October 15th, 2015, 03:53 PM | #1 |
Join Date: Jul 2015 Motorcycle(s): 07 Ninja 01 Sportster Posts: 56
Trail Tech Vapor
Is anyone running a Trail Tech Vapor?
I installed one and can't get the tach to settle down. I'm at a single wrap on the sensor and it still jumps around a lot. |
October 18th, 2015, 08:07 PM | #2 |
Update for posterity.
After Googling around, I've found that the Vapor has had tach problems from day 1. You would think they would have addressed the issue by now. They continue to try to get their users to go with the inductive pickup. i.e. wrap the signal wire around the spark plug wire. Unfortunately the inductive pickup picks up everything. "Those bikes have a lot of electrical noise" to quote their tech support. All bikes have a lot of electrical noise. I suspect they use that phrase a lot. Use coax if you want to go that direction. They will sell you a resistor wire that can be connected to the +12v lead of the coil. Or, as most users have discovered, you can simply solder in a 540k - 640k resistor to the exisiting wire that comes with the unit. It's still the least stable tach I've ever had but this fix at least gets it into the acceptable range. |
October 19th, 2015, 04:10 AM | #3 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
I've used Trail Tech Vapor on my dirt bike, supermotard, single cylinder thumper, they've always been easy to install, function as they should.
Ninja 250 Vapor Trail Tech | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 35 | October 1st, 2017 04:10 PM |
Trail Tech Vapor Idiot lights | RogerPapaMike | 1986 - 2007 Ninja 250R Tech Talk | 3 | January 19th, 2015 10:11 AM |
Trail Tech Vapor Review | Kruse08 | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 19th, 2014 02:55 AM |
Trail Tech Vapor and mount | rugbert | 1986 - 2007 Ninja 250R Farkles | 12 | September 2nd, 2013 11:36 AM |
Vapor Trail Tech Question/Help | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 41 | May 12th, 2013 02:40 PM |
