January 20th, 2017, 05:19 PM | #1 |
Join Date: Nov 2015 Motorcycle(s): 2009 Ninja 250 Posts: 386
Can I still use this master link?
I am trying to do a rivet master link for the first time. And I was using the tool to rivet it, and I was using a set of micrometers to make sure the new one was the same flare as the existing. The existing is 5.60mm the new one I got to 5.55m and part of the rivet kinda split. Do I need to get another master link?
Large pic, you can see it around 11 o'clock |
January 20th, 2017, 05:34 PM | #3 |
January 20th, 2017, 05:55 PM | #4 |
Not to tell anyone what to do with his or her own safety, but I've used clip type master links for many tens of thousands of miles and never had one give me any trouble. With an O-ring or X-ring chain, you do have to squeeze the link together and make sure the clip is really seated in the grooves properly. These days I usually do this to them with some good adhesive like 3M weather strip adhesive, although in the past I've used them without it:
January 20th, 2017, 06:07 PM | #5 | |
1. Install it the right direction 2. Keep your chain adjusted 3. Keep your chain clean and lubed 4. Inspect it a bit more often There shouldn't be much issue really, but like you... I want a rivet type.
January 20th, 2017, 06:12 PM | #6 | |
January 20th, 2017, 06:53 PM | #7 | |
MOTY - 2018, MOTM - Oct '16
It doesn't take much...if you doubt it just try to get it off, and I'm with Jim .....never had a problem with master link clips.
January 20th, 2017, 07:32 PM | #8 |
In in the Clip club myself for many years, no issues if you install it properly, and maintain the chain.
January 20th, 2017, 08:45 PM | #9 |
I went ahead and ordered 2 more master links. 5$ each. Since I made the investment in a tool I might as well finish the job.
January 21st, 2017, 05:20 AM | #10 |
Join Date: Jul 2015 Motorcycle(s): TOOOOOO MANY!! Posts: 87
Heck,I race with clip links. Just smear some clear silicone over it as a little extra "placebo" and go with it. Keep it all clean and lubed to move freely and fugetaboutit
January 21st, 2017, 07:12 AM | #11 |
cadd cadd cadd
MOTM - May '15
I have good experiences with clip type master links. Goes on & comes off easy with needle nose pliers.
My personal opinion: Although not as secure as rivet type of master links, as long as the clip is installed in the proper direction and you keep your chain reasonably maintained, I don't see how the clip can fail.
January 21st, 2017, 07:37 AM | #12 | |
January 21st, 2017, 07:40 AM | #13 |
I'm surprised that the riveting tool isn't designed to stop when it's done, especially if going too far splits the rivet head.
January 21st, 2017, 09:38 AM | #14 |
one more reply for the clip, love em.
January 22nd, 2017, 09:49 AM | #15 |
Join Date: Oct 2013 Motorcycle(s): gsxr 750, sv650, 250 ninja Posts: 110
don't change it , it's still 100 times stronger than a clip
Can I use an RK XSO Master Link with an SO chain? | daverdfw | Ninjettes At Speed | 10 | January 10th, 2017 05:38 PM |
Missing piece to my master link?! | mrudich | 1986 - 2007 Ninja 250R Tech Talk | 24 | October 10th, 2014 07:29 PM |
FS: RK XSO 520 gold rivet master link | choneofakind | Motorcycle-related | 3 | January 18th, 2012 05:48 PM |
Riveting new master-link | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 13 | December 17th, 2011 06:39 PM |
Watch your master link clips!!!! | bdavison | General Motorcycling Discussion | 42 | October 7th, 2011 08:07 AM |
