Old October 12th, 2011, 09:19 AM   #1
venmichaels
Motorcycle(s): 08 ninja 250r
Running ninjette with no muffler, bad idea??
I recently removed my muffler to install my two bros slip on...
However, I discovered that My right side foot peg bracket is bended in and the two bros slip on will not mount onto the bike because of it..
Until I figure out my next move, im running with no muffler..
Are there any harsh effects of running the bike like this???
WIll i mess up my motor??
09 ninja 250r
venmichaels is offline   Reply With Quote
Old October 12th, 2011, 09:28 AM   #2
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
other then being insanely loud above 5k rpms.. it shouldnt really hurt anything. a aftermarket slip on has no backpressure as its just a straight through glasspack basically. you can also either try bending your bracket back out or go to your local hardware store and either make a new hanger which would remove your stock rear peg.. not sure if you need it .. or make a small bracket to hang off your stocker and then to the slip on until you can get a new rear bracket.
#1
greatwhiteninja is offline   Reply With Quote
Old October 12th, 2011, 09:29 AM   #3
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
it will decrease your engine's performance when operating, as 250's require exhaust back flow pressure. not sure if you'll ruin your motor tho.
gt_turbo is offline   Reply With Quote
Old October 12th, 2011, 09:31 AM   #4
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
Well the first thing it's going to do is piss off just about every single person in about a half mile radius. The bike is ridiculously loud with no muffler on, to the point you might get pulled over. I did a few runs with no muffler on just for fun with some friends and noticed the noise was excessive. The other thing I noticed was a loss of power. This makes sense since taking the muffler off reduces the back pressure. Too little back pressure on our little motors will cause them to not run at top performance. Damage wise, I don't think it will do any really harm to the motor. It will do harm to people's hearing however.
sombo is offline   Reply With Quote
Old October 12th, 2011, 09:32 AM   #5
greatwhiteninja
Ridin Dirty
heres the link to make your own hanger http://www.ninjette.org/forums/showt...xhaust+bracket
#1
Old October 12th, 2011, 09:42 AM   #6
venmichaels
Thanks for the link.. but the only issue is that I need that passenger foot peg becuz my girlfriend rides with me everywhere...
Any other ideas????
Old October 12th, 2011, 09:42 AM   #7
greatwhiteninja
Ridin Dirty
it probably feels slower becuase its just so loud lol! but most likely no muffler on a stock bike is a little less power but should be same power as a aftermarket slip on stock bike as its breathing better now you need to be sucking in more air on the inlet side and adding more fuel with jets. i dont think your ears will be able to deal with it though after a few days loL! i know when i had my shorty can i made that was a 4" long canister .. going down the HWY at 10K only after 5-10 miles was WAY too much.
#1
Old October 12th, 2011, 09:44 AM   #8
greatwhiteninja
Ridin Dirty
Any other ideas????
by a new bracket.. look in the marketplace here or ebay. look at the bottom of that thread where i show my bracket. that would work while still retaining your stock, bent bracket.
#1
Old October 12th, 2011, 09:54 AM   #9
venmichaels
oh i forgot to mention... The bracket Im using is brand new...
Its not the bracket thats bent.. i think its the frame of the bike..
I just bought this bike a few weeks ago.. it didnt even have a passenger foot peg...
I guess now I know why......
Old October 12th, 2011, 10:04 AM   #10
greatwhiteninja
Ridin Dirty
hmmm.. should post some pics of how far away it is from the bracket.. maybe the exhaust was bent. what was the stock pipe mounted too?
#1
Old October 12th, 2011, 10:28 AM   #11
venmichaels
the stock pipe was mounted using some kind of rig similiar to the link u showed me...
I removed the whole set up and installed the passenger foot bracket and was getting ready to install my two bros exaughst.. the hanger was so far away from the exhaust, that mounting it is impossible.. I cannot even mount my factory pipe to the FACTORY passenger bracket.. so I know something is seriously wrong...
Old October 12th, 2011, 10:36 AM   #12
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
No one has pointed this out... Ive read a lot that you can burn a hole in your piston with no muffler. There is a certain back pressure that the TBR (or any other exhaust) creates that is vital to the engine running smothley
Also is bent not bended
----> My Youtube! <----
Old October 12th, 2011, 11:15 AM   #13
sombo
sombo's Avatar
I never said my ninjette was stock lol. It's a pre-gen with a 2-1 exhaust and jet kit. There was a noticeable loss of power cause I was ummm kinda doing 1/4-mile runs against some of the cars our little group had (mustangs, camaros, grand prix, etc etc) and there was definitely a noticeable drop in power w/o the can on. Plus the aftermarket cans are NOT as much of a straight pipe as you are making them out to be. The do provide the needed back pressure our bikes need to operate correctly.
Old October 12th, 2011, 12:42 PM   #14
Running without a muffler for an extended period of time is a bad idea. You'll damage valves/pistons/your hearing
Old October 12th, 2011, 12:56 PM   #15
Mr. Your/You're, Then/Than, Their/There himself is giving vocabulary advice?!
J/K
Old October 13th, 2011, 10:34 AM   #16
Jojah17
Jojah17's Avatar
Motorcycle(s): 2008 Honja
I ran with no muffler for a week or so. Didnt ride very much just a couple jaunts around the neighborhood and once up to the exhaust shop. The power band gets real jacked up w/o a muffler....you'll have no mid-range at all. Also, detonation can occur which can eventually mess up your valves/pistons. Get a muffler, save your ear drums.
Jojah17 is offline   Reply With Quote
Old October 13th, 2011, 10:39 AM   #17
Kevin2109
KThanksBye
Kevin2109's Avatar
J/K
I know I actually laughed a little inside lol
Old October 13th, 2011, 10:58 AM   #18
jonthechron
Motorcycle(s): magHitVE
As long as the muffler bearing remains lubricated you should be OK.
Old October 13th, 2011, 04:07 PM   #19
Fly'in Ninja
Motorcycle(s): C-250R-ST
maybe metal wire ties??
Fly'in Ninja is offline   Reply With Quote
Doubling up on armor... Is this a bad idea? MrAtom Motorcycle Gear 15 December 1st, 2014 05:46 PM
[motorcyclenews.com - news] - Wheelie bad idea Ninjette Newsbot Motorcycling News 0 November 19th, 2014 08:00 AM
[motorcyclenews.com - news] - Wheelie bad idea Ninjette Newsbot Motorcycling News 0 November 19th, 2014 05:50 AM
Probably a bad idea, but... bagtf3 1986 - 2007 Ninja 250R Tech Talk 3 March 3rd, 2013 07:25 PM
Tell me why this is a bad idea DBentley415 General Motorcycling Discussion 13 February 19th, 2011 09:00 PM
