Old October 27th, 2022, 09:05 AM   #1
[motorcycle.com] - 2023 BMW R 1250 R First Look
BMW announced minor updates to its R 1250 R, giving the Boxer-engined roadster a full LED headlight, and making some previously optional electronics standard, all while keeping the price unchanged at $14,995.
Visually, the 2023 BMW R 1250 R looks similar to the previous model. The most noticeable change is the new LED headlight, which can be upgraded to an optional adaptive turning light. The turn signals are now also LEDs, and come with an updated version of BMW’s Comfort Turn self-cancelling function.
The 1,254cc Boxer with liquid-cooled heads and ShiftCam variable intake timing and lift remains unchanged, claiming 136 hp at 7,750 rpm and 105 lb-ft. at 6,250 rpm. For 2023, the R 1250 R gains a third ride mode, with the new ECO mode joining the returning Road and Rain modes. In ECO mode, the ShiftCam system adopts a soft throttle curve and moderate engine torque limitation to maximize fuel economy and range.
A new optional seat spoiler adds a touch of sporty style.
The 2023 R 1250 R also gains the lean sensitive Dynamic Traction Control and Integral ABS Pro as standard equipment (they were previously offered as an option). Also standard is Dynamic Braking Control which works to reduce drive torque during braking to improve stability and reduce the braking distance.
The TFT full-color digital display gains a new “Sport” screen which provides lean angle information in real time, as well as data on the lean-sensitive control interventions.
The 2023 R 1250 R comes standard in an Ice Grey paint, but BMW does offer a premium Style Sport variant in Racing Blue Metallic with a white frame, gold-colored brake calipers, a blue chin spoiler, as well as a Triple Black version in Black Storm Metallic with an Agate Grey frame, gold-colored calipers, stainless steel radiator grille, and stainless steel chin spoiler.
For 2023, BMW offers the R 1250 R with a Premium Package which adds keyless ride, chrome-plated exhaust manifold, heated grips, tire pressure monitor and cruise control. BMW also offers a number of accessories from its Option 719 program including new wire-spoke wheels.
Expect the 2023 R 1250 R to arrive in U.S. dealerships in Spring 2023.
2023 BMW R 1250 R SpecificationsEngine TypeLiquid-cooled 2-cylinder, 4-stroke boxer engine with two overhead, spur-gear driven camshafts, counterbalance shaftCapacity1,254 ccBore x Stroke102.5 x 76.0 mmPower136 hp at 7,750 rpm (claimed)Torque105 lb-ft. at 6,250 rpm (claimed)Max. Engine Speed8,750 rpmCompression Ratio12.5:1Fuel TypePremiumValvetrainBMW ShiftCam variable intake camshaft control system, four valves per cylinderIntake / Exhaust Valve Diameter40 / 34 mmThrottle Body Diameter52 mmEngine ControlBMS-O, electronic fuel injection with ride-by-wire throttleEmission ControlClosed-loop 3-way catalytic converter, EU-5AlternatorThree-phase 508 watts wattsBattery12 volts / 12 Amp-hours Volta / AhHeadlampFull LED with daytime running lightStarter900 wattsClutchHydraulically operated, anti-hopping wet clutchGearboxConstant-mesh, 6-speed with helical-cut gearsPrimary Ratio1.65:1Gear RatiosI – 2.438:1
II – 1.714:1
III – 1.296:1
IV – 1.059:1
V – 0.943:1
VI – 0.848:1Secondary Ratio2.818:1Final DriveShaft-driveFrame Construction TypeTwo-section frame, main frame with bolt-on rear section and load-bearing engineFront Suspension45 mm upside-down telescopic forkRear SuspensionCast aluminum swingarm with BMW Paralever, WAD travel-dependent spring/shock, continuously adjustable spring preload by means of hand knob, adjustable rebound stages by hand knob,
Optional Dynamic ESA Next Generation; 5.5 inches of travel.Rake / Trail27.7° / 4.9 InchesFront BrakeTwin 320 mm floating disks, 4-piston radial calipersRear BrakeSingle 276 mm disk, 2-piston floating caliperAbsBMW Motorrad Integral ABS ProTraction ControlFront Wheel3.5 x 17″ cast aluminumRear Wheel5.5 x 17″ cast aluminumFront Tire120/70 ZR17Rear Tire120/70 ZR17Length85.2 inchesWidth34.6 inches (with mirrors)Wheelbase59.6 inchesSeat Height32.3 standard, 29.9 – 33.1 possible inchesCurb Weight527 pounds (claimed)Fuel Tank Capacity4.8 gallonsBecome a Motorcycle.com insider. Get the latest motorcycle news first by subscribing to our newsletter here.
The post 2023 BMW R 1250 R – First Look appeared first on Motorcycle.com.
Click here for full story...
[roadracingworld.com] - More Electronic Features Now Standard On 2023 BMW R 1250 R Ninjette Newsbot Motorcycling News 0 October 27th, 2022 08:06 AM
[ridermagazine.com] - 2023 BMW R 1250 R | First Look Review Ninjette Newsbot Motorcycling News 0 October 27th, 2022 08:06 AM
[RideApart] - BMW R 1250 R and R 1250 RS To Get Minor Updates For 2023 Ninjette Newsbot Motorcycling News 0 September 25th, 2022 09:30 AM
[cycleworld.com] - 2023 BMW R 1250 RS and R 1250 R Updates Ninjette Newsbot Motorcycling News 0 September 22nd, 2022 12:27 PM
[RideApart] - 2023 BMW R 1250 GS Trophy Comes Ready For Adventure Right Out Of The Bo Ninjette Newsbot Motorcycling News 0 July 1st, 2022 09:51 AM
