Old August 12th, 2011, 07:58 AM   #1
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
How do you remove the grip?
I need to replace my left grip / clutch side and it's not budging at all. I haven't taken my heat gun to it for fear of melting the rubber. Any ideas?
The www.ModMy250.com guy
Old August 12th, 2011, 08:05 AM   #2
Madchild
Ninja Racer
Motorcycle(s): 2006 Yamaha R6, 2009 Kawasaki Ninja 250R, 07 Aprilia SR50 Factory
If you don't care to keep it. Take a razor blade and cut it in half (Split the grip in half). From right to left or left to right. Not up and down.
CRA #23 - 2011 Sponsors: Cheng's Dynasty, Motoprimo, Studio299.com, Michelin, Syderleatherworks, Woodcraft, Vortex, Scorpion Helmet (USA), 24/7
Madchild is offline   Reply With Quote
Old August 12th, 2011, 08:16 AM   #3
CThunder-blue
ModMy250.com
Ummm, trying to reuse it on another handle bar. thanks tho
Old August 12th, 2011, 08:18 AM   #4
azimmer11
azimmer11's Avatar
shoot compressed air under it and itll slide right off
azimmer11 is offline   Reply With Quote
Old August 12th, 2011, 08:23 AM   #5
CThunder-blue
ModMy250.com
Thanks, but how do you get the air compressor nozzle under it? It's air tight. lol
Old August 12th, 2011, 08:35 AM   #6
Madchild
Ninja Racer
Try to roll it. From inside to outside of the handle
Posted via Mobile Device
Old August 12th, 2011, 08:55 AM   #7
CThunder-blue
ModMy250.com
Yep, I tried rolling it already. lol
Old August 12th, 2011, 08:58 AM   #8
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Compressed air is the proper way to do it.
You put the nozzle under the grip and shoot air in and it magically becomes "loose" on the handlebar.
when you install them, clean the bar and the grip with alcohol, shoot air into the grip and slip it on the bar and it'll never move.
Once you see somebody do it, you'll never want to do it any other way.
I put arriette grips on all my bikes.. I've done this many times.
Used to do it with bicycles as a kid too.
Very very good Italian grips.
Never ordered here but here's the color span..
http://www.jpcycles.com/ariete/grips
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old August 12th, 2011, 08:59 AM   #9
bob706
bob706's Avatar
I used the little needle adapter that you use to fill up basketballs and such
http://sandollarmotorcycleclub.com/
Old August 12th, 2011, 09:01 AM   #10
CThunder-blue
ModMy250.com
Thanks guys. I'll give it a go! Is it ok to use canned air? I'm not sure if I have any of the needle tips.
Old August 12th, 2011, 09:02 AM   #11
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
1 video is for saving the grip the other is just the blade tech-nick
http://www.youtube.com/watch?v=tL3_3_4pdcY
http://www.youtube.com/watch?v=sf-EKwyER74
THE GOOD LIFE
Old August 12th, 2011, 09:22 AM   #12
CThunder-blue
ModMy250.com
Thanks I'll try the tool if the air compressor doesn't work.
Old August 12th, 2011, 09:45 AM   #13
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Since I didn't have compressed air I just pried up the edge of the grip with a flathead and sprayed some soapy water inside. Then moved the flathead around the inside of the grip while proceeding to press to the flathead to the other side gently (all the while spraying some water in there). Once I got to the other side is slipped right off.
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old August 12th, 2011, 10:44 AM   #14
Madchild
Ninja Racer
Just order new grip and cut the old one off. The previous owner may have put super glue on it.
Old August 12th, 2011, 12:03 PM   #15
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
did you remove the bar end first? i didn't see you mention if you had or hadn't removed that first. if you didn't heat up the bar end screw with a small torch or heat gun. then stick a thin flat head in there and jab it all around to get the grip loose. that helps to fit the air compressor needle in there.
gt_turbo is offline   Reply With Quote
Old August 12th, 2011, 01:05 PM   #16
CThunder-blue
ModMy250.com
I removed the bar end in 2 minutes with no torches or other crazy stuff. I used my #3 JIS screw driver, wrapped a towel around the handle, gripped it with my stupid big wrench and broke it loose. The right tools for every job ftw
Old August 12th, 2011, 01:05 PM   #17
CThunder-blue
ModMy250.com
I'm transplanting my original grip to a new bar. Again, I'm not going to cut it off.
Old August 12th, 2011, 01:19 PM   #18
dino74
dino74's Avatar
Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race
I've had good luck with rubbing alcohol. I use a screw driver to make a little gap, then I squirt some alcohol. It works really well.
dino74 is offline   Reply With Quote
Old August 12th, 2011, 01:35 PM   #19
+1 on pulling from inside to outside (pull it inside-out). makes getting it back on painless without using a lubricant also (do the same thing but in reverse, it folds over itself and nicely into place. don't know if it works so well with stock grips though since they're made out of what seems like titanium enriched rubber.
Old August 12th, 2011, 02:39 PM   #20
setasai
setasai's Avatar
Yea it takes a little elbow grease but I got it off by using a small screw driving and slowly shimmed it in. Once you break the glue loose, it'll wiggle off. When you put it back on, use hairspray instead.
Old August 12th, 2011, 02:42 PM   #21
CThunder-blue
ModMy250.com
I don't have any hairspray.
Old August 12th, 2011, 02:45 PM   #22
setasai
setasai's Avatar
I didnt either. Had to go to target and get a 1dollar travel sized bottle.
Old August 12th, 2011, 02:48 PM   #23
CThunder-blue
ModMy250.com
I have some spray adhesive I'll try.
Old August 12th, 2011, 02:59 PM   #24
setasai
setasai's Avatar
I say hairspray because it's got a soapy texture until it dries. Makes it easier to get the grip on. Goodluck with the repairs. Let me know when you finish. I have a few other scenic routes I'd like to plan for.
Old August 12th, 2011, 06:00 PM   #25
sergemoat
a little heat may help soften up the rubber
sergemoat is offline   Reply With Quote
Old August 12th, 2011, 06:41 PM   #26
CThunder-blue
ModMy250.com
The air compressor worked like a charm. Thanks guys! Took me less than a minute to get it off.
Old August 12th, 2011, 08:04 PM   #27
cuz
cuz
cuz's Avatar
glad 4 the success so you just got it out w/the compressed air?
THE GOOD LIFE
Old August 12th, 2011, 09:15 PM   #28
k-os
I've used just a spray can of clear coat. Not really necessary. Should be able to get it back on using the compressed air too.
Old August 15th, 2011, 05:16 AM   #29
azimmer11
azimmer11's Avatar
told ya so
Old August 16th, 2011, 07:35 PM   #30
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
a small flat-head screwdriver + WD40 works good too. slide the screwdriver in between the grip and the handlebar, slide the WD40 nozzle in, spray a little, and its lubed and ready to come off, lol
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
How do I remove this reroka 2008 - 2012 Ninja 250R Tech Talk 7 June 10th, 2014 06:58 PM
Another way to remove the carbs.... Soujyu 2008 - 2012 Ninja 250R Tech Talk 6 August 26th, 2013 12:36 PM
Pro Grip 724 Dual Density Road Grip fmx 2008 - 2012 Ninja 250R Farkles 10 May 5th, 2013 07:47 PM
How do you remove your engine tubarney 2008 - 2012 Ninja 250R Tech Talk 9 February 18th, 2013 06:41 PM
To remove or not to remove?? extremez31 General Motorcycling Discussion 13 April 18th, 2012 07:54 AM
