April 21st, 2013, 09:11 PM | #1 |
The Black Ninja
Join Date: Apr 2013 Motorcycle(s): 1989 Kawasaki Ninja EX250 Posts: 13
If it's not one thing.......
Well I have got my petcock leak temporarily fixed with a universal fuel shut off valve. So since I got it fixed this morning I decided to put my plastics on for the first time since I bought the bike. I got the front plastic and the bolts the man I bought it from gave me in a ziploc baggy labled Front Plastic Bolts and started putting them in.
I got all of them put in and noticed gas dripping and thought my valve failed so I started taking them out. The last bolt I took out I had gas flow a foot out the side of my tank and I freaked. Turns out he gave me the wrong bolts and they were to long and it went through the side of my tank, I went and got some all thread and a thing of gas tank epoxy. My plan is tomorrow when I get home to put epoxy on the all thread stud bolt and run it though and just hold my plastic on with a nut. I'll cover the bolt with some epoxy and feather it to the outside of the tank to get it to hold. What yall think about that idea? The bolt literally just threaded through the tank on the top left bolt hole.I can't afford a whole new tank so this is gonna have to work for now. DrewHamm974 |
April 21st, 2013, 09:16 PM | #2 |
Join Date: Jan 2012 Motorcycle(s): 2009 Kawi 250 Posts: 118
Pics or it didnt happen
April 22nd, 2013, 06:29 AM | #3 |
This is pretty common on pregens. The owner did not give you the wrong bolts; two of the tank bolts are a few mm shorter than the other two. Kawasaki corrected this on newer pregens, but it's always a good idea to make sure the shorter bolts are in the top holes.
How hard did you have to turn the bolt in to puncture the tank????? More info here: http://faq.ninja250.org/wiki/Replaci...asteners/bolts and here: http://faq.ninja250.org/wiki/How_do_...l_tank,_etc%3F It's more common than you'd think, and surprisingly hard to fix. |
April 22nd, 2013, 08:01 PM | #4 |
The Black Ninja
I barely snugged it. I let it tighten up on all of them and after it felt tight I snugged it just a little more. I didn't feel any resistance at all honestly, it just felt like I was getting her nice and snug. Today though I took that epoxy and covered the threads on my stud bolt. When i ran that through the tank about a half inch I put a nice solid coat on the outside of the bolt around a half inch. Let her dry for 4 hours, poured some gas in, and had her running. No leaks at all. Put the plastics on and then tightened a nut on that stud bold and cut it to length. So now I have a permanent stud out my tank but with the plastics on you would never be able to tell thhe difference. I got the repair hiding. I'm also about to post some pictures of my bike if you want to see them.
April 22nd, 2013, 08:29 PM | #5 | |
Join Date: Jan 2013 Motorcycle(s): 03' Ninja 250ex Posts: 333
April 23rd, 2013, 08:37 AM | #6 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250R '07 Posts: 81
Check this out. This dude got it welded for $50, but that included some extra work so you may be able to get it done for cheaper. Just make sure to clean out the tank VERY VERY VERY well.
http://www.ninjette.org/forums/showthread.php?t=130076 |
April 23rd, 2013, 10:43 AM | #7 |
The Black Ninja
That's what I was thinking as well.I may not be a master mechanic but I've done my fair share of repairs and I know there is no way I would torque it enough to puncture the tank.... I might get it welded but for right now the epoxy is holding very well. As for the pictures, I took them but I cannot seem to find my cable to connect my camera to the computer. I will as soon as I can because I want y'all to see my baby. As far as the repair went it seems whenever the bolt went through the tank, the small weld around the bolt bracket ( thats what it looks like anyways is a bracket) on the tank seems to have busted so I had to put the epoxy around it as well. Now to sand and put a coat of new paint. The gas ate mine off the tank.
April 23rd, 2013, 01:11 PM | #8 |
I guess that will work for now but I'm sure you know it's by no means a permanent fix. Eventually you're gunna need to take the tank off and/or that epoxy is gunna dissolve.
Can't wait to see the pics. |
I love this thing | Apex | Off-Topic | 3 | January 7th, 2014 08:20 AM |
What is this thing? | thisisbenji | 2008 - 2012 Ninja 250R Tech Talk | 17 | January 5th, 2012 06:16 PM |
What's this thing? | the big mike | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 3rd, 2011 07:17 PM |
What is this thing? | sixer | General Motorcycling Discussion | 4 | December 12th, 2009 10:13 AM |
Its just one thing after another... | Loaded Moses | General Motorcycling Discussion | 26 | June 30th, 2009 11:12 AM |
