October 8th, 2014, 01:10 PM | #1 |
[American Motorcyclist Association] - AMA Member Tested: Biker Rain Chaps
"I was pleasantly surprised with the ease of donning the chaps."
MSRP: $19.99 (25 percent discount for AMA members) www.bikerrainchaps.com/ama By Ted Pasche Biker Rain Chaps are the brainstorm of Mitch Harris, a long-time motorcyclist, to fill a need to keep a rider’s pants or leathers dry. The chaps satisfy that need in an extremely cost-effective manner. For the small price of $19.99 (and 25 percent less for AMA members) your lower half can ride dry and comfortable, thanks to this handy, amazingly compact accessory gear. In fact, the product arrived in a package so small and light I wasn’t sure if they would work. The Biker Rain Chaps come ready to use, and included is a small 5.5-by-11- inch stuff bag to keep the chaps easy to find and protect your other gear from the wet chaps after use. I was pleasantly surprised with the ease of donning the chaps. (There’s a handy tag inside that designates the left and right legs.) Simply open the heavy hook and loop seam lower, pull the chaps over your pants, open the hook-and-loop top strap, slip the end under your belt, and press the hook-and-loop fastener together at the top and bottom of the chaps. All this can be performed faster than you read the previous paragraph, even in a windy situation. As for durability, these chaps are constructed of the same material as most waterproof jackets, pants, etc. — a polyester exterior with a waterproof coating on the inside. This makes for a strong construction. However, they aren’t made to take excessive heat, such as what might be generated by a running exhaust pipe. The only nitpick is that these are indeed chaps. That means they leave your posterior exposed to the elements. However, that certainly isn’t a criticism specific to this product, simply an observation of chaps in general. In a long heavy rain your rear would probably get wet but, as intended, this inexpensive product will suffice for those times that full rain gear isn’t warranted, desired or available. For a small investment, pick up a pair and stuff them on your bike. They’re light, compact and won’t break the bank, especially for AMA members. See the website for a sizing chart and gift card options. Ted Pasche is an independent AMA Member Tester. Click here for full story...
[American Motorcyclist Association] - AMA Member Tested: Shoei J-Cruise Helmet | Ninjette Newsbot | Motorcycling News | 0 | December 1st, 2014 09:51 AM |
[American Motorcyclist Association] - AMA Member Tested: Sedici Rapido Waterproof Tex | Ninjette Newsbot | Motorcycling News | 0 | December 1st, 2014 09:10 AM |
[American Motorcyclist Association] - AMA Member Tested: SoCal Motorcycle Tours | Ninjette Newsbot | Motorcycling News | 0 | November 6th, 2014 07:40 AM |
[American Motorcyclist Association] - Member Tested: Factory Connection Suspension Re | Ninjette Newsbot | Motorcycling News | 0 | June 4th, 2014 11:10 AM |
[American Motorcyclist Association] - AMA Member Tested: Rev’It USA Chronos GTX Jacke | Ninjette Newsbot | Motorcycling News | 0 | May 7th, 2014 12:50 PM |
