Old April 29th, 2011, 08:15 PM   #1
headshrink
headshrink's Avatar
Water pipe came out....
I was taking my valve cover off because I'm trouble-shooting a tasty sound. I think I have confirmed the EX valves on #1 were to loose. But here is the issue.... Rather than follow the SM directions, I used the shortcut in the DIY, by leaving the radiator and hoses on. As I was finagling the valve cover off, I inadvertently pulled off the metal water pipe that comes out off the top end (the pipe that has that tab for the valve cover). I didn't know this came out...... Do I have a problem, or will shoving it back down ensure I won't have any leaks? I can't find mention of it in the SM.
THANKS!
Old April 29th, 2011, 08:41 PM   #2
headshrink
headshrink's Avatar
How do these posts get indexed by google almost immediately!? Times sure have changed.
Old April 29th, 2011, 11:05 PM   #3
headshrink
headshrink's Avatar
Anyone know, or should I start ordering parts?
(do I REALLY save money DIY?)
Old April 29th, 2011, 11:20 PM   #4
I dunno. What nasty sound are you troubleshooting?
Old April 30th, 2011, 12:56 AM   #5
headshrink
headshrink's Avatar
Nasty metalic tapping. Clearance was to much on #1 ex.
Old April 30th, 2011, 03:02 AM   #6
randomwalk101
self wrencher
randomwalk101's Avatar
Just put it back in. Should be okay...I think. Worst case is getting a new one but I dont think you have to. Can you do a YouTube video on how to adjust valve? I'm still confused with the diy.
Old May 1st, 2011, 05:02 PM   #7
headshrink
headshrink's Avatar
A few related issues here......
I got it all back together, and it seems OK. I did learn why that annoying tab is on the valve cover... The pipe slips into the hole in the top of the engine, and has an O-ring near the end (similar to the shuttle boosters). The tab on the valve cover is what holds it secure in place. So when you unbolt your valve cover, the only thing holding it in is friction from the O-ring. That is why it can be pulled out so easily if you leave your cooling system intact. Unfortunately I got a bit of coolant INSIDE my engine.... now I have milky oil... nice. So I get to do an oil change tonight.
I redid my valve clearances (tighter) and the tapping is somewhat reduced, although still present. I am finding I don't get repeatable results with my feeler gauges. I have the head knowledge, but need to have someone physically show me what too tight feels like, too loose, and just right. I also noticed when I use my digi micrometer, as opposed to my digi vernier caliper, the added decimal can yield enough of a difference to give me the next shim in the equation. So, when all was said and done, I ended up with nearly the same shims I had BEFORE the last valve adjustment 1K miles ago when I loosened it too much. Technically, however, I was never out of spec at either end.... I just went from barely within spec (tight -> loose -> tight).
I did notice the beginnings of a little wear on the cam gears. I think this is due to switching to the manual CCT last service (1K ago). I was careful not to go too tight (I think), but it is a delicate balance. I stopped just at the point it stopped making noise. Online the DIYs say once you hit the point the chain noise stops, tighten another 1/4 turn and stop, but the manufacturer says the opposite.... which would basically leave you with the same noisy chain the OEM CCT gives you. 1/4 turn is a LOT of tension. Let's hope splitting the difference is the sweetspot.... but I may back it off 1/16-1/8 to be safe due to the wear.
randomwalk: I wouldn't mind doing the video at some point, but don't feel confident enough yet, with all the errors and all that I am still making. I take a stab at answering any questions though....
Anyone know how many oil changes it should take to get rid of the milk?
Old May 2nd, 2011, 02:58 PM   #8
ricochet08
ricochet08's Avatar
Motorcycle(s): 2007 ninja ex500, 2010 Ninja 250r, 2004 zzr600, 2003 CBR600rr, 2013 Ninja 300...in that order :D
you've been waiting for a vid on this for a while haven't you?
ricochet08 is offline   Reply With Quote
Old May 3rd, 2011, 07:53 PM   #9
randomwalk101
self wrencher
Yep. I'm about to due for a valve adjustment
Old May 3rd, 2011, 07:56 PM   #10
randomwalk101
self wrencher
I imagine one oil change & take the oil filter out to drain all oil in there would be enough.
Btw, if you do a video, perhaps the expert like racerx can see what you do wrong too ( if any)
Old May 3rd, 2011, 10:28 PM   #11
headshrink
headshrink's Avatar
good point.
I started seeing a noticeable, but not complete, difference on the second oil change. I've done 3, but will do 4 or 5.... depends on how much cheap oil I have left. The key was to do it when it is burning hot. Some of the slime is left under the oil cap... reminds me of arterial plaque, only not as hard. Moral of the story = don't mix oil and antifreeze.
Water pipe on engine head leaking cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 14 June 4th, 2020 08:07 PM
Must be something in the water... notsofast General Motorcycling Discussion 24 January 5th, 2014 05:15 PM
[superbikeplanet.com] - As The Water Buffalo Turns: Suzuki Won't Dip Toe Into Water I Ninjette Newsbot Motorcycling News 0 September 10th, 2013 09:10 AM
Water lovely water rusninja Off-Topic 28 November 7th, 2012 02:02 PM
