July 12th, 2014, 10:42 AM | #1 |
Join Date: Jul 2014 Motorcycle(s): 2011 Ninja 250R (Sold), 2015 Rocky Mountain Soul (Runs on fat) Posts: 404
Wider tire in the back?
Hi,
I curently have a 130/70 tire in the back, which is the stock size. I was wondering, will a 140/70 or 150/70 fit on the stock rim? Also, will it interfere with anything? What are your thoughts? |
July 12th, 2014, 10:54 AM | #2 |
Daily Jap rider
Join Date: Dec 2012 Motorcycle(s): 2012 Ninja 250r Posts: A lot.
I have a 140 kenda on mine. if you do a google search or ninjettewiki search you will find tons of threads on this subject. 150's will fit, but just barely.
July 12th, 2014, 12:19 PM | #3 |
Urban Legend
Join Date: Apr 2014 Motorcycle(s): 09 Ninja 250R SE - Circe Posts: 542
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up." -Baron |
July 12th, 2014, 12:30 PM | #4 |
Certified looney toon
MOTM Jul '13, Jul '14
I've run 140's in both Pirelli DRIIs and Bridgestone BT45s with no fitment issues. I've heard Michelin PR4s 150's will just fit, but since I have a hugger and some wires running between the tire and swingarm, I haven't wanted to risk anything rubbing.
July 12th, 2014, 05:03 PM | #5 |
Wannabe Reborn
Not thread jacking, but just offering choices. Heard a lot of noise about the Michelin Pilot Street tires when they first hit the scene, just haven't heard any ride reviews. Unfortunately, every one is out of stock of these tires. Whats up with that? Was about to scoop a 140.
Generally, going to 140 won't hurt. Just understand that the bike was designed for a 110 up front, 130 in rear. Changing will change the lean in, and many aspects, some of which you may not notice. I have a 120/130 on mine from the previous owner. My lean in is completely different. Not a solid curve from straight up to lean. More aggressive at end of lean. I was hoping a 140 in the rear would help, but not many with a setup like mine. Whatever you choose let us know.
July 12th, 2014, 06:43 PM | #6 |
140 will be more useable then a 150, I currently have a 140 on my rear and a centimeter of thread left after a track weekend. the 150 has about an inch of unused thread. the 150 thread unused is pretty much perpendicular to the road surface when mounted.
July 12th, 2014, 09:27 PM | #7 |
You will need to lean your bike a little more for same speed and turn, your suspension will work a little less effectively and you will force the frontal tire to go to the limit (edge) before the rear reaches similar point.
July 13th, 2014, 06:47 PM | #8 |
Join Date: Jan 2014 Motorcycle(s): SC28 Fireblade Posts: 463
When I first bought my bike it had 150/60-17, it works without any mod; however, 140/70-17 would be better for the bike. It sucks there's not a lot of OEM tire selections for our bike. It would be cool if B-Stone made BT-003 for 130/70-17.
94 900RR 04 BMW Z4 2.5 M Package 01 R170 AMG Sport Package |
July 13th, 2014, 08:20 PM | #9 |
I'm using a 140/70 with no issues whatsoever
July 13th, 2014, 11:35 PM | #10 |
Freedom for Germany
Without changing the rim the 140/70 will be the better choice because it fits the 3.50 inch rim but the 150/60, which has nearly the same circumference like the 130/70, needs a 4.00 inch rim already.
July 16th, 2014, 04:13 AM | #11 |
So, you're saying it's better to stick with factory size?
July 16th, 2014, 07:03 AM | #12 |
Long Time Rider
July 16th, 2014, 07:42 AM | #13 | |
Join Date: May 2014 Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F Posts: 588
You can try it. Worst that will happen is you ride it for a few thousand miles and change back. Or if you really hate it, take it off and sell to someone for slightly less than you paid. |
July 16th, 2014, 08:12 AM | #14 |
Join Date: Sep 2010 Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty Posts: A lot.
This is my goal:
July 16th, 2014, 04:00 PM | #15 |
Better is relative.
Those were just the thoughts of mine for which you asked. People who know about, design and manufacture these machines, try using the bigger diameter, the minimum profile and the lightest possible tires for a determined purpose. What is better for one purpose may be worse for another. There must be a reason for not seeing scooters or Batcycles at MotoGP or Motocross races.
July 16th, 2014, 04:05 PM | #16 |
Join Date: Oct 2012 Motorcycle(s): '04 R1 and '08 Ninja 250 Posts: 222
Draik runs Pirelli Diablo SC1 110/150 and absolutely loves that set up. He's got about 1/4" on the front and 3/4" on the rear left but never has to worry about "running out of tire" like he was doing with a 120/140 Bridgestone set up.
There are no clearance issues with the Pirelli 150.
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son |
July 16th, 2014, 04:26 PM | #17 |
July 19th, 2014, 04:48 AM | #18 |
Join Date: Jul 2014 Motorcycle(s): 08 ninja 250r Posts: 1
I've just put on Michelin Pilot Power 120/60 and 150/60, didn't mod, all factory stuff.
I haven't got any problem like can't fit or rubbing on my swingarm. btw I'm 65kg For the other people said it will lose power or hardly lean, honestly I can't notice that at all. |
July 19th, 2014, 09:53 AM | #19 |
Did anyone say 180?
The most dangerous risk of all is the risk of spending your life not doing what you want... |
July 19th, 2014, 10:22 AM | #20 |
Join Date: Mar 2014 Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R Posts: 256
Yeah, but you'd have to get new swing arms and it'll be extended out looking like a drag bike (this photo set has a side view). 140 would be perfect for stock wheel. 150 fits but it will pinch and road contact will be minimized. I had 150 on my stock wheel and it didn't feel too great as it was pinched and the tires weren't rounded. I went with 4.5" wheel and now the 150 fits perfect and looks wider than when it was on stock wheel.
July 21st, 2014, 02:19 AM | #21 |
Join Date: May 2014 Motorcycle(s): ninja 250R 2009 Posts: 4
Is it ok if I have a 150/60 Pilot Power in the back and 110/70 stock in the front?
July 21st, 2014, 07:44 AM | #22 | |
MOTM - June '15
I have the stock 130 and love it. we dont have any curves, but I have 2000+ miles on mine and it's just starting to square off. I guess I need to go back to TN!
July 22nd, 2014, 04:38 AM | #23 |
What about 140/80-17 or 130/80-17? I found a guy who has these tires and has a good deal on them.
July 22nd, 2014, 06:08 AM | #24 | |
Long Time Rider
On the avg., your profile will be high. Instead of a tire circumference of 75-77" (130/70/17 & 140/70/17) it will be more like 80-82". In other words your tires will look like big ass ballons and be a very tight fit, if it fits at all. |
July 22nd, 2014, 11:22 AM | #25 |
Long Time Rider
Pic of a 130/80/17
July 22nd, 2014, 12:48 PM | #26 |
Not sure as he has more than 1. Anyhow, I'll stick with factory specs.
July 22nd, 2014, 01:47 PM | #27 |
Long Time Rider
July 22nd, 2014, 03:28 PM | #28 |
July 22nd, 2014, 03:34 PM | #29 |
Long Time Rider
July 24th, 2014, 03:44 PM | #30 |
Join Date: Jun 2014 Motorcycle(s): 2012 NINJA 250R Posts: 2
I'm running the Michelin Pilot power 150/60ZR17 rear and Michelin Pilot power 110/70ZR17 up front ... *** my opinion *** the bike by far out performs the stock crap IRC rubber and size... running Nitrogen in the tires also as the climate change here in Nova Scotia is all over the map lol..
July 24th, 2014, 03:47 PM | #31 |
October 4th, 2014, 02:03 AM | #32 |
Freedom for Germany
Not really necessarily, it looks like that the stock swing arm is ok with the 5.5 inch rim from the ZX6R and a 180/55R17 tire http://www.ninja250thailand.com/boar...&topic=51414.0
By the way there are much more here with the same modification... |
October 4th, 2014, 05:58 AM | #33 | |
modaholic junkie
Join Date: Sep 2012 Motorcycle(s): 2001 ZX-12R, 2009 ninja 345cc and plenty of others in the past... Posts: 438
I don't understand much from the descriptions but judging from the pics that guy has fitted a whole ER-6 front system (ninja 650) with its discs along with a 250 stock front rim or what? the swingarm looks stock but rear tyre also looks as stock ER-6 size which I believe is 160/60.... or are both rims oversize but have the 250's looks ?? I saw he writes about ZX-6R "rear mag" but what does that mean ? could you provide some more info on that please ? last but not least... how did he fit the ER-6 front on the 250 ? is it "plug and play" fit or did he have to chop off the stem and put the 250's welded on ?? if it is not a bolt-on fit, I believe @Rassie 's choice of putting an inverted ZX-6R front is way better...
If noone has tried it before, I will !!! |
October 4th, 2014, 06:40 AM | #34 | |
Freedom for Germany
For me there is the problem that I don't speak the language and then I use my wife for translating, but she doesn't understand anything about technical things. So the guys then talk with her about how blue the sky is and there I stand with my pulled-down pants... So as I understand for the future I don't post anything from here no more. |
October 4th, 2014, 02:11 PM | #35 | |
modaholic junkie
I'm sorry if I got carried away from my enthusiasm, I just can't help it when I see mods like that...
Wider rear rim RACE LEGAL? | krolinked | Ninjettes At Speed | 9 | December 8th, 2012 09:12 AM |
2009 Ninja 250r with a wider tire | schultzy808 | 2008 - 2012 Ninja 250R Tech Talk | 43 | June 14th, 2012 04:43 PM |
Is a wider rear wheel possible? | dburgess1231 | 1986 - 2007 Ninja 250R Tech Talk | 11 | March 27th, 2012 10:43 AM |
Not your normal wider tire thread | Jinx250 | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 23rd, 2011 09:05 PM |
About wider tires | bogdanb | 2008 - 2012 Ninja 250R Farkles | 20 | July 15th, 2009 01:57 PM |
