April 24th, 2011, 04:50 PM | #1 |
Drive chain life expectancy?
OK so I got my bike with 6400 miles. I didn't lube it for about 2500 miles because frankly, I'm a teenager and didn't think twice about it at the time. Well I've been lubing it every 400 miles since then and cleaning it every 3rd lubing, or cleaning it the lubing after getting caught in the rain. (btw my bike currently has 10,500 and change on it) Honestly, the bike was in good condition aside from gummed up carbs when I bought it, and it had both the first scheduled maintenance and its' 6000 mile valve check, so I'm assuming that the PO lubed the chain for those 6400 miles, but I really don't know.
Anyhow, my question is, with my current maintenance and previous maintenance, what do you think I should expect mileage-wise out of my chain? I keep it at the proper tension (35-45mm), I clean/lube it regularly, and I would like to have some sort of idea what to look for as a sign that it's on its' way out, and when to expect this to happen. I've already budgeted for a valve check at 12k, and if I need to budget in a new chain/sprockets as well I will do that. Sorry for this long post, I was perusing ninja250.org and was reading about chains and they said that with minimal care, expect 10k-13k out of a chain and kind of freaked out when I thought of what kind of damage a chain could do to me/my bike if it broke while I was moving |
April 25th, 2011, 06:58 AM | #2 |
The factory chain is an O-ring chain so it's considered permanently lubricated internally. The main thing cleaning and lubing does is to extend the life of the external chain roller surface and the sprockets. My first chain died after 20,000 miles, right at the end of back to back 800 mile runs at 80+ mph with full saddlebags. Sprockets still look new, no hooking, cupping, or visible wear for that matter. I lube every tank full and whenever it gets ridden in the rain.
May 19th, 2011, 09:32 PM | #3 | |
May 20th, 2011, 06:27 AM | #4 |
Several pins wore excessively internally, causing some sections of the chain to be stretched by 1/8". I run a 15T front so there's minimal room from the chain to the inside of the front cover. The stretched links froze and rode up on the front sprocket teeth, wearing shallow grooves into the aluminum. It manifested as a rhythmic lurching sensation accompanied by odd noises when I accelerated.
I've got an X-ring chain on there now, was $70-something shipped off Amazon. The sprockets still look new, no cupping of teeth or noticeable change in tooth profile. |
May 20th, 2011, 07:57 AM | #5 | |
May 20th, 2011, 10:40 AM | #6 | |
FWIW, I use Castrol Chain Wax on my chain every 200 or so miles and after every rain ride. I don't clean, scrub, scrape, brush, or obsess. Just spray it on and wipe off the excess with a rag, done. The buildup in between the chain sideplates, which would be removed by cleaning with a brush, keeps grit and dirt away from the X-rings. When I got the bike with 2K miles the chain was bone dry, showing no signs of ever having been lubricated, FWIW. |
May 20th, 2011, 10:46 AM | #7 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Well...I got 9800 miles and my chain is pretty much shot, along with the front sprocket.
The front sprocket is showing signs of hooking, and the chain is stretched. Im not a wheelie junkie or anything like that, but I do whomp on it when I feel like it. Also, chain was properly maintained...lubed every 400 miles, and tension adjusted properly per kawasaki specs. Oddly enough, the rear sprocket shows no signs of wear at all. Ill have to mic the teeth and check for runout on warpage, but it appears 100% good to go. |
May 20th, 2011, 11:58 AM | #8 | |
Canadian guys and parts... (Drive chain/sprockets) | sidekick10121 | 1986 - 2007 Ninja 250R Tech Talk | 1 | May 24th, 2014 04:40 PM |
[motorcyclistonline] - Drive Chain Maintenance | Drive Time | Ninjette Newsbot | Motorcycling News | 0 | May 9th, 2013 05:30 PM |
[topix.net] - Bikers join Bread of Life ministry for toy drive | Ninjette Newsbot | Motorcycling News | 0 | December 25th, 2011 12:20 AM |
Drive Chain Advice! | EvnEvn724 | 1986 - 2007 Ninja 250R Tech Talk | 1 | August 22nd, 2011 04:15 PM |
