July 20th, 2010, 08:09 AM | #1 |
Replacing front sprocket only
I want to replace the stock 14T sprocket with a new 15T sprocket. But I want to keep the original chain and rear sprocket. The bike only has 3500 miles on it (2004). Will this cause a wear problem with the chain long term? On my other chain drive bikes I have replaced the front and rear along with a new chain when they're worn out. Thanks.
July 20th, 2010, 08:29 AM | #2 | |
I'm gonna say you will be fine. Yes normally if you are replacing a worn part in the drive-line, you would replace the chain and both sprockets.
July 20th, 2010, 08:33 AM | #3 | |
Join Date: Jan 2009 Motorcycle(s): 2008 250R (Black) Posts: 298
When you need to change the chain and rear sprocket later, i would throw in a new front sprocket again. But that is many many miles away. |
July 20th, 2010, 08:37 AM | #4 |
That's what I thought. Thanks for the fast replies. The front sprocket was only $16 so when the chain is worn out I'll get a new front and rear.
July 20th, 2010, 08:43 AM | #5 | |
http://www.ninjette.org/forums/showthread.php?t=10273
May 29th, 2011, 03:24 AM | #6 |
Join Date: Apr 2011 Motorcycle(s): 2002 Kaw Ninja 250/05 yama RSTD/03yama 1100 Classic Posts: 5
I replaced my Wifes Front Sprocket with a 15T as well, I did it because of the RPM's she was getting in the lower gears. Guess what, I cut the RPM's in half and did not effect the gas milage or the handling of the bike at all now it rides as it should. As for the Chain No ya dont need to replae it YET. But some day you may wish to but as stated before not to worry now.
May 29th, 2011, 03:41 AM | #7 |
Texas Newbie
Join Date: Sep 2010 Motorcycle(s): 07 Ninja EX250, 07 FZ6 Posts: A lot.
The 15t is the best mod to do on the lil Ninjette...
May 29th, 2011, 06:56 AM | #8 |
No, you cut the RPM's to 14/15ths of what they were before.
Replacing Front Turn Signals | UCSDavid | 2008 - 2012 Ninja 250R Farkles | 4 | August 21st, 2014 10:37 PM |
Replacing front end electrics | notsofast | 1986 - 2007 Ninja 250R Farkles | 11 | November 18th, 2013 05:29 PM |
Replacing front tire on your own? | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 9 | June 20th, 2013 01:43 PM |
Replacing Front Springs | Key007 | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 5th, 2010 05:52 PM |
Replacing sprocket for more speed | tlhamon | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 6th, 2009 12:36 PM |
