Go Back   ninjette.org > Marketplace > Motorcycle-related
Old May 24th, 2010, 01:50 PM   #1
ecannon1
Motorcycle(s): depends on the day of the week
87-07 engine bits
Well I picked up an engine, took a chance and well it not worth fixing. Parting out the rest of the engine. Everything will be cheap. I split the cases today and the crank is probably not worth machining, the connecting rod broke on the crank side. Here is a list of parts. I will except offers and if you are interested in multiply parts we might work something out. I haven't looked on ebay to see what this stuff goes for, not trying to break anyones pocket book. If you need a small part let me know.
Lower half of the crank case $25
Upper half of the crank case $10 (might be useable has some marks from the pistion/rod)
Stator cover plus fastners $25
Stator $10
Clutch cover plus fastners $25
starter (includes small reduction gear in the case) $15
Complete clutch including basket and pressure plate $20
Crank (probably not useable but I haven't taken it to a machine shop yet)$10
Head ( I think it is good but no warranty)sold
Cams sold
timing chain $2
Shifter and all parts connecting mechanical to shift drum $15
Gears set for the transmission $20
I am sure there are other parts I left out. If you need something shoot me a pm or email me cycledagain@gmail.com
Last futzed with by ecannon1; May 29th, 2010 at 07:03 PM. Reason: update items sold
ecannon1 is offline   Reply With Quote
Old May 24th, 2010, 06:44 PM   #2
HKr1
IC2(SW)
HKr1's Avatar
I'll take the complete head off your hands. Head/cams/rocker arms/valve cover and head bolts.
you have a pic, both sides?
Old May 24th, 2010, 09:54 PM   #3
ecannon1
pm sent
Old May 25th, 2010, 11:00 AM   #4
ecannon1
Picture emailed
Old May 25th, 2010, 04:00 PM   #5
ecannon1
Originally Posted by ecannon1 View Post
Head ( I think it is good but no warranty)$20
Cams $5
[/email]
also pending valve cover and head bolts and valve cover bolts
Sale pending
Old June 1st, 2010, 10:51 PM   #6
ecannon1
Lower half of the crank case $15
Upper half of the crank case $5 (might be useable has some marks from the pistion/rod)
Stator cover plus fastners $15
Stator $8
Clutch cover plus fastners $15
starter (includes small reduction gear in the case) $10
Complete clutch including basket and pressure plate $10
Crank (probably not useable but I haven't taken it to a machine shop yet)$5
Cams sold
timing chain $2
Shifter and all parts connecting mechanical to shift drum $10
Gears set for the transmission $10
Just quoted the original and lowered prices if they are any cheaper I might as well recycle them. If you are interested let me know. Maybe these parts can help someone out. If someone is interested in the remain parts I will sell it all as a package for less than listed individually.
Junk small engine bits subxero Items Wanted 5 September 5th, 2014 06:32 PM
Dipped a few bits Shell-case 2008 - 2012 Ninja 250R Farkles 2 July 18th, 2013 01:59 PM
250R Track Bits pjed Items Wanted 2 October 23rd, 2011 09:27 PM
Last bits WickerPig Motorcycle-related 0 September 25th, 2010 04:27 PM
New bits from Christmas shporsche Pictures 18 January 6th, 2009 04:01 PM
