Old April 6th, 2011, 09:25 AM   #1
M
Motorcycle(s): Ninja 250 x2, Ninja 650R
FS '88-07 Ninja 250 | five bikes part-out | updated 040611
I have some Ninja 250 parts that I'm selling. 98% of these parts are from 250's that are between '00-'06. A few parts are from a '96 model. All parts listed are compatible with '88'-07 (wiring harness, regulator will be different for '88-'93).
I've listed each part with a picture. My pricing is typically within the range of 15-25% of OEM. Prices do not include shipping, so let me know your destination. I'll gladly combine parts to save you money on shipping.
This list is not complete of all my parts, but is about 90%. I have an '06 with many parts that are duplicates of these listed below. I also have many internal engine parts both from an '00 engine and an '05 engine. Let me know if you have internal parts needs.
I do not 'hold' parts. First one to pay via PayPal gets the parts. This policy is due to many, many potential buyers who have me 'hold' a part while they spend the next ten days shopping for a better price.
If you are near Oklahoma, local pick up is available. Also, if you are buying more than $500 in parts at one time, I may deliver to you for a charge, if you are within 500 miles or so of Coweta, OK.
The donor bikes:
250 parts:
air filter bracket | $3
air filter case assembly | $20
air filter strap | SOLD
axle, front | $10
battery tray | $8 - SOLD
battery wire leads & 30A starter switch | $15
brake caliper assembly, front | $35
brake caliper assembly, rear | $30
brake line, rear assembly | $20
brake line, front w/ bracket | $10
brake, front hose clamp | $3
brake, rear hose | $8
brake pedal, rear & master cyclinder / brake line | $30
brake master assembly, front | $40 - SOLD
brake master assembly, front w/ caliper |70
brake master assembly, rear | $10
brake reservoir, front | $25
brake switch | $5
carb. boots | $10
carbs. 2005 in very good condition | $125 - SOLD
carbs, 2006 in excellent condition | $150
cargo clips, four | $15
cargo clips, three | $10
center stand | $35 - SOLD
cable, clutch | $7
cable, clutch | $7
cable, speedometer | $7 - SOLD
cable, starter | $7
cable, throttle opening | $7
cable, throttle closing | $7
chain cover | $12
chain cover | $12
chain cover | $12
chain guard | $7
controls, left | $30 - SOLD
controls, left w/ clutch cable | $30
controls, right | $30 - SOLD
controls, right harness | $20
picture two
cowling, lower | $65 - SOLD
picture two
picture three
cowling, lower bracket | $3
cowling, lower bracket | $5
engine bolts | $6
engine mounts, L & R | $30
exhaust, Cobra F1r | $150 - SOLD
engine parts, internal | enquire
exhaust, w/ scratches, no leaks | $35
exhaust headers | $25
exhaust stay, L | $12.50 - SOLD
exhaust stay, R | $12.50
fender, front | $40 - SOLD
fender, rear FR | $15
fender, rear w/ turn signals & reflectors | $40
footpeg, L front & stay | $25
footpeg, L & stay w/ shifter assembly | SOLD
footpeg, L rear | $10
footpeg, R front & stay w/ brake pedal & master cylinder | $35
foot peg, R front & stay w/ brake pedal & master cylinder | $35
footpeg, R rear | $10
footpeg, right R | $10
fork holder, lower w/ bearings | $40
fork, upper | $25
forks, L & R | $125
fuel tank dampers | $5
fuse / junction box | $20
picture two
gear lever assembly | $10
gear lever assembly | $15
handle bar, left (approx. 5* bend in the bar) | $10 - SOLD
handle bar, left w/ riser (approx. 3* bend in the bar) | $35 - SOLD
handle bar, left w/ riser | $35 - SOLD
handle bar, right w/ riser | $35 - SOLD
handle bar, right W/ throttle sleeve | $25 - SOLD
handle bar, right w/ throttle sleeve | $25 - SOLD
harness, main | $25
harness, main | $25
harness, main | $25 - SOLD
headlight | $45 - SOLD
horn | $8
horn | $10
horn & bracket | $13
igniter | $45
igniter | $45
ignition coils & caps | $35
instrument cluster | $125 - SOLD
instrument cluster w/ replacement cover, 1 broken tab | $65
picture two
picture three
instrument cluster wiring harness | $12
lock set, complete w/ two keys | $100 - SOLD
petcock | $25
radiator & fan | $110 - SOLD
radiator & fan | $125 - SOLD
picture two
picture two
picture two
radiator reservoir | $7
radiator reservoir & hoses | $10
radiator cap assembly | $10
radiator cap assembly | $15
radiator cap assembly | $25 - SOLD
regulator, voltage | $25
rear grip | $20
rear grip | $20
reflectors | $5 each
rocker arms | $20 each
seat, minor tears | $25 - SOLD
seat | $60 - SOLD
seat front latch | $5
shock | $35
shock | $35
shock | $35 - SOLD
side stand w/ switch | $25
signal covers | $5
speedometer | $40
speedometer gear | $15
speedometer gear & cable | $22
sprocket cover | $25
starter switch & leads | $25
picture two
swingarm | $60
swingarm | $60 - SOLD
swingarm caps | $5
tachometer | $30
tail cover & rear grip | $30
picture two
picture three
tail cover | $20
picture two
picture thre
tail lamp | $45
tank / seat bracket | $5
temperature gauge | $13
thermostat & sensor | $20
thermostat & sensor | $25
throttle sleeve | $5
tool tray | $5
tool tray | $5
turn signal relay | $10
uni trak arm | $20
uni trak tie rods | $25
uni trak, tie rods & arm | $45
wind screen | $25 - SOLD
wind screen | $35 - SOLD
The Rally - Oklahoma
M is offline   Reply With Quote
Old May 20th, 2011, 08:55 AM   #2
TDM Ohio
Motorcycle(s): 1972 T150 Trident, 1981 CB125S, 1992 TDM-850, 2002 VTX-600, 2003 Ninja 250, 1986 KX-80
PM sent.
TDM Ohio is offline   Reply With Quote
Old May 20th, 2011, 04:50 PM   #3
Hemi4cs
Hemi4cs's Avatar
Motorcycle(s): Ninja 250 and a YZF 600R
red upper? 22701
The kids are finally old enough I can start riding again!
Hemi4cs is offline   Reply With Quote
Old May 20th, 2011, 05:54 PM   #4
CZroe
CZroe's Avatar
Wow. There's a Coweta, OK? I grew up in Coweta County, GA and never heard it used to reference anything else but the Indians it was named after. I guess they moved west.
Old June 11th, 2011, 10:08 AM   #5
M
Hi,
The red upper has sold. All PMs up to 061111 have been answered.
Old June 20th, 2011, 01:57 PM   #6
Donnyd21
Motorcycle(s): 2008 250R
I could use a good seat if you have one, left handlebar and left rear side cover rubber groumet that slides into the tank. I am in Oklahoma City. Whats wrong with the bikes in the 1st 2 pics? Pm me if you have those parts still
Donnyd21 is offline   Reply With Quote
Old June 21st, 2011, 05:42 AM   #7
M
I don't currently have a seat for sale. I do have a LT handlebar with about a 5* bend in it (see my pics in the original post). I do have the rubber tank bumpers.
The first two bikes each had blown engines (ran out of oil by the previous owners).
Old June 23rd, 2011, 09:36 PM   #8
cerberusrex25
Accesories Guru
cerberusrex25's Avatar
Motorcycle(s): '99 EX250(Cafe/fighter project)
If you guys have not bough something from this lot, or need a part, I suggest you get on this. M is an excellent seller and his stuff is in great condition.
cerberusrex25 is offline   Reply With Quote
Old June 27th, 2011, 01:46 AM   #9
cuong-nutz
cuong-nutz's Avatar
Do you have any more handle bars or a front left turn signal?
HalfFast Racing Team
Old June 27th, 2011, 06:49 AM   #10
M
I do have a LT front turn signal. The base isn't included. It would be $20 shipped within the CONUS.
Old June 29th, 2011, 05:28 PM   #11
cuong-nutz
cuong-nutz's Avatar
Do you have any stock levers? Needing both clutch and brake that aren't bent or broken. I'll take the turn signal with it as well if you have them.
Old July 9th, 2011, 06:15 AM   #12
M
I have a front brake lever, that has a paint scratch on the ball end. The lever is straight.
It'd be $16 shipped for both.
Old July 9th, 2011, 08:56 AM   #13
cool_hand_luke_12
cool_hand_luke_12's Avatar
Motorcycle(s): 1998 Kawasaki Ninja Ex250
hey do you have a front fairing for a ex250?
cool_hand_luke_12 is offline   Reply With Quote
Old July 10th, 2011, 11:50 AM   #14
M
Hi,
All my upper and lower fairings have been sold.
Old July 11th, 2011, 09:43 PM   #15
03slime250
Motorcycle(s): 2003 ninja 250
have a front master cylinder?
03slime250 is offline   Reply With Quote
Old July 15th, 2011, 10:53 PM   #16
streetracer744
Ninja ZX-5R
streetracer744's Avatar
can i buy a set of rear pegs..I need both left and right pegs
2002 Ninja 500r....Mod friendly
streetracer744 is offline   Reply With Quote
Old July 20th, 2011, 07:35 PM   #17
M
I'll check on both the front master cylinder and the rear pegs. It may be the weekend before I can check.
Old July 20th, 2011, 08:07 PM   #18
03slime250
Already found a mc, thanks tho
Old July 21st, 2011, 03:39 PM   #19
dirtyrottenninja
Motorcycle(s): ninja 250
i need some parts please
i could use a 2 intake valves, 2 inener and 2 outer springs ,2keepers,2retainers ,etc, and a 4 rocker arms ,i also need the two side brackets (left and right ) for the chin fairing and bolts ,1 rubber bushing thing for the tank mount, , im in phoenix 85032 thanks steve
dirtyrottenninja is offline   Reply With Quote
Old July 24th, 2011, 11:54 AM   #20
M
Hi Steve,
I'll ship you an entire upper head with all the valves & springs, keepers, etc. for $50. You can pull the valves, etc. that you want. The rocker arms are $20 each ($80 for four). Can you give me parts numbers for the chin fairing/bolts as I can't picture them. The tank mount bushing would be $3. Shipping for everything would be $20.
Old July 24th, 2011, 05:14 PM   #21
xbox3bob
Motorcycle(s): EX250F
hello, i need to buy a left fork, and a right turn signal how much woudl that be?
xbox3bob is offline   Reply With Quote
Old July 25th, 2011, 04:14 AM   #22
M
Forks are sold only as a pair. They're $125 + shipping. I've sold all of my turn signals.
Old July 25th, 2011, 02:46 PM   #23
xbox3bob
Forks
sounds good ill take the forks. and can we exchange information?
Old July 25th, 2011, 03:26 PM   #24
xbox3bob
or ur paypal info so i can give u the money
Old July 28th, 2011, 07:11 AM   #25
A7xschecter6661
A7xschecter6661's Avatar
Motorcycle(s): 2003 Yamaha R6
Since some of the fairings are broken would you be willing to sell a few of the bolts/grommets for the fairings and side panels if you have any left? Idea on a price if so?
A7xschecter6661 is offline   Reply With Quote
Old July 28th, 2011, 09:59 AM   #26
M
Payment received, I'll let you know when the parts have been shipped via FedEx.
Old July 28th, 2011, 10:01 AM   #27
M
Which bolts/grommets do you need?
Old August 2nd, 2011, 09:24 PM   #28
A7xschecter6661
Just the bolts and grommets around the bottom fairing and the 4 side grommets for the back of the side panels (2 each side)
Old August 12th, 2011, 10:22 AM   #29
M
Sorry, I do not have those.
Old August 14th, 2011, 12:03 PM   #30
You still have the petcock? if so, does it leak at all? mine leaks on the "on" position.
Old August 14th, 2011, 01:25 PM   #31
M
I do have it, it'd be $35 shipped within CONUS. It doesn't leak. The internal filter at the top is a bit cracked, but it doesn't impede the petcock use.
Old August 22nd, 2011, 05:30 PM   #32
modemagic
modemagic's Avatar
Motorcycle(s): 2000 Ninja 250
Do you have a brake pedal? What about a stock exhaust in good shape? (No major scraps/dents)
modemagic is offline   Reply With Quote
Old August 22nd, 2011, 05:57 PM   #33
Palero
Palero's Avatar
Motorcycle(s): 1988 Honda Hawk GT 1989 EX250F (Died from left-turning car) 2011 EX250J (Died from SAME left-turning car)
Upper fairing stay available?
Palero is offline   Reply With Quote
Old August 24th, 2011, 08:33 PM   #34
M
No upper fairing stays left, sorry!
Old September 7th, 2011, 05:25 PM   #35
I'm still interested. I can't order it at the moment. I have fall break in a few weeks. If you still have it then, I'll order it. If it's sold, then it's my loss.
Old September 20th, 2011, 06:33 AM   #36
M
I still have the petcock. Feel free to PM me or e-mail me. Shipping would be $7 within CONUS.
Old October 7th, 2011, 09:49 PM   #37
03slime250
Clutch lever and perch?
Old May 15th, 2012, 12:39 AM   #38
Major_Paine
Motorcycle(s): 2004 ninja 250 (in progress), 2009 cbr600rr
footpeg, L front & stay (http://www.hickmans.us/ninja250/2000/022809_039.jpg) | $25
do you still have this part?
Major_Paine is offline   Reply With Quote
Old May 18th, 2012, 03:18 PM   #39
drdriftking007
Drdriftking007
drdriftking007's Avatar
Please
Do you have a fairing stay bracket? Would pick up
also do you left and right turn signals? and another seat?
drdriftking007 is offline   Reply With Quote
Old May 18th, 2012, 07:33 PM   #40
Major_Paine
i hope you still check this thread..
Part Out 2010 Blue Ninja 250 Jred Motorcycle-related 63 January 19th, 2014 10:06 PM
2001 Ninja 250 Part out hawker1693 Motorcycle-related 33 September 30th, 2013 08:20 PM
WTB : 08+ Ninja 250 Carb Part abhijitz Items Wanted 0 July 29th, 2012 08:12 PM
08' Ninja 250 Parts bike part out *you name the part and price* BuckyNaked Motorcycle-related 106 July 12th, 2011 02:01 PM
04 ninja 250 part out. - SOLD bamaland Motorcycle-related 6 September 18th, 2010 08:27 AM
