Old July 27th, 2011, 06:23 AM   #1
peeweecollins
peeweecollins's Avatar
Motorcycle(s): 06 ninja 250
Excessive crankcase pressure
I'm having trouble with oil and smoke going into the air box stalling the engine. I unhooked the s shaped hose off air box and the bike runs fine, but What do I do about the base Pressure I heard that's is a common problem with the 06 ninja something called the internal breather tube. I wanted to know could this be the problem and not bad piston rings and if so is this an exspensive repair the bike only has 7k miles on it so I don't think it could be the rings. Any help and advice wil be appreciated thx
peeweecollins is offline   Reply With Quote
Old July 27th, 2011, 08:15 AM   #2
Jinx250
Smoker
Motorcycle(s): Guess....
What planet are you from? The 06 is no different mechaincally than the other engines in the 88-07 line.
Using deductive reasoning, if the bike stalled, but then ran fine when you disconnected the breather hose, then that means the hose itself is blocked. If the crank is blowing smoke out of the breather then the rings are probably bad and it's cheaper to replace the engine.
Jinx250 is offline   Reply With Quote
Old July 27th, 2011, 08:32 AM   #3
peeweecollins
The reason I specified 06 was because after a little research I found this was a common problem with the bikes manufactured in that year breather tube not connected properly possable recall and the smoke is more like an oily mist and when you hold your finger over the hose coming from the crankcase you can feel the pressure build other than that the bike does not smoke from the exhaust
Maintenance schedule excessive? isuoboe 1986 - 2007 Ninja 250R Tech Talk 20 January 23rd, 2015 04:19 PM
Excessive engine noise and no acceleration "G-Man" 1986 - 2007 Ninja 250R Tech Talk 24 July 20th, 2013 10:07 PM
GPR v4 Damper for track/Racing...excessive or good to have tooblekain Ninjettes At Speed 15 May 22nd, 2012 07:15 PM
New Brake Problems (Excessive Lever Travel) fsilva_mcl 2008 - 2012 Ninja 250R Tech Talk 6 May 19th, 2010 01:02 PM
[motorcyclenews.com] - Damage done to biking by excessive speeders Ninjette Newsbot Motorcycling News 0 August 12th, 2008 08:32 AM
