June 23rd, 2014, 03:05 PM | #1 |
Join Date: Mar 2014 Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R Posts: 256
Aftermarket V-Rossi wheels bearings are cheap
Curious, anyone with the V-rossi wheels 4.5" ones use the bearings that came with it? I did and the bearings after 1 week of riding are bad. They're clunking now and I had to order OEM bearings/bushings. So my advice, if you got these wheels from Indonesia, replace the bearings and bushings cause it's dangerous to ride with the ones that comes with it.
June 23rd, 2014, 03:21 PM | #2 | |
June 24th, 2014, 11:06 AM | #3 |
EX500 full of EX250 parts
Yup, I bought All Balls bearings (25-1444 front and 25-1234 rear, about $25 total from Amazon) just to be safe. I also bought new spacer collars that go in between the bearings - the 500 uses a different size in the front, so I needed to buy the 250 version, and buying the rear one meant that I could assemble the new wheels without removing and tearing into the stockers.
After spending as much as I did on the new wheels and tires, a few extra bucks for bearings and spacers to avoid extra work and possible quality issues seemed like a no-brainer. Here's a pic of the OEM rear spacer collar compared to the one that came in my VRossi wheel. As I've said multiple times, do whatever you want with your own bike and money, but one of those looks a whole lot better to me than the other one. Make up your own mind whether that's worth $11 to you.
June 24th, 2014, 12:35 PM | #4 |
Agreed. That's totally worth $11. Bearings + spacers OEM costed me $60, but hells, I rather spend $60 than go down when the cheap bearings explode on the freeway.
Stock wheel vs aftermarket wheels | Bigballsofpaint | Ninjettes At Speed | 86 | September 13th, 2014 11:17 AM |
cheap dented aftermarket exh | ninja250 | Items Wanted | 5 | October 23rd, 2011 09:14 PM |
[sportrider - tech] - Aftermarket Wheels, Overheating And Oil Changing | Ninjette Newsbot | Motorcycling News | 0 | April 13th, 2010 04:00 AM |
[sportrider - tech] - Aftermarket Wheels, Overheating And Oil Changing | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2010 11:40 PM |
[sportrider - tech] - Aftermarket Wheels, Overheating And Oil Changing | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2009 01:23 PM |
