Old June 26th, 2012, 05:50 PM   #1
tsdexter
Motorcycle(s): 2008 Ninja 250R - Kawi Green
Just bought used, what should I do to ensure a healthy engine?
Hi guys,
Noob alert. I'm new to motorcycles and doing my own work. I am quite capable of it, just don't know what's good/bad/better etc..
I bought a used 08 with 17,000km, claimed oil changes every 5000km, claimed carbs and valves done in December.. The bike is pretty well mint condition, coming from a reliable bike mechanic, so I know it was at least taken care of.
However, I want to make sure it's brought up to spec and healthy... What should I do before I start riding it? Oil change and chain lube obviously, anything else? I saw at the store carb cleaner spray, oil flush/clean, fuel additives and a bunch of other stuff.. Should I use any of these? Any brands?
Should I replace the spark plugs too?
Thanks for the advice
tsdexter is offline   Reply With Quote
Old June 26th, 2012, 06:05 PM   #2
Sailariel
Sailariel's Avatar
I would certainly lube the chain, change the oil and filter (might be a good time to change to synthetic), lube the cables, and check the tyre pressure. Sounds like a great bike---enjoy.
I would stay away from additives/carb cleaners, etc. They are a lot of hype. I would only use a gasoline additive if the bike is stored--I recommend "Star-Tron"
Hope that helps. Ride Safe.
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550
Old June 26th, 2012, 06:12 PM   #3
tsdexter
Thanks, I appreciate the advice! Unfortunately I can't ride at all until I do the safety course, in two week, so I certainly will!
Old June 26th, 2012, 06:17 PM   #4
Sailariel
Sailariel's Avatar
Do all the maintenance and then wax the hell out of it--make it shine. Rim tape is also a good thing especially if it is reflective.
Old June 26th, 2012, 06:26 PM   #5
tsdexter
That's the plan! Know a good wax?
Old June 26th, 2012, 06:41 PM   #6
Sailariel
Sailariel's Avatar
I use Honda Pro Polish. Works well with plastic.
Old June 26th, 2012, 07:35 PM   #7
thurt88
thurt88's Avatar
Motorcycle(s): 2014 Honda CRF250L, 2010 ninja 250r
I always just used turtle wax Good call on the star-tron, good stuff. I would never use seafoam....never ever ever !
thurt88 is offline   Reply With Quote
Old June 26th, 2012, 08:37 PM   #8
Countersteer
Countersteer's Avatar
Motorcycle(s): <2008 250R> Past Bikes:06 GSXR600 89 CBR1000 78 Hawk 400 86 Ninja 600R 86 & 87 FZ600 81 GPZ550 71 CB360T
Shim the cush drive. Here is Alex's info that I used to do mine (Thank's Alex!)
http://www.ninjette.org/forums/showp...2&postcount=20
And let me tell you, it makes a world of difference! Also, get the front forks under control. Depending on your body weight the stock springs and oil are worthless, almost dangerous. For me at 250-260 geared-up the stock fork compressed so badly as to make the rear brake useless. If you want the $15 method or the $130 method let me know and I can tell you what I did.
Have you ever read the King James Bible?
To say speed kills is akin to saying guns kill, neither of which is true.
Countersteer is offline   Reply With Quote
[crash.net - MotoGP] - Hayden: I need to get healthy Ninjette Newsbot Motorcycling News 0 July 15th, 2014 01:50 AM
What does a healthy chain look like? Brian General Motorcycling Discussion 18 April 27th, 2014 07:50 AM
[motorcycledaily.com] - Now We Shall See: Lorenzo Feels Healthy, Is Coming Off A Win, Ninjette Newsbot Motorcycling News 0 September 12th, 2013 06:20 PM
[topix.net] - Springsteen connects with Harley; Healthy TV? Ninjette Newsbot Motorcycling News 0 September 8th, 2008 06:19 AM
[topix.net] - New Way to Ensure Motorcycle Safety Ninjette Newsbot Motorcycling News 0 July 21st, 2008 12:23 PM
