July 31st, 2014, 07:04 PM | #1 |
Join Date: Jul 2014 Motorcycle(s): 2006 Honda ST1300, 2001 Ninja 250 Posts: 53
Question about throttle
Oops! Just noticed I put this in the wrong year's section. Sorry. Still should apply to all years, though.
My 2001 Ninja that I just bought had the rubber grip on the throttle slipping fairly freely on the throttle sleeve. I could squeeze it and turn the throttle ok. The throttle sleeve returned fine under the spring action. I did something that was probably stupid. I tried to squirt some super glue between the rubber grip and the throttle sleeve. I must have gotten some under the throttle sleeve. I can still turn it pretty easily, but it is glued just enough that it does not snap back on its own. Any suggestions for freeing that back up? Last futzed with by amad1972; July 31st, 2014 at 07:05 PM. Reason: put in wrong section |
July 31st, 2014, 08:04 PM | #2 | |
Blind 250 Loving Whore
It's not really that bad. http://faq.ninja250.org/wiki/Throttl...is/re-assembly |
August 2nd, 2014, 04:45 PM | #3 |
Throttle control is a dangerous thing when not working as planned by the manufacturer.
If you post some pictures, we could help you install it properly.
August 2nd, 2014, 06:03 PM | #4 |
I got it all taken apart today and cleaned up. That bar end bolt was a bugger to get off. Heat didn't work. Drilling didn't work. I finally used a dremel and about 2 hours to grind the head off enough to get the weight off. Then used vice grips to get the bolt out. Throttle works as it should now.
August 2nd, 2014, 06:10 PM | #5 |
Good to hear you got it all worked out. Those bolts are a pain. I needed a torch and impact.
Full throttle kills bike, throttle lag response. | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 30th, 2014 03:25 AM |
Question about throttle on larger bikes | Jiggles | General Motorcycling Discussion | 47 | September 27th, 2012 06:43 PM |
[twisted throttle] - Visit the Twisted Throttle Open House & 10th Anniversary Party o | Ninjette Newsbot | Motorcycling News | 0 | April 13th, 2012 08:00 AM |
Throttle & Throttle Cable Smoothness | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | December 1st, 2009 01:50 PM |
Dan Kyle's Quick turn throttle question | Gregular | 2008 - 2012 Ninja 250R Tech Talk | 7 | February 28th, 2009 03:14 AM |
