Old April 7th, 2011, 06:40 PM   #1
GeorgiaHooligan
GeorgiaHooligan's Avatar
Exclamation Tire Pressure recommendations 2up
Want to take with out tomorrow , its been a while and cant recall tire psi I used. This for a 07. Any tips would be great.
GeorgiaHooligan is offline   Reply With Quote
Old April 7th, 2011, 06:43 PM   #2
GeorgiaHooligan
my bad, taking "the wife" out tomorrow.
Old April 7th, 2011, 06:48 PM   #3
GeorgiaHooligan
i want to say i went up 2 or 3 psi on the front and back. not sure though.
Old April 7th, 2011, 07:18 PM   #4
GeorgiaHooligan
no suggestions?
Old April 7th, 2011, 07:31 PM   #5
Samer
Samer's Avatar
Motorcycle(s): 09 Ninja 250R SE
I've never gone 2-up but I do know you can push up the pressure on the tires quite a bit without any worry. I know the manual says 28 front and 32 rear... when I checked my tire pressure after taking it to the dealer for 600 mile service it was ~40 psi in the rear and maybe ~36 up front. When I asked them about it they said the tire wears less that way. Maybe true but I'm a believer in the manual, so I've switched back. My point is, you can go 5 or 6 psi extra without any worry.
Samer is offline   Reply With Quote
Old April 7th, 2011, 07:59 PM   #6
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
I haven't done 2-up on the 250 either but it will probably depend on your weight + her weight and how it feels riding. I would say start at stock pressure for your baseline and then adjust up 2 lbs each as necessary based on how that feels.
slolane is offline   Reply With Quote
Old April 7th, 2011, 08:10 PM   #7
GeorgiaHooligan
Thanks for the feedback, I was thinking the same. I'll take her around the block and make adjustments if needed. She weighs 100lbs and 5' tall so her weight shouldnt change the handling up too much.
Old April 7th, 2011, 08:19 PM   #8
/moved to pre-gen tech section
Old April 8th, 2011, 01:34 PM   #9
GeorgiaHooligan
Took her out today for a couple hours, had a blast . Even hit 95mph on the interstate with her on the back. Went with 30psi in the front and 34psi in the rear.
Old April 14th, 2011, 08:08 AM   #10
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
Rather than messing around with the PSI, I think it better if you just adjust the rear suspension pre-load
edit: ignore my post...I just saw yours is a 07
Last futzed with by LoneRonin; April 14th, 2011 at 09:09 AM.
LoneRonin is offline   Reply With Quote
Tire recommendations for commuters? CThunder-blue 2008 - 2012 Ninja 250R Tech Talk 95 April 10th, 2013 07:22 PM
Tire recommendations for NYC rider? nliu314 2008 - 2012 Ninja 250R Tech Talk 2 June 11th, 2012 12:53 PM
Got a flat...now need a new tire. Need recommendations on an upgrade Hitman 2008 - 2012 Ninja 250R Tech Talk 4 July 25th, 2011 05:10 AM
Ideal Tire repair kit and portable air pump recommendations? setasai General Motorcycling Discussion 12 July 6th, 2011 08:44 AM
Bt-45 tire pressure indr 2008 - 2012 Ninja 250R Tech Talk 1 July 5th, 2011 09:05 AM
