Old October 6th, 2010, 05:15 AM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
warming up the bike
hi there i just shimmed my needles, bike runs great
now its getting 52 dgrees in the morning....im in NJ
bike har dto start dont want too flood it with choke
after a while it starts up, any ideas on how to start up the ninja in cold weather
james250ninja is offline   Reply With Quote
Old October 6th, 2010, 05:20 AM   #2
are you using the choke to start it now?
Old October 6th, 2010, 06:01 AM   #3
/moved to pre-gen tech
Old October 13th, 2010, 02:20 PM   #4
mrlmd
mrlmd's Avatar
Use the choke - that's what it's for.
Old October 13th, 2010, 02:51 PM   #5
bob706
bob706's Avatar
Old October 13th, 2010, 06:28 PM   #6
Bleak21
Bleak21's Avatar
Motorcycle(s): 05 Ninjette
Whatup,
I'm also in NJ so I can relate to our weather. This past week, mornings have been the crispest this season. I usually start the bike with no choke as I stand beside it and put my gear on. I never start it with choke (it seems wrong if I don't have to to just let the engine jump immediately), but bump it up halfway after its settled initially. This all usually takes 2-3 minutes. Then I'm on the road and away.
Bleak21 is offline   Reply With Quote
Old October 13th, 2010, 06:43 PM   #7
mrlmd
mrlmd's Avatar
Originally Posted by Bleak21 View Post
Whatup,
I have no idea what you said or were trying to say.
As has been said on here multiple, multiple times - these bikes are coldblooded and need the choke to start, sometimes even if it's 80 degrees outside, especially for the first start of the day or if it's been sitting and the engine is cold. I don't understand what the ego trip is not to use the choke. It's only on for a few minutes 'till the engine warms up and that is the way it's supposed to work. It's an enricher circuit, not a butterfly air restricting valve like on a car. It's meant to be used to start the bike. Read your owner's manual, learn how your bike works, get over the fact that it is supposed to be used. Set it up 1/3 - 1/2 way, hit the start button. If it doesn't start in 2-4 revolutions of the engine, turn it up a little more untll it does. That's normal operation - what's the big deal, the turnoff, to using the choke as it's supposed to be used? You can shim all you want, rejet all you want, use the friggin choke to start the bike.
Old October 23rd, 2010, 08:07 PM   #8
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Air mixture screws?
Are the EPA caps still installed over the air screws?
If they are:
Remove carbs, pop off the caps, turn screws in until "gently seated", turn them out 2.5 turns.
Real good idea to check the float height while the carbs are out.
Replace carbs. You'll still need the choke on cold mornings but she'll start easier and warm up quicker.
j98
j98sprint is offline   Reply With Quote
Won't stay running after warming up skrymir69 1986 - 2007 Ninja 250R Tech Talk 31 May 1st, 2014 07:24 PM
[topix.net] - Warming up to The Chill Ninjette Newsbot Motorcycling News 0 March 3rd, 2012 10:40 AM
Warming Up Tires akima General Motorcycling Discussion 9 November 17th, 2011 04:13 PM
noob in need...issues with warming engine. EthioKnight 2008 - 2012 Ninja 250R Tech Talk 5 October 27th, 2011 11:45 PM
Global Warming - Would Al Gore lie? g21-30 Off-Topic 13 January 29th, 2009 01:24 AM
