October 29th, 2013, 06:59 AM | #1 |
Join Date: Oct 2013 Motorcycle(s): 08 Ninja 250r Posts: 23
K&N Air filter
hi guys/gals this has probably been covered more than once, but unfortuneately the search function is not working on my tablet.
I installed a k&n airfilter ka-2508. The cover did not sit flush with the airbox (until i bolted it tight), filter was sticking out just slightly? After i tightened the allen bolts it looks fine, just curious if this is normal or do i need more grease on the lip to slide it in further? Cheers |
October 29th, 2013, 07:47 AM | #2 |
Improperly fitting filters have been reported more than a few times. Be careful not to over tighten the cover if the filter is not fitting properly. Bending or warping of the cover may occur. This may also cause some air to leak in too. A easy remedy is too shave a little rubber off on the ends of the filter to ensure a proper fit of the airbox cover.
October 29th, 2013, 07:52 AM | #3 | |
Cheers |
October 30th, 2013, 12:04 AM | #4 |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
i had to shave some rubber off with a razor blade for mine to fit
October 30th, 2013, 01:03 PM | #5 |
November 1st, 2013, 07:18 PM | #6 |
Join Date: Sep 2013 Motorcycle(s): 2009 Ninja 250R Special Edition Posts: 18
you may want to shim your needle with 1 washer for better performance if you notice that your bike doesn't want to stay on with a cold startup or lags at lower rpms.
Installing the filter will make the bike run a bit leaner than it already is from the factory! I just shimmed with two washers and i have a K&n filter and Yoshi exhaust... it feels like a new bike!
2009 Kawasaki Ninja 250R Special Edition 2005 Lotus Elise Sports Pack |
November 1st, 2013, 09:04 PM | #7 |
Join Date: Nov 2011 Motorcycle(s): Many Two Wheels .. Posts: 611
There is a recess at the far end of the airbox. The filter has to go all the way IN to the recess. The K&N is slightly thicker than OEM, so sometimes it is usual for the filter not to fit all the way into the recess.
I have a K&N and when i service it, it usually takes 2-3 tries to get it fit into the recess. It doesnt stick out to the extent that i would have to press the cover.
[ex-AFM #828 | SMUSA #828 | Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers + OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com |
Ninja 300 K&N Air Filter How To Install Tutorial & Quick Review Video | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 12 | June 27th, 2014 07:15 PM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2012 06:00 PM |
Anyone have a K&N Air Filter? | Machine1 | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 6th, 2012 02:09 PM |
