July 19th, 2013, 05:59 PM | #1 |
Low End Problems
Reference thread: http://www.ninjette.org/forums/showt...021#post714021
(thread got a little off track with un-needed info) Similar threads:http://www.ninjette.org/forums/showt...sensor+trouble http://www.ninjette.org/forums/showt...sensor+trouble http://www.ninjette.org/forums/showt...sensor+trouble These guys had the same or similar problems and each thread seemed to die like my last one. To restate the problem, When the bike is idling it runs fine, with the choke on it runes fine. If you try to give it some gas it wants to die. IF and only IF I can push it past the 3-5k range the bike will run fine. Within this 3-5k range there is a ton of popping and surging of power. This problem points to fuel delivery but the carbs are spotless and everything is working fine within them that i can test. The only other option with carburetion is vacuums, which I am unsure of. Rain was heavy the days leading up to the problems which sends me in the direction of electrical. What electrical problem could do this? I'm running out of ideas and if we cant figure it out why would the 100$/hr mechanic be able to? Compression is tested, no foreign debris or anything blocking up anything. Fuel rune smoothly through jets. Spark plugs have been replaced. how can I test for IC igniter trouble Crankshaft sensor trouble Ignition coil trouble I tried searching but got nothing Please help... |
July 19th, 2013, 06:52 PM | #2 |
Join Date: Mar 2013 Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only Posts: 150
Where ya at in south Florida?
I was having an issue with rpm return when my idle was too high. I just looked at your video though so what you asked here was different than what was happening. Are you letting it warm up before giving it that much gas? Does it still do that if the choke is on?
http://www.1000rr.net/forums/showthread.php?t=90412 http://www.8thcivic.com/forums/ http://www.facebook.com/profile.php?id=1209877267 |
July 19th, 2013, 07:05 PM | #3 | |
If i can push it past 5k rpm i can ride the bike but one i try to get back down to idle as soon as it passes through 3-5k again it wants to die. |
July 19th, 2013, 08:02 PM | #4 | |
Some = same im assuming typo? Im not sure but Are you throttle cables adjusted properly are they actually turning the butterflies? Did you physically clean the idle ports with a metal wire not just look inside and see some light? If you need an extra set of hands let me know
July 19th, 2013, 08:22 PM | #5 | |
The cables are on correct and are opening butterflies based on what i could see when I had the airbox off. I Sprayed carb cleaner through every jet hole and it comes flying through every hole it's supposed to. Just did a ohms test on the crankshaft sensor and came back pretty good. I have access to a trailer if need be. If you think you could help out at all I wouldn't mind a third pair of eyes. I'm home bound till this is fixed. My only transportation. |
July 19th, 2013, 08:38 PM | #6 |
I'd completely drain the gas tank and float bowls and refill with fresh 87 octane - without Ethanol if available.
July 19th, 2013, 08:46 PM | #7 |
Wish i knew earlier my carbs are off my bike in PSL and id let you use them to trouble shoot if its a carb issue!
July 19th, 2013, 08:48 PM | #8 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
My guess is water in the gas. As my buddy jkv stated ethanol free 87.
July 20th, 2013, 07:46 AM | #9 |
July 20th, 2013, 08:46 AM | #10 |
Drain the float bowls. There may be old gas in the carbs. Just because there is new gas in the tank doesn't mean its going into the engine.
July 20th, 2013, 09:35 AM | #11 | |
This is one of the reasons I don't think its the carbs anymore |
July 20th, 2013, 10:19 AM | #12 | |
I still think it's carb/diaphragm/fuel related, but I can't prove that. EDIT: I have experienced odd running problems where an engine will not take throttle or rev properly that were caused by bad fuel, but if you're sure it's fresh... Last futzed with by jkv45; July 20th, 2013 at 11:56 AM. Reason: additional info |
July 20th, 2013, 10:22 AM | #13 |
July 20th, 2013, 10:23 AM | #14 |
The diaphrams aren't cracked or anything? Seems to me that the slides aren't moving. Take the washers out from the carbs it sounds like its hanging up and not allowing more fuel in when the throttle opening increases.
July 20th, 2013, 10:47 AM | #15 |
The slides are moving, i took off the airbox and watched them, they have no cracks or slits.
July 20th, 2013, 11:04 AM | #16 |
Are they moving all the way? That's what I would put my money on. If nothing else maybe the cdi box advance curve is somehow messed up
July 20th, 2013, 11:22 AM | #17 | |
some local non ethanol gas stations
July 20th, 2013, 01:13 PM | #18 |
The ethanol isn't going to be the root of the problem its just a good idea. See if you can plug in another cdi to check if its bad.
July 20th, 2013, 01:27 PM | #19 |
Yeah the slides moved up all the way. Like I said the top end is all there, if I can get it to rev past 5k with careful throttle maneuvering it will be ride-able. The only problem is sometimes it will not make it past that 5k mark.
July 20th, 2013, 01:37 PM | #20 |
There is different advance curve for different rpms so maybe it is electrical.
July 20th, 2013, 06:04 PM | #21 |
July 20th, 2013, 08:31 PM | #22 |
The cdi box. Its on the tail section under some cover. Its made by denso. If you have a buddy with the same bike swap it out its plug n play. If it fixes it you know what the problem is.
Low end power?? | gregoryl | 1986 - 2007 Ninja 250R Tech Talk | 16 | December 1st, 2014 09:32 AM |
Low end adjustment help | Noobman | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 9th, 2014 08:51 PM |
improving low end power | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 16 | November 17th, 2013 05:37 PM |
How to end a bad day? Low-side in the rain. | Monkeytofu | !%@*#$%!)@#&!%@ I crashed! | 28 | October 24th, 2012 04:12 PM |
low speed collision. need help to find problems on the bike. | ZackoFF96 | !%@*#$%!)@#&!%@ I crashed! | 13 | July 25th, 2012 08:09 AM |
