Old November 14th, 2012, 09:11 AM   #1
How hot do the clutch and stator covers get? What temperature?
Rather than painting, I want to cover my clutch and stator covers with CF vinyl. Obviously, this won't work if they are going to melt, but I need to know what kinds of temps these surfaces run before researching the exact material.
Any idea?
Old November 14th, 2012, 09:26 AM   #2
well the water can get up to 180Fish or even boiling in a failing system. i think the case would be around there. cooler on those outer covers too. probably safe to assume somewhere between 150-200F
Old November 14th, 2012, 09:40 AM   #3
bdavison
Wartown, USA
bdavison's Avatar
At the temps of the engine case...usually in 160-180F the CF vinyl probably wont melt, but it will perhaps bubble or discolor a bit.
I dont think I would recommend it.
Old November 14th, 2012, 10:14 AM   #4
EMSRacer07
EMSRacer07's Avatar
powder coat them.
Old November 14th, 2012, 10:30 AM   #5
Thanks.
Thanks. I think the newgen-J/K clutch bolt pattern is the same and so the SSR CF clutch cover will probably fit (HATE the gloss though). I might be able to get away with real CF sheets on the stator side but I'll need a high-temp adhesive.
Originally Posted by EMSRacer07 View Post
powder coat them.
Yeah, I was going to paint it and the frame high-temp flat black but half the reason to use CF vinyl there was to cover the scrapes and stuff painting or powder-coating won't. The other half of the reason was so that I wouldn't have to take the engine apart.
Old November 14th, 2012, 10:41 AM   #6
EMSRacer07
EMSRacer07's Avatar
Originally Posted by CZroe View Post
Thanks.
Yeah, I was going to paint it and the frame high-temp flat black but half the reason to use CF vinyl there was to cover the scrapes and stuff painting or powder-coating won't.The other half of the reason was so that I wouldn't have to take the engine apart.
Have done the high temp paint. And it lasts as long as your clean about it. But if you get gas or anything that will eat through paint on it it will look terrible. Ask me how i know...... lol.
But if your going to take the time to paint them i would say powder coat them. Idk if vinyl will do it. I have vinyl on the body panels and it doesnt like the heat coming from the radiator so i could assume it not being so well on the engine itself.
Old November 14th, 2012, 11:57 AM   #7
DaBlue1
DaBlue1's Avatar
Why not just polish them? It's a lot easier.
Old November 14th, 2012, 08:31 PM   #8
Actually, I replaced the sprocket cover, rearsets, and frame hole caps with newgen-J parts specifically to black it all out and the glossy-black engine covers just don't match. I'm going to paint the frame from my parts bike flat black too and move this engine into it. I guess I'll hit it with some hi-temp exhaust paint during the cross-over.
Old November 15th, 2012, 01:01 PM   #9
Did you take the passenger pegs off?
I've thought about blacking mine out, except then I'd have to paint the swingarm.
Old November 15th, 2012, 01:35 PM   #10
Yes, though I'm considering painting and reinstalling. The swingarm is also replaced with a black newgen-J part, but you already knew that.
Old November 15th, 2012, 01:58 PM   #11
Yessir. I'm jealous of that. If I can ever find a good donor bike for cheap, I'll do the whole suspension conversion. But I'm pretty happy with it for now. It's at a point where if I'm out riding the suspension, I should get myself an SS yo! I'm a long way off of out riding the 250
[motorcycle.com] - The Latest From Empire Covers Bike Covers Ninjette Newsbot Motorcycling News 0 September 29th, 2014 07:21 PM
sticky hot clutch alex.s 2008 - 2012 Ninja 250R Tech Talk 14 June 1st, 2014 09:52 PM
Hi, looking for Dress up parts 250R (clutch, break, chain covers, handlebars etc) BulletPROZ General Motorcycling Discussion 8 August 26th, 2013 05:03 PM
[sportrider - latest stories] - ALL NEW Barnett Billet Clutch Covers Ducati 6-speed Ninjette Newsbot Motorcycling News 0 May 14th, 2012 04:50 PM
