July 9th, 2013, 03:35 AM | #1 |
Join Date: Jan 2013 Motorcycle(s): 1987 Ninja 250 custom gold Posts: 218
Lack of electrical power
Hi all,
Recently had troubles with going into neutral for initial startup and i figured out that it was the engine ground that wasn't connector to battery negative, so i connected that. Now, however, when i idle, there isn't enough power generated as i can see the dash being unsteadily lit. Furthermore, if i put on the turn signal, every time it blinks, the headlight dims. When riding normally, i.e. at higher RPM, this problem does not exist. Battery is pretty new, half a year old, and the bike starts fine. I have yet to check the wiring from the stator to the electrical circuit of the bike. Could the stator be the problem? |
July 9th, 2013, 04:37 PM | #2 |
Bump, anyone?
July 9th, 2013, 04:46 PM | #3 |
Different model, but similar problem.
http://www.ninjette.org/forums/showt...hlight=problem You may find some good leads to your problem there if you forward to the third page.
July 9th, 2013, 06:03 PM | #4 |
FWIW, when my bike was totally stock, I could make the bright light dim by turning on a turn signal while idling. Never had any other issues with it, so I ignored it.
July 9th, 2013, 08:21 PM | #5 |
Thanks for the replys, i will be testing the stator as soon as i get a chance.
[motogp.com] - Hayden: ‘Lack of power is demoralising’ | Ninjette Newsbot | Motorcycling News | 0 | February 7th, 2014 07:50 AM |
[sportrider - latest stories] - New Michelin Pilot Power 3 And Power Supersport Tires | Ninjette Newsbot | Motorcycling News | 0 | May 9th, 2013 05:30 PM |
Where to start- assessing complete lack of low end power | Jojah17 | 2008 - 2012 Ninja 250R Tech Talk | 17 | May 10th, 2011 11:24 AM |
[motorcyclistonline] - New Permatex® Liquid Electrical Tape Keeps Electrical Connect | Ninjette Newsbot | Motorcycling News | 0 | February 26th, 2011 01:20 AM |
Power question, powerlet 12v to mini-usb power. | karlosdajackal | 2008 - 2012 Ninja 250R Tech Talk | 1 | May 12th, 2010 05:03 AM |
