Old December 24th, 2013, 03:02 AM   #1
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
Exclamation Clutch Basket
After only 6,500 miles, the clutch basket is getting loose enough to irritate me with the noise and vibration at idle (unless I keep the clutch pulled in).
Question: Am I stuck with the rubber damper type basket, or do I have any alternatives? I know the "New Gen" uses springs instead of the rubbers.
Will the "New Gen" basket fit a "Pre Gen"?
Are the new OEM baskets improved in any way over the stock 2006 one in my bike.
The old KZ650-750 used the basic same style of clutch basket, and they got loose too, but being 4 cylinder they were not as noisy. The rubber gets hard and fails.
I found one reference in a forum where an enterprising owner/machinist had new rubbers cut by water-jet, made new rivets and rebuilt his.
One of my old contacts in the Pro Dragracing world can custom rebuild the stock basket, but that would be several times the cost of a new stocker.
Suggestions?
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old December 24th, 2013, 04:33 AM   #2
Originally Posted by fast1075 View Post
...........Suggestions?
Slightly press the clutch lever while idling.
Old December 24th, 2013, 12:14 PM   #3
i have read about someone replacing the rubber dampers with new hand cut rubbers. i forget where i saw it. it didn't look hard
Old December 24th, 2013, 12:15 PM   #4
here, http://forums.ninja250.org/posting.p...&t=86485&tro=1
Old December 25th, 2013, 08:49 AM   #5
fast1075
Talking Thanks
Thanks Alex. The author of that thread did what most people don't, provide real and usable info like part numbers and complete descriptions.
Old December 25th, 2013, 11:33 AM   #6
yw. post updates on your progress. i'm morbidly curious to see your clutch basket
Old December 25th, 2013, 12:22 PM   #7
I wouldn't do the small radial drills to the cushions; I have always believed that those were a flaw of the original design that led to early failure.
They don't do much more than unnecessarily weaken the cushions (.... yes, I know better than the Japanese engineer that designed those ).
I was not joking in my previous post.
A light pressure hurts nothing and eliminates or reduces the annoying noise.
Old December 26th, 2013, 03:33 AM   #8
fast1075
I intend to buy an E-bay basket to work with, and swap it in if it goes well.
When I was drag racing, I used a "slider" clutch from a company called MTC Engineering. They converted the stock basket to a purely centrifugal design.
They used a special cutter to cut the stock rivet heads down instead of drilling them out. When they reassembled the unit, they held everything together in a jig and TIG welded the rivets to the backing plate. The clutch held up to 200+ HP without failure.
Old December 26th, 2013, 10:25 AM   #9
fast1075
Just scored a complete clutch assembly from E-bay for $16.00 from a 2005 model. Should be here in a few days. Will update.
For those watching this, the part number for the silicone material has changed since the original poster did the posting.
The new part number for the tubing is 5546T56. The cost for a 6" piece is $5.37 plus freight.
Last futzed with by fast1075; December 26th, 2013 at 11:48 AM. Reason: more info
Old December 26th, 2013, 11:54 AM   #10
fast1075
Wink
Mine makes enough noise to be FELT through the seat at stops. It stops completely when I pull the clutch or load it a bit. I am very OCD about my mechanicals.
Old December 27th, 2013, 08:55 AM   #11
n4mwd
n4mwd's Avatar
The newgen uses replaceable springs and not rubber. I would be curious what is involved in getting one to fit a pregen.
My Ninja Blog
Old December 27th, 2013, 10:06 AM   #12
fast1075
Got the piece of silicone tubing today on UPS! WOW! what quick shipping. McMaster Carr ROCKS!
Old December 27th, 2013, 01:54 PM   #13
i have a spare newgen clutch and trans if you want to send me a pregen engine.
Old December 30th, 2013, 01:11 AM   #14
az3200
az3200's Avatar
Motorcycle(s): 2002 Ninja 250
What if it rattles even when idling while the clutch is pulled all the way in in 1st gear?
az3200 is offline   Reply With Quote
Old December 30th, 2013, 07:30 AM   #15
n4mwd
n4mwd's Avatar
I'll email it to you. But seriously, didn't you used to have a pregen engine to try it on?
The pregen clutch rattles pretty much all the time that it isn't under load. The Ninjette doesn't have many "oops" in its design, but using rubber dampers on the clutch basket is one of them.
The rubber dampers can be replaced as in the link above, but I think you need a machine shop to do it. It looks pretty difficult to me.
My Ninja Blog
Old December 30th, 2013, 12:04 PM   #16
3 new gen motors. no pregens.
Old December 30th, 2013, 02:26 PM   #17
n4mwd
n4mwd's Avatar
How about measuring it, counting teeth, etc.?
My Ninja Blog
Old December 30th, 2013, 02:45 PM   #18
i can do that, sure. what all do you want measured? just the gear that hooks up to the output shaft? i'll give you some photos and you can count the teeth.
Old December 30th, 2013, 04:37 PM   #19
n4mwd
n4mwd's Avatar
Maybe like the shaft diameter and the height of the basket when laid flat on a table. Also the thickness of the gears. And the diameter of the gears. I should be able to get a better idea with that info. And yes, some good clear photos to count the teeth. That would help for sure.
My Ninja Blog
Old December 31st, 2013, 09:08 AM   #20
az3200
az3200's Avatar
So as long as I don't mind the rattling it's no big deal?
Old December 31st, 2013, 09:19 AM   #21
n4mwd
n4mwd's Avatar
Mines been rattling for 30,000 miles so I don't think it hurts anything much.
My Ninja Blog
Old December 31st, 2013, 02:54 PM   #22
Daks
Jersey Devil
Daks's Avatar
Motorcycle(s): '06 Ninja 250
Reading this, I'm assuming it's the same issue my bike is having. Just got back from a 2 week vacation and noticed the clutch knocking something fierce in neutral until I pulled in the lever. Sometimes it would slip into neutral after shifting up to 2 as well, though that could be rider error with new boots.
It almost seemed like enough to keep it from starting right, but he could just be grumpy after not being touched for 2 weeks
~Riding like a grandma because I wanna ride as a grandma~
Daks is offline   Reply With Quote
Old December 31st, 2013, 03:07 PM   #23
Originally Posted by Daks View Post
..........Just got back from a 2 week vacation and noticed the clutch knocking something fierce in neutral until I pulled in the lever...........but he could just be grumpy after not being touched for 2 weeks
That is the way our bikes tell us that they were built to roll every day.
Old January 2nd, 2014, 08:58 AM   #24
fast1075
Thumbs up
My $16.00 used clutch just came in. There is no slop in the gear on it, so I will install it and see how it goes. And the fiber discs are within spec and look good. I will use a couple of the steels to build a hub tool. Just need to go pick up a cover gasket. Hopefully the local Kawi shop has one in stock.
Old January 2nd, 2014, 09:46 AM   #25
A) the clutch tool from cycle gear costs $12 and works fairly well.
B) use an impact wrench to take the clutch hub nut off, it will make a nearly impossible job, a piece of cake. literally takes 5 seconds with the clutch tool and impact wrench.
C) shops never carry the 250 gasket. if you still have most the gasket left you can patch it up with gasketmaker but if its turned to dust it will end up leaking with just gasketmaker. save a trip and order the gasket... or i guess you could call first.. but who the hell uses a telephone these days
Old January 2nd, 2014, 02:09 PM   #26
n4mwd
n4mwd's Avatar
or you could just print one out by going to my blog. You'll need to use gasket paper and a wide printer.
My Ninja Blog
Old February 1st, 2014, 04:12 PM   #27
fast1075
I finally found time to do something with the clutch. Remarkably easy job. The old clutch basket, as I suspected had a ton of play in it, but remarkably no rubber pieces in the oil strainer. I put the used basket I bought on E-bay in it, and also the inner since it had no grooves from the steels.
The strainer had the usual bits of case sealant since it had never been cleaned, no metal or rubber, or anything scary.
Put it back together with new gaskets, oil filter, and some fresh Amsoil 10-40.
The "raging gremlins with tiny banging hammers" sound is gone at idle.
I will in the future take the old basket apart, and try to rebuild it. I will post pics when I do. I came up with a unique tool to tighten/loosen the hub nut since I didn't bother to order a hub tool.
Old February 1st, 2014, 05:30 PM   #28
i imagine this is pregen? do you know how different the newgen is? do you have one for newgen? i'll give you a dollar to make a newgen one.
Old February 1st, 2014, 06:10 PM   #29
n4mwd
n4mwd's Avatar
No problem. Send me a dollar and a newgen engine and I'd be happy to.
My Ninja Blog
Old March 30th, 2014, 11:25 PM   #30
mr2peak
Motorcycle(s): Hyper 821
Anyone ever find out if the pregen will fit the newgen clutch assembly?
mr2peak is offline   Reply With Quote
Old March 31st, 2014, 02:42 AM   #31
Ginganinja
pregens for the win!
Motorcycle(s): 07 ninja 250, 07 yamaha r6
@fast1075 Interested in what your hub tool looks like. Throw up a pic if you got one!
Ginganinja is offline   Reply With Quote
Old April 1st, 2014, 04:15 PM   #32
mr2peak
Here's a link to making a clutch tool
http://forums.ninja250.org/viewtopic.php?t=83912
Old April 1st, 2014, 05:30 PM   #33
n4mwd
n4mwd's Avatar
Here is the one that I made. It requires sacrificing a clutch disk, but since I had a spare set, I went ahead and made the mods to it to make it hold the clutch basket in place while I turned the big nut.
The four tabs are made from a 1" wide steel strip and bent at a 90 and then riveted to the disk so that it can lock the two clutch basket sections together. Then I use a flat screwdriver between the gears to lock the basket so I can turn the nut.
The tool on ninja250.org used a string to hold the outer basket, but I like my way because it is more durable.
My Ninja Blog
Old May 27th, 2014, 04:39 PM   #34
Still curious about what can swap.
The clutch covers have the same bolt pattern, IIRC.
2003 Ninja 250 Clutch Basket Replacement!! RobJB 1986 - 2007 Ninja 250R Tech Talk 3 March 2nd, 2012 07:16 AM
Clutch basket q's *searched* iceman.kcmo 1986 - 2007 Ninja 250R Tech Talk 11 February 10th, 2012 09:10 PM
Replacing clutch basket on 88 gpx RII qwaka 1986 - 2007 Ninja 250R Tech Talk 5 August 28th, 2011 04:52 PM
Play in Clutch Basket Normal? *Video Inside shiftdrift06 1986 - 2007 Ninja 250R Tech Talk 2 April 21st, 2011 04:52 PM
