Old June 9th, 2010, 02:18 PM   #1
shiftdrift06
Motorcycle(s): None
Quick Question about accessories (Headlights, Horn, Taillights, etc)
Hello, I just recently purchased a bike, however, it does not run. That is not my concern at the moment, as I am gonna replace the engine soon.
However I was wondering, what accessories turn on, with the key in the "On" position with the bike NOT running.
SO far, only my turn signals work, my front and rear headlights don't work as well as my horn. Does my bike need to be running for those to work?
shiftdrift06 is offline   Reply With Quote
Old June 9th, 2010, 02:59 PM   #2
Momaru
Momaru's Avatar
That may depend on the model, but if it's one of the newer generation, the below are true:
The headlights shouldn't come on until the engine has been started. They will however, remain on once the engine has stopped if you don't turn the key to 'off'.
The horn is also downstream of the starter relay so it won't work unless the engine's on. Edit: it will, I just read the diagram wrong.
Do the tail & license plate lights work? They should whether the engine's been started or not.
Here's a link to the full wiring diagram for the new-gen
http://www.ninjette.org/forums/showthread.php?t=35886
Proud member of the Blue Army
Last futzed with by Momaru; June 10th, 2010 at 10:00 PM. Reason: Correction to horn
Old June 9th, 2010, 05:09 PM   #3
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
On a pregen, the horn and tail light should work without turning the bike on, but the headlight is the same as described by Paul. My first suggestion would be check your fuses. I won't pretend to understand how they work, but that may help. I do know that the fuse for the backlight behind the speedometer and tachometer are connected to the same fuse as the tail light, so an easy way to check that is to switch the bike on at night. If those lights aren't on when you switch the bike on, the fuse is probably blown. I don't know about the horn, but I know that both the tail light and the horn should work without starting the bike on a pregen.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old June 9th, 2010, 07:11 PM   #4
shiftdrift06
Motorcycle(s): None
Thank You for the reply, Momaru and Verus Cidere.
As of now, only my turn signal works right now.
I will check my fuse and report back.
Old June 9th, 2010, 07:58 PM   #5
check the rear tail light bulb... it may be blown.
Old June 10th, 2010, 01:48 PM   #6
shiftdrift06
Motorcycle(s): None
Tested all the fuses with a testlight they were fine. I started to fiddle with the connection at the horn, and it works now.
My rear bulb was half blown, the taillight filament was gone, but the brake filament was still good.
But I notice that, only my brake pedal would light up my rear brakes, my brake lever switch might be out, or loose connection, because it doesn't light up my brake light.
And notice that my clutch switch or kick switch is funky, it would sometimes crank my engine, in almost any position....
Old June 10th, 2010, 09:51 PM   #7
Momaru
Momaru's Avatar
The clutch switches are notoriously flakey. I took mine apart & cleaned it which helped me.
The 'before' shot...
Sorry for the bad info on the horn; should've gone out and just checked it like I meant to...
quick question Electronic M 2013 - 2017 Ninja 300 Tech Talk 57 March 17th, 2015 04:41 AM
Quick question kennetht 2008 - 2012 Ninja 250R Tech Talk 5 March 26th, 2014 11:40 AM
Quick Question PsHYk 2008 - 2012 Ninja 250R Tech Talk 3 June 10th, 2012 02:58 PM
Just a quick question zooman 2008 - 2012 Ninja 250R Tech Talk 12 May 18th, 2012 10:52 PM
Quick Question! shiftdrift06 1986 - 2007 Ninja 250R Tech Talk 4 March 1st, 2012 08:31 PM
