Old September 12th, 2019, 09:12 PM   #1
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
Exhaust Leak?
I've been noticing an more than normal amount of exhaust smell when I'm riding around. Side note I do have the fairings off right now.
I want to check to see if I have an exhaust leak somewhere. Any tips on how to do this? I sprayed some brake cleaner on the exhaust manifold ports and didn't notice and engine surging. I also blew some ecig vapor over the exhaust manifold openings to see if the ecig vapor moved indicating a leak.
I noticed a little hole on the bottom of my exhaust that is spewing exhaust out. Is this hole supposed to be here?
Other methods to check for an exhaust leak?
Edit: resized picture because it was ridiculously large
Last futzed with by nocturncal; September 19th, 2019 at 11:24 PM.
Old September 13th, 2019, 05:50 AM   #2
You gotta resize that photo...
That looks like a drain hole to let moisture out of the muffler.
With it idling you can cover the exhaust outlet with the sole of your shoe (or have a helper do it) and listen for exhaust escaping. If it's been leaking for a while there may also be deposits around the area.
You won't get any reaction or RPM change by spraying anything on the exhaust, that only works for finding intake leaks. Not sure I'd spray anything on a hot exhaust system.
Old September 13th, 2019, 12:21 PM   #3
Best way to find any sort of leak is to plug ends and pressurise intake. Then spray soapy water on outside and look for bubbles.
Old September 19th, 2019, 11:22 PM   #4
nocturncal
nocturncal's Avatar
Awesome thanks, I'll try this out
Exhaust leak on the right side Sirref 1986 - 2007 Ninja 250R Tech Talk 9 December 14th, 2014 08:01 PM
exhaust leak Solunatic 1986 - 2007 Ninja 250R Tech Talk 1 July 26th, 2013 04:29 AM
Exhaust leak chikenstrips 2008 - 2012 Ninja 250R Tech Talk 11 April 30th, 2012 09:22 AM
How much popping? (and exhaust leak) singlecoillover 2008 - 2012 Ninja 250R Tech Talk 30 May 30th, 2011 08:35 PM
Exhaust Leak Betlog 2008 - 2012 Ninja 250R Tech Talk 3 April 24th, 2010 10:27 PM
