Old July 14th, 2011, 05:56 PM   #1
Archerzz
Motorcycle(s): 2007 Ninja 250r
Clutch Adjustment?
So I had to move my bike today and I alwyas park in first gear so I just hopped on and pulled the clutch and i noticed that it was resisting like the clutch wasnt being engaged the whole way. So basically the question is when I pull the clutch in gear should I be able to push the bike as if its in neutral?
If so should I tighten the clutch?
Archerzz is offline   Reply With Quote
Old July 15th, 2011, 06:24 AM   #2
dubojr1
dubojr1's Avatar
Yes you should be able to push it and I would say if the clutch functions correctly when your riding, then no adjustment is needed.
Old July 15th, 2011, 09:23 AM   #3
you're fine. mine does this too when its totally cold and I pull in the clutch. the plates don't separate the whole way. it's the same reason the bike lurches a bit when you first put it into gear. let go of the clutch. grab it again, then push like hell. it's a bit rough to get the plates to let go the first time when it's off and cold. or just put it in neutral if you have to move it.
Old July 15th, 2011, 01:59 PM   #4
Archerzz
Ok thanks, thats what I thought. I will have to check it out when it is warmed up and the clutch functions fine while riding so I was not overly concerned about it.
One thing when I start it in first gear it kinda pulls forward a little bit, is that the same reason as why it lurches when it is put in first?
Old July 15th, 2011, 02:13 PM   #5
http://faq.ninja250.org/wiki/My_bike...this_normal%3F
Old July 15th, 2011, 02:33 PM   #6
yes. it's the same
Clutch Adjustment JBinSD 2013 - 2017 Ninja 300 Tech Talk 12 February 11th, 2017 09:42 PM
Lighting, clutch adjustment and more yogurtpooh 2008 - 2012 Ninja 250R Tech Talk 13 December 3rd, 2014 07:09 PM
Clutch adjustment bolts peter330 2008 - 2012 Ninja 250R Tech Talk 2 June 1st, 2010 03:59 PM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
Clutch cable adjustment SteveL 2008 - 2012 Ninja 250R Tech Talk 2 August 17th, 2009 12:39 AM
