October 13th, 2009, 12:43 PM | #1 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
Exhaust hits the swingarm -
My bother bought a used 250 - '01 I believe - with about 5000 miles - the problem is the exhaust pipe on the right side (both do this to some degree) hits the swingarm as the shock is compressed. I would just move the bracket to the outside of the frame, but the passenger foot peg prevents this - the hanger must be on the inside of the peg attachement point on the frame -
Is this a common problem? How can it be resolved? Should we just fabricate a metal bracket? Bending the exhaust piping won't help.... Last futzed with by austexjg; December 2nd, 2009 at 10:06 AM. |
October 13th, 2009, 03:07 PM | #2 |
the bracket that mounts to the peg is probably bent - you'll need to use something like a mallet and a 2x4 to change the angle so that it no longer hits. Mine did the same thing after my oops last year, but beating on it with a mallet and a board helped to fix that
October 13th, 2009, 04:38 PM | #3 |
Yep, just bent the brackets and the problem was solved - seems like a heavy person using the back pegs could cause this to happen.
October 13th, 2009, 10:14 PM | #4 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
I had the same problem with my stock exhaust because of the bike being dropped. 'Tis an easy fix!
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
December 1st, 2009, 12:51 PM | #5 |
I had the same problem when I installed my Muzzy system. Ended up just grabbing the backside of the muffler and pulling outwards. That seemed to fix it.
December 1st, 2009, 10:14 PM | #6 |
Join Date: Nov 2009 Motorcycle(s): 2001 Ninja 250 (Sold); 2008 Ninja EX500 Posts: 273
+1 on having the same problem after a drop. Bent it back out.....problem solved!
Swingarm Bearings? | ebrammer252 | 1986 - 2007 Ninja 250R Tech Talk | 2 | May 27th, 2014 04:22 PM |
bigger swingarm | blade | 2008 - 2012 Ninja 250R Tech Talk | 9 | March 29th, 2011 07:44 AM |
[hell for leather] - Erik Buell’s latest patent combines exhaust, swingarm | Ninjette Newsbot | Motorcycling News | 0 | November 22nd, 2010 03:00 PM |
new gen swingarm | backinthesaddleagain | 2008 - 2012 Ninja 250R Tech Talk | 25 | October 20th, 2009 05:36 PM |
