic Safety Administration are also preparing for a recall. According to Transport Canada, heat build-up near the brake master cylinder could cause the plastic manifold inlet on top of the tandem master cylinder to melt. A melting manifold inlet could cause a brake fluid leak which may result in a fire. The recall affects all versions of the RT and ST, including the S and Limited versions. A BRP spokesperson posting on the SpyderLovers.com forum says the company has developed new heat shields which dealers will install to reduce the heat levels near the tandem master cylinder which will prevent the manifold inlet from melting. The Transport Canada recall affects 2,380 units. We’ll provide an update once NHTSA releases information about a U.S. recall. [Source: Transport Canada, SpyderLovers.com] The post 2013 Can-Am Spyder RT and ST Models Recalled for Fire Risk appeared first on Motorcycle.com News. Click here for full story...
[motorcycle.com] - 2015 Husqvarna and KTM Models with 4CS Forks Recalled | Ninjette Newsbot | Motorcycling News | 0 | November 12th, 2014 10:40 AM |
[motorcycle.com] - 2015 Victory Models Recalled for Transmission Issue | Ninjette Newsbot | Motorcycling News | 0 | November 11th, 2014 10:40 AM |
[motorcycle.com] - 2014 MV Agusta Brutale, F3 and Rivale Models Recalled for Loose Sw | Ninjette Newsbot | Motorcycling News | 0 | May 14th, 2014 02:50 PM |
[motorcycle.com] - 2014-2015 Victory Models Recalled for Risk of Engine Seizure | Ninjette Newsbot | Motorcycling News | 0 | May 2nd, 2014 01:40 PM |
[motorcycle.com] - 2014 Zero Models Recalled for Motor Defect | Ninjette Newsbot | Motorcycling News | 0 | April 7th, 2014 05:30 PM |
